Yamaha ybr 125 idle ajustment.
pmidd
PostPosted: 21:17 - 21 Mar 2013    Post subject: Yamaha ybr 125 idle ajustment. Reply with quote
Hi, Got myself a 2011 Yamaha ybr 125 and this cold weather is playing havoc with my tick over, i'm having to keep the choke on for quite a while and then even when it's warmed up the rev counter still shows under 1000 revs . How can i tweak this up a bit?
Many thanks in advance,
Paul.
Mark65
PostPosted: 21:26 - 21 Mar 2013    Post subject: Reply with quote
2011 choke??
YBR Ric
When you say a 2011 YBR, do you mean a 4 year old carb model which was eventually registered in 2011 and advertised as a 2011 model?
There was one such bike (in red) with a built in square headlamp fairing up for sale in a dealers recently.
pmidd
PostPosted: 21:33 - 21 Mar 2013    Post subject: Reply with quote
Hi, it's a 2011 registered 61 plate 2 years old. No kick start!
YBR Ric
PostPosted: 21:37 - 21 Mar 2013    Post subject: Reply with quote
Tickover adjustment will be by way of an anticlockwise twist of the small brass screw found on the right hand side of the injector body when engine is at normal working temperature. 1300-1500rpm is book recommendation for idle speed.
Try 1/2 turn first.
pmidd
PostPosted: 21:44 - 21 Mar 2013    Post subject: Reply with quote
Might sound a bit slack, but is that right hand side when sat on bike or facing the bike ? Very Happy
Boris the spider
PostPosted: 21:50 - 21 Mar 2013    Post subject: Reply with quote
Try 1/2 turn first.
Pic ?
Just for reference as i have an injected YBR for commuting.
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
YBR Ric
PostPosted: 21:51 - 21 Mar 2013    Post subject: Reply with quote
https://i162.photobucket.com/albums/t245/portisheadric/P1000346_zps85feee6a.gif
Right hand when sitting on the bike - spark plug side
Out of curiosity, what are you adjusting that you believe to be a choke?
If everything's working as it should the revs will increase automatically to compensate for a cold engine and return to normal once having reached normal operating temperature.
pmidd
PostPosted: 21:53 - 21 Mar 2013    Post subject: Reply with quote
Will have a look tomorrow and take a picture.
Many Thanks again,
Paul.
pmidd
PostPosted: 21:55 - 21 Mar 2013    Post subject: Reply with quote
On the left hand side of the carb there is a leaver with a black rubber end that pushes up for on and down to turn off.
Boris the spider
PostPosted: 22:14 - 21 Mar 2013    Post subject: Reply with quote
My 2008 YBR is injected and does not have a choke.
Boris the spider
PostPosted: 22:16 - 21 Mar 2013    Post subject: Reply with quote
YBR Ric.
Thanks for the pic. It's just for reference should i need it.
Mines runs just fine in the cold this year.
Alpha-9
PostPosted: 22:21 - 21 Mar 2013    Post subject: Reply with quote
Err, it's autochoke if it's 2011, otherwise something weird is going on with that bike
I didn't know you could set it's idle at all! Always baffled me
Fzr-600 1999
pmidd
PostPosted: 22:22 - 21 Mar 2013    Post subject: Reply with quote
Boris, if yours is 2008 what the hell have i been told to lift as the choke that increases the revs??
YBR Ric
PostPosted: 22:32 - 21 Mar 2013    Post subject: Reply with quote
Mines running fine but I had my first problem a few days ago - ran out of fuel after 350 miles - because of the cold it runs much richer for much longer- fortunately lowering the bike onto the footrest released 1/2 a liter or so of fuel from the dead zone in the tank and this allowed me to carry on to the petrol station where I purchased 13.5 liters of gogo juice at a cost of 19.01 !!!!
YBR Ric
PostPosted: 23:06 - 21 Mar 2013    Post subject: Reply with quote
Alpha-9 wrote:
....I didn't know you could set it's idle at all! Always baffled me
On the EFI YBR's this small brass screw affects the mixture.
Running a faster idle (1500rpm) gives a richer mixture and better performance.
Running a lower idle (1300rpm) weakens it and improves economy.
Run it too weak(slow) and you risk both electrical and mechanical damage.
The brass screw is the only thing you should ever touch to adjust the idle.
Under no circumstances should you ever be tempted to disturb the screw and lock nut (throttle stop) to alter the idle speed.
This is set at the factory, if you even think about touching it a ninja will be sent round to administer a suitable punishment Shocked
pmidd
PostPosted: 23:25 - 21 Mar 2013    Post subject: Reply with quote
pmidd
PostPosted: 17:46 - 22 Mar 2013    Post subject: Reply with quote
Hi, Here is the photo of the choke, anyone recognize this ??
https://i46.tinypic.com/vhcfmh.jpg
Alpha-9
PostPosted: 18:06 - 22 Mar 2013    Post subject: Reply with quote
Been converted to carb? Shocked
i'd be checking my engine numbers as all ybrs are fuel injection past 2007 Laughing
Fzr-600 1999
pmidd
PostPosted: 18:16 - 22 Mar 2013    Post subject: Reply with quote
Starting to think i have bought a pig in a poke !
Where would i cross reference the engine number?
Alpha-9
PostPosted: 18:18 - 22 Mar 2013    Post subject: Reply with quote
V5 by what is printed on the engine
Fzr-600 1999
pmidd
PostPosted: 18:30 - 22 Mar 2013    Post subject: Reply with quote
Hi,Vin/chassis/frame number match V5 ! Last 4 numbers are 2007 please tell me this is not the year of manufacture as it is registered 2011 on a 61 plate !!!
Alpha-9
PostPosted: 18:33 - 22 Mar 2013    Post subject: Reply with quote
https://www.gov.uk/get-vehicle-information-from-dvla
"Vehicle enquiry"
Fzr-600 1999
Boris the spider
PostPosted: 18:42 - 22 Mar 2013    Post subject: Reply with quote
It looks very much like it.
pmidd
PostPosted: 18:44 - 22 Mar 2013    Post subject: Reply with quote
Hi,Just checked and it was manufactured in 2007 and registered 2011 Sad So not a lot i can do about that !!!
So back to my original question, how do i adjust the idle/tick over ??
Thanks for your help !!
Paul.
The last post was made 13 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 124.15 Kb
