Balancing carbs?
Symon27
PostPosted: 16:52 - 10 Mar 2013    Post subject: Balancing carbs? Reply with quote
How many times do you balance your carbs?
I seem to have to do it every 6 months.
Is this normal?
Honda Nsr 125 - Sold
Zxr 400 - Sold
Bandit 600 - Current (Y)
Copycat73
PostPosted: 18:16 - 10 Mar 2013    Post subject: Reply with quote
every 2-3 years
caveat emptor
thomp1983
PostPosted: 19:00 - 10 Mar 2013    Post subject: Reply with quote
6 months is about normal for a zxr400 i usually do mine 3 or 4 times a year doesn't take long if you make a manometer with long pipes to go to the carbs
Chris.
frostage
PostPosted: 19:35 - 10 Mar 2013    Post subject: Reply with quote
You SHOULD balance your carbs with even a change in weather, so this question really is "How many times do you BOTHER balancing your carbs?
Personally I will check the balance with a simple 4-guage set from ebay roughly twice a year (height of summer / height of winter).
Any sort of engine modification will also of course result in a balance/tune.
All depends on the bike other than that, some bikes are fussy and need constant balancing, others will run right for years. Rule of thumb would be if it don't sound/ride right it probably aint!
2000 Gixxer 750
1995 RM 250
Symon94
PostPosted: 19:38 - 10 Mar 2013    Post subject: Reply with quote
Cheers, so every 6 months is about right then, I it dose seem to be when the weather gets nice, and once again when cold.
frostage
PostPosted: 20:02 - 10 Mar 2013    Post subject: Reply with quote
Yeah you should be fine Thumbs Up
2000 Gixxer 750
1995 RM 250
StevRS
PostPosted: 13:23 - 12 Mar 2013    Post subject: Reply with quote
My ZZR1100 needs a carb balance with every 3k oil change according to the service schedule and it needs it by then.
MV Agusta Brutale 800 RR, Unfinished 1978 XS250
Fizzer Thou
PostPosted: 12:29 - 14 Mar 2013    Post subject: Reply with quote
My friends ZZR1100 needed the carbs balancing but not until we had done the shims,air filter and spark plugs.He was astounded by how much differance it made to the smoothness of the engine and how much easier it was to pull away from low revs once done
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture561.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture566.jpg
Pictured are the readings on my R1 but the results were similar Thumbs Up
Always have a 'Plan B'
Jefr0
PostPosted: 20:50 - 14 Mar 2013    Post subject: Reply with quote
Sorry to hijack.
I've owned my Cbr 600 for 6 years 30k miles and have never balanced the carbs. Is this something that should be checked as the bike seems to run fine?
Although I may notice a difference once done?
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
Sid_The_Sloth
PostPosted: 00:20 - 15 Mar 2013    Post subject: Reply with quote
Another question to add to this, is it possible to do this using the bikes own fuel tank rather than hooking up a make shift gravity feed tank?
Fizzer Thou
PostPosted: 11:45 - 15 Mar 2013    Post subject: Reply with quote
In answer to the last two questions,the only way to see if the throttle bodies need balancing is to plug the gauges in and to see how far out they are - if at all.If you pull the clutch in and any rumble from the bottom end smootes out or lessens,this might suggest that the balancing needs to be checked.
As for using the petrol tank while checking the balanceof the throttle bodies,if the system is pressure fed ie.fuel injected,you may well not be able to useanything other than the tank due to a return system if it has one.Otherwise,you could make a gravity fed system quite easily.
The last post was made 12 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.39 - MySQL Queries: 14 - Page Size: 69.32 Kb
