Kwakasaki GT550 Bars.
AlekSmart
PostPosted: 20:16 - 24 Sep 2012    Post subject: Kwakasaki GT550 Bars. Reply with quote
Hi there.
Has anybody got experience/info on whats required to fit "Ordinary" bars to a GT550 G4 or am I doomed to forever wander abroad with those contraptions originally fitted ?
Casper
PostPosted: 20:25 - 24 Sep 2012    Post subject: Re: Kwakasaki GT550 Bars. Reply with quote
AlekSmart wrote:
Hi there.
They are the same set up as my GPZ. Shit.
Drill two holes in your top yoke and get a set of bar risers and bars to swap over. You may need longer clutch and throttle cables and pull the loom through to let the switchgear reach.
temeluchus
PostPosted: 20:48 - 24 Sep 2012    Post subject: Reply with quote
I think a Z550 top yolk might fit.
Casper
PostPosted: 21:00 - 24 Sep 2012    Post subject: Reply with quote
I was looking into that also but having dam skinny forks made the choice limited (37mm) also mounts for clocks and ignition may not line up. I am changing mine over winter and i bought a spare top yoke that had been drilled. Ill be looking for cheap 2nd hand risers and bars soon.
temeluchus
PostPosted: 21:17 - 24 Sep 2012    Post subject: Reply with quote
I think the z550 has the same forks.
There are also a few custom variations floating around that may do the trick from the z's. US imports all had normal bars as well i believe.
Casper
PostPosted: 21:32 - 24 Sep 2012    Post subject: Reply with quote
If its the bar hight the OP has a problem with. If you have an early GT some had bars that only sat about an inch tall. Some of the later ones the were risen to about one and a half inch, could have been two.
temeluchus
PostPosted: 21:46 - 24 Sep 2012    Post subject: Reply with quote
to clarify, the z550 and the customs(rather than the z550gt) used normal 3/8" bars.
Thugly grunt
PostPosted: 17:34 - 25 Feb 2013    Post subject: GT550 Reply with quote
I was wondering if anyone has changed the top yoke on a GT550 I want to put as set of t bars on mine any help I would be very greatfull cheers
Casper
PostPosted: 20:53 - 25 Feb 2013    Post subject: Re: GT550 Reply with quote
As said to th eother bloke measure your stanchions. If the same as the donner ones from another kwak then it will fit. I would go gor the Drill your yoke option as the fixing bolt holes may be different from your bike to the donner one. If you have a spare few quid buy a 2nd hand one to drill so you can put your bike back to standard if needed.
The last post was made 13 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.39 - MySQL Queries: 14 - Page Size: 59.05 Kb
