Standalone 1Tb Media Players which attach straight to the TV
GSTEEL32
PostPosted: 20:52 - 10 Mar 2013    Post subject: Standalone 1Tb Media Players which attach straight to the TV Reply with quote
Guys, I appreciate this is a biking forum but there seems to be a fair few amount of you that know your techhie shit.
Basically, I'm looking for a Media Player to run films and stuff direct from it's hard drive to the TV.
A friend suggested the Cyclone 1tb system but said the software was "clunky", whatever that means. I also see CnM do a system but that also has mixed reviews.
Anyone on here use either system or an alternative?, I'm looking to make the wife's life easier when entertaining the nipper at home, so I want a system that's self sufficient once files have been copied over...
Jayy
Mr. Ponzi
PostPosted: 21:36 - 10 Mar 2013    Post subject: Reply with quote
I will suggest a slight alternative on the cyclone system but made by the same people.
You can probably get this down to £22 odd if you shop around but it's a cycle micro 2+ device.
https://www.ebuyer.com/274064-cyclone-micro-2-mkv-player-cyclone-micro-2-player
Couple that with an external 1TB HDD (plugs in via USB) and you have a very capable player. I have one of these, recommended them to my parents and sister and not had a single issue.
I know it's not all contained in one unit (have to plug HDD in) but it really is simple. Box goes in to TV via HDMI and HDD in to box via USB.
The only cons with the cyclone series is:-
Controller is a bit flimsy and sometimes have to point it directly at the box head on or it doesn't register what you're clicking.
If you have hundreds of files in one folder, there's no search. You have to scroll down to find your stuff.
Other than that, can't fault them. I would never recommend DVD/Bluray players to anyone when you can store hundreds of your films on 1 drive.
Dweezil
PostPosted: 21:54 - 10 Mar 2013    Post subject: Reply with quote
I use an old style Xbox (soft modded) networked to my comps through a linux server running samba (windows to linux transfer protocol) linked to a hub so all PC's on the network are seen by all others including the xbox. plays anything I throw at it using Xbox media centre (XBMC) If you have an old Xbox, all you need is another network card in your comp and it should read it fine. it will cost you about £5.00 for the card and a cat 5 cable.
Hope this helps mate
Jayy
Mr. Ponzi
PostPosted: 22:00 - 10 Mar 2013    Post subject: Reply with quote
That's a bit complex for his missus though mate, needs to be easy to setup Very Happy
Dweezil
PostPosted: 22:56 - 10 Mar 2013    Post subject: Reply with quote
True mate,
I'm just a skinflint. I was in Bornio and they wanted £1500 for the same server spec that I built here for £50 out of old bits.
It is quite easy though, just need an old PC with two network cards. install linux server (I use ubuntu) tell the Xbox (chipped) the local IP address. set the shares and your away. (with a little tweaking of course)
The last post was made 13 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.08 - MySQL Queries: 17 - Page Size: 46.65 Kb
