Falco |
Falco Traffic Copper
Posted: 01:24 - 13 Jan 2017 Post subject: |
Removed the carbs. Jesus christ what a faff! I know it's always slower when doing something for the first time but 3+ hours? Starting with the tank off? And why is there no damn room to get at anything inside the frame? How I long for a garage with a light (and maybe even some heat).
Found 4 of the 8 screws holding the float bowls on were seized so had to cut a slot in the top and get a long screwdriver on them. Fucked if I'm going to replace the screws at this point, they still work and they will get proper replacements when I am marginally less irate at the bike and when it can prove it deserves them (by surviving the petrol polluted oil trip)
Tomorrow is an oil change (and filter if it arrives and if it stops snowing... ) and cleaning the float bowls after having a quick look without gloves today, but with no way to start the bike (new float needles aren't due till Monday) means I'll be stuck with free time and no way to tell if the bike has been fixed. |
M.C |
M.C Super Spammer
smallfrowne |
smallfrowne Scooby Slapper
Petemate |
Petemate Trackday Trickster
Pigeon |
Pigeon World Chat Champion
ThatDippyTwat |
Dave70 |
Dave70 World Chat Champion
Groove |
Groove World Chat Champion
Posted: 22:17 - 15 Jan 2017 Post subject: |
I thought about the 2 in the garage and then thought I like the idea of a mt-10 in replace of them both
thing is the triumph has pretty much sat in the garage since buying it in November. I havnt even had the plastics back from being repainted.
I may have a problem. ____________________ || Past: 1991 Kawasaki ZXR 250 ~ 2003 Honda CBR 600 F Sport ~ 2004 Kawasaki ZX6R B1H 636 ~ 1999 Yamaha R1 ~ 1999 Kawasaki ZX6R J ~ 2004 Kawasaki ZX6R B1H 636 ~ 1998 Honda VTR1000F Firestorm ~ K1 GSXR 600 Track bike ~ K6 GSXR 1000 ~ 2006 Speed Triple 1050 || Current: 2005 R1 https://www.adrucore.co.uk |
KTMTony |
KTMTony Nova Slayer
Falco |
Posted: 02:42 - 16 Jan 2017 Post subject: |
Yesterday:
Drained oil and changed filter. Shortened fuel pipes and hooked it up to make sure I hadn't messed up the carbs to much. Finally started, so I suppose I haven't killed it entirely
Today:
Drained Fuel and removed tank (again), drained coolant, removed the 50 odd pipes, tubes, cables ect that run across the top of the engine and removed the valve cover.
Set valve clearances - had a total nightmare to access the lock nuts and had to remove the oil lines (dropping the securing screw into the engine on one occasion - thank christ of the extendable magnet stick) with the exhaust valve end on cylinder 1 needing pulled out totally before it would re-seat properly, so I know where I am going if I end up with an oil leak!.
Clearances were waaay too tight, not sure what but I couldn't even get the feeler below the mid-range one into the gap .
Spent 30+ minutes trying to dislodge several small stones that had fallen into the spark plug recess and that I knew with certainty will fall into the engine when I change the plugs next week.
Cleaned (sort of) the coolant tube bits that go through the rocker cover.
The end is in sight! Reattach throttle+choke cables, flush and fill with new coolant, fit new fuel lines to tank, top up oil, run to check for leaks, refresh oil and then maybe I can ride the damn thing!
What I wouldn't give for a garage or even a tarp to work under when it is raining. |
haroman666 |
haroman666 World Chat Champion
Posted: 02:35 - 17 Jan 2017 Post subject: |
Bummer to hear Mr Pidge.
I did notice vague wisps of blue smoke on start up when we did Lille. But I figured it may have just been a bit of settled oil residue in the cylinder.
Make sure you have a good look at the cylinder wall when the head's off!
(P.S. Hope you're well! 'Sbeen a while.) ____________________ The mistresses: 2000 Honda CBR600f, 2000 Honda VTR1000 |
..... Quote Me Happy
Pigeon |
Posted: 23:49 - 17 Jan 2017 Post subject: |
Thanks guys. Am probably deluded, but I believe the SV will live. It's the Top Gear HiLux of BCF
Need to fix my Striple first (in bits due to electrical issues).
Currently commuting on XR250R with knobblies and quite short gearing.
Cornering, accelerating and braking are a non-optional extra.
On the plus side, I can now straightline ALL roundabouts and go WOT over speed bumps.
M.C |
M.C Super Spammer
Beehive Bedlam |
Posted: 10:52 - 18 Jan 2017 Post subject: |
My Scottoiler isn't working in had no time to fix it so I had to oil the beasts chain manually 5am this morning.
https://i.imgur.com/dKwAwjf.jpg |
Beehive Bedlam |
kramdra |
kramdra World Chat Champion
NJD |
NJD World Chat Champion
Azoth |
Azoth Brolly Dolly
Beehive Bedlam |
M.C |
M.C Super Spammer
Posted: 00:11 - 19 Jan 2017 Post subject: |
Christ, I'm only on my second can of chain lube in my biking 'career'. I know you're hardcore and northern, but used engine oil's carcinogenic, just so you know |
Beehive Bedlam |
Pigeon |
Posted: 00:34 - 19 Jan 2017 Post subject: |
Tawny wrote: | Sorry about your bike. I think it's kaput.
Just out of interest, what servicing did you have done on the bike? Did you have the big one at 30-35K? |
Thanks Tawny.
Am not aware of a big one at 30-35k.
I bought the bike at 38k in March 2014 and checked the valves which were on the limit, so re-shimmed them. Replaced the air-filter, oil filter, plugs, coolant, battery and reg/rec that was buggered. Replaced the brake lines with braided ones and resprung it front/rear last year.
Oil change every 3k miles and filter change every 6k
Went bang at 51k
I did however overfill it with oil over the summer to the tune of about 250ml.
But to be honest, the engine has sounded like a bag of nails since day1
https://www.youtube.com/watch?v=cngv0X2VRz4
I was just eager to buy the cheapest hack that was close to me as switching between 10bhp commuter during the week and 100bhp at weekends was giving me the hump at that time. So the SV was to replace my commuter.
She had 9 owners before me, a fair bit of corrosion and things which were wrong + signs of being unloved. I should have walked away and bought something else, but don't regret it.
Cost me £450 on top of what I got for my Chinese 125 and that was 13k miles ago. Not terrible, but am hoping there is life left.
Going to check the inside of the rad for anything. Will remove the plugs and see what they look like. Then try turning the engine over by hand just to see if it feels any different.
If it does, then the heads are coming off and go from there. If it does turn over by hand ok, then I'll take the carbs off and give them a damn good clean then see if she starts.... |
Kickstart |
Kickstart The Oracle
Tamsin |
Tamsin World Chat Champion
The last post was made 7 years, 96 days ago. Instead of replying here, would creating a new thread be more useful? |
