| Chonk1978 |
 Chonk1978 L Plate Warrior
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 20:04 - 20 Mar 2013 Post subject: |
you may have an air lock in the fuel system,if poss drain the carb to check that fuel is reaching the carb,and check the 'cleaned filter' if its a foam...wash in parrafin type....is'nt damp ,as this will make the carb run superich and flood it. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| sickpup |
 sickpup Old Timer
| Chonk1978 |
| unitynotsocri... |
 Posted: 11:09 - 21 Mar 2013 Post subject: |
you'd need to find a diagram of the carb and thermostat to see if it has a cut out circuit,if its not leaking then it may still be ok... ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Chonk1978 |
| Chonk1978 |
The last post was made 12 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
