tom_m |
tom_m Scooby Slapper
Posted: 21:41 - 12 Mar 2013 Post subject: 2008 YBR 125 not starting |
Just popped round to have a look at brothers ybr, it is a 2008 EFI model. when you try to start it the engine management light (orange)flashes repeatedly, does have a spark but just wont fire up, tried different plug, tried to bump it and kick it over without any luck.
anybody any ideas? ____________________ Current: 2005 Kawasaki Er-5 C5P
Past: 2012 Yamaha Ybr 125, 2004 Yamaha Neos 50, 1994 Suzuki Gn 125, 2005 Aprilia Sportcity 125, 1988 Yamaha Tzr 125
Theory: Passed... Mod 1: Passed 22/08/12 Mod 2: Passed 22/10/12 |
jamieward |
jamieward Nova Slayer
Posted: 22:03 - 12 Mar 2013 Post subject: |
have you tried putting abit of petrol down in the sparkplug hole mate might give it abit of luck and I allways though that the light comes on normally when the bike isn't ticking over ____________________ first bike was a derbi gpr 50 got some right looks when I fired up lol
second bike is a tuono rs 125 love the bike keeps up with the 600's |
tom_m |
Alpha-9 |
Alpha-9 Super Spammer
Posted: 22:08 - 12 Mar 2013 Post subject: |
The way the light flashes will be a fault code
How many times does it flash and in what timing?
Ie. pulsing slowly/quickly
I had that once..think it was just a knackered/low battery
When it's too low the injectors can't work, FI madness ____________________ Fzr-600 1999 |
tom_m |
Alpha-9 |
tom_m |
Alpha-9 |
Posted: 22:18 - 12 Mar 2013 Post subject: |
tom_m |
Posted: 22:25 - 12 Mar 2013 Post subject: |
When you try to kick it does the same, the light pulses constantly. The 2012 doesnt have a kickstart , but it does have a big black grommet where the kickstart is on the 2008 one so im assuming one could be fitted (yam cutting costs ey ?).
I never tried using the rest of the electrics, as these stoopid ybr's dont have a headlight switch and full lights will only come on once the engine is started. Im gunna go round in morning and have a proper look, swap batteries over and check electrics etc.
Id ask my bro to help me but after the comment he gave me the other day i dont thinkso.
"I thought you switched it to high beam when it was night time so you could see easier, wondered why people have been flashing me for the last 6 months" .... what a bellend ____________________ Current: 2005 Kawasaki Er-5 C5P
gfrancisdev |
gfrancisdev Nova Slayer
tom_m |
Posted: 01:36 - 13 Mar 2013 Post subject: |
gfrancisdev wrote: | just for reference that bike will start without a battery if you kick hard/rapidly enough, though it's probably not too healthy, the rev counter goes nuts and the light barely works
though according to my haynes manual that's a ecu fault code, and is stored until the memory is cleared, the faults that won't let it restart are:
19-no signal from black/white wire between ignition and ecu
30-tip over sensor(triggered)
33-ignition coil
39-fuel injector
41-tip over(bad wiring/faulty sensor)
50-ecu malfunction
the light flashing pattern says which code it is, first number is long flashes, second is short
15 = 1 long flash, 5 short flashes |
Thanks for that will get it up on my phone when i have a look in the morning, il report back once ive had a nosey at it. ____________________ Current: 2005 Kawasaki Er-5 C5P
BG5067 |
BG5067 Spanner Monkey
tom_m |
Posted: 17:32 - 13 Mar 2013 Post subject: |
33-ignition coil
39-fuel injector
50-ecu malfunction
Bike is flashing 1 long flash and 9 short flashes. Code 19. Now im currently ripping the bike apart checking the black/white wire from ignition to ecu ____________________ Current: 2005 Kawasaki Er-5 C5P
gfrancisdev |
smarjoram |
smarjoram Borekit Bruiser
Alpha-9 |
gfrancisdev |
smarjoram |
smarjoram |
smarjoram |
kevinheb |
kevinheb Two Stroke Sniffer
Alpha-9 |
kevinheb |
There is a gap of 221 days between these two posts... |
simonjb |
simonjb Nova Slayer
There is a gap of 4 years, 59 days between these two posts... |
leroymel |
leroymel L Plate Warrior
The last post was made 6 years, 96 days ago. Instead of replying here, would creating a new thread be more useful? |
