| Cheerfulgrin |
 Cheerfulgrin Scooby Slapper
 Posted: 10:44 - 24 Feb 2013 Post subject: battery charging whilst attached to bike |
I've searched and read a few threads that say charging whilst still on the bike should be fine. Thing is, my battery doesn't seem to charge if it's still attached to the bike, it charges happily when off the bike.
Is this quite common or could it be an indication of a short on the bike or something?
I have disconnected the hand grips and cig lighter socket just in case these where causing a problem but it still didn't charge.
Thanks
Rob ____________________ --Current Bike: '98 Hornet CB600F
--Previous Bikes 2012 Hyo GT250R - 2010 YBR125 - Back in '91:Suzuki 50cc moped & Honda CB125T Superdream
--CBT -Feb '11, Theory -Nov '11, Mod 1 -Jan '12, Mod 2 Feb '12 |
| orac |
 orac World Chat Champion
| Stonefly |
 Stonefly Scooby Slapper
 Posted: 11:39 - 24 Feb 2013 Post subject: |
I regulary use an optimate to trickle charge my battery whilst still connected to the bike. I also have an alarm fitted, and have never had any problems. ____________________ Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250 |
| Cheerfulgrin |
 Posted: 11:41 - 24 Feb 2013 Post subject: |
It doesn't have an alarm, other than the dog who lives here, so won't be that.
It's not an Optimate, it's a halfords maintenance charger which kicks out 750 milliamps.
I don't have a Haynes manual, I don't think they do them for hyosungs, but I'll check between positive terminals and post result.
Should I be checking amps while ignition is off and not running?
Thanks for the quick reply  ____________________ --Current Bike: '98 Hornet CB600F
| Cheerfulgrin |
 Posted: 12:27 - 24 Feb 2013 Post subject: |
I checked between battery and bike positive terminals and when turning the ignition on got a reading of 0.1 amps which went down to 0.06 once it had Settled down.
I should probably mention the bike is outside whilst charging and it's been pretty cold here, maybe that's effecting the battery charging whilst on the bike? ____________________ --Current Bike: '98 Hornet CB600F
| Stonefly |
 Posted: 13:41 - 24 Feb 2013 Post subject: |
My bike is always outside and i have had no problems with trickle charging. Sounds like you may have a small drain to earth somewhere. Check all your electrical connections for corrosion. It dont take much for a crusty connecter to cause a drain. ____________________ Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
| doggone |
 doggone World Chat Champion
| reckless_b |
 reckless_b Trackday Trickster
| J.M. |
 J.M. World Chat Champion
| orac |
| Cheerfulgrin |
 Posted: 20:07 - 24 Feb 2013 Post subject: |
it does go flat quite often if i dont use it, takes about 3 days and then it wont start up. If i use it daily it tends to be ok.
when i got the battery i was broken down so couldnt charge it before use, which probably hasnt helped much. the fella in the garage said it should be charged overnight before use, but i didnt have a charger back then, so it just got charged by me riding it every day.
its been totally flat a few times which has probably knackered it, i think a new battery will be in order soon but would prefer to eek this one out for as long as i can, at least till the freezing weather has gone. ____________________ --Current Bike: '98 Hornet CB600F
| J.M. |
| neil. |
 neil. World Chat Champion
The last post was made 13 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
