What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 275, 276, 277 ... 407, 408, 409  Next
Quote Me Happy
PostPosted: 18:03 - 11 Sep 2017    Post subject: Reply with quote
Changed the air filter for the first time in 30k miles, obligatory old/new filter pic below.
https://i.imgur.com/dua11np.jpg?1
It's a job I've been putting off as the official Kawasaki method involves dismantling half the bike but in fact can be done in about 30 mins.
PostPosted: 21:33 - 11 Sep 2017    Post subject: Reply with quote
Not directly to the bike, but put up another set of shelves in the garage to store parts on. I can now get at the bottom of a stack of crates without having to move the rest first. I have 2 more sets to put up, although not sure where one will go, and I need to move the compressor to make space for the other set
Katy
TheSmiler
PostPosted: 15:19 - 12 Sep 2017    Post subject: Reply with quote
Added a mascot to the bike.
https://i.imgur.com/kCkSOWL.jpg
Tracer1234
PostPosted: 16:47 - 12 Sep 2017    Post subject: Reply with quote
Those indicators though. Shocked
stonesie
PostPosted: 17:14 - 12 Sep 2017    Post subject: Reply with quote
Removed the top box rack and waxed it after it's wash and ACF-50 yesterday. Thumbs Up
TheSmiler
PostPosted: 21:45 - 12 Sep 2017    Post subject: Reply with quote
Had to put the old ones in after the visot to the bbq. The lenses looked like slmeone had taken a lighter to them.
Hawkeye1250FA
PostPosted: 22:18 - 12 Sep 2017    Post subject: Reply with quote
New tyres front and back on 1250
Front tyre went flat overnight
Took bandit to work that day instead as couldn't be arsed to duck about with the tyre.
Battery died 5 miles in
Limped home using the portable battery jump pack linked directly to the battery
Took the car 😞
On the return journey car picked up a screw in the sidewall
Swapped batteries and took the bandit
Realized bandit had no MOT
Took bandit for MOT 2 days ago - failed on suspension bushes
Replaced suspension bushes
Passed MOT
Sorted tyre on 1250
Put space saver on car
Vowed that next bike isn't going to be a Suzuki.
thx1138
PostPosted: 23:05 - 12 Sep 2017    Post subject: Reply with quote
exchanged my friends GPZ500S that I was borrowing, for my CRF250L
sad to see GPZ go, but felt a genuine gladness at seeing my little red Honda again Embarassed
offered up a disclock on Honda, fits, never used them before borrowed Kawasaki, but will buy some
Then double up the tie downs and bungies on all of the motorcycle covers, cos theres-a-storm-a-coming Confused or, it's going to be a bit windy anyway
Hong Kong Phooey
PostPosted: 23:16 - 13 Sep 2017    Post subject: Reply with quote
Debaffled. Might put back in, less torque lower down.
Wheezybiker
PostPosted: 10:04 - 14 Sep 2017    Post subject: Reply with quote
Follow up post from getting new tyres 25th Aug Michelin pr4 front and rear
Got the the 30quid reward back into my bank for buying 2 tyres happy bunny there
Approx 3 tanks of petrol paid for by Michelin
Also bike has just got better and better as tyres have scrubbed in a bit
So very pleased with my tyre choice and would recommend them
Usual caveats apply in that I am no expert on tyres or bikes
ThatDippyTwat
PostPosted: 20:09 - 14 Sep 2017    Post subject: Reply with quote
Managed to remove carb.
Someone has decided not to replace the seal on the inlet manifold, and use instant gasket. Carb had loads of shit and the usual fluff coating the float bowl. Pulled jets, main was part clogged with instant gasket.
Hopefully snag a replacement seal tomorrow as anything in my box of seals/o-rings are too small.
Tracer1234
PostPosted: 23:39 - 15 Sep 2017    Post subject: Reply with quote
Fitted the panniers, Tried then out on the road and made the the lid fits. All is good.
https://s20.postimg.org/51hzrbfil/Drawing_2.jpg
https://s20.postimg.org/n5l0byd71/IMG_20170915_145319.jpg
mrtisme
PostPosted: 14:36 - 16 Sep 2017    Post subject: Reply with quote
Sold it. Smile but Crying or Very sad if you know what I mean.
sickpup
Old Timer
PostPosted: 15:10 - 16 Sep 2017    Post subject: Reply with quote
Fitted a new rear tyre to the 700 Deauville. Stripped various parts of the swingarm, cleaned them up with a flapper disc, greased and reassembled.
Free'd up the centre stand so it now retracts freely.
ThatDippyTwat
PostPosted: 20:32 - 16 Sep 2017    Post subject: Reply with quote
Cleaned inlet manifold off. It was bad. Couldn't snag a seal, so Instant Gasket was used until a new one arrives.
https://i.imgur.com/ohpA56bl.jpg
Managed to get one of the last 2 seized screws out. Utter bollock to move, was rocking the bike with the amount of force needed to get it out. Last one will need to be cut off I suspect. Replaced with stainless bolt, as were other corroded fasteners I encountered. This meant I could now get at the airbox, and the filter was surprisingly clean, almost no oil on it.
Cleaned carb, but discovered why I had been smelling petrol - float bowl seal is toast and had been weeping. Can't find a seal because I don't know the carb model, the lettering stamped on gives me nothing. A new carb is only £25, apparently a Lexmoto uses the same one, so that's ordered, Did try to run her, but she just revved up on, despite slackening off the throttle cable. Not sure what's going on, but will check the cabling to the slide, I was iffy about the fitting of it when it went back together.
Ordered tyres - very little choice in the stupid rear size.
Applied yet more rust inhibitor.
Fisty
PostPosted: 00:53 - 17 Sep 2017    Post subject: Reply with quote
Did an indicated 190mph on it.
I need to crack the double ton.
Speed is addictive.
Fatter and faster than Fret
Howling Terror
PostPosted: 11:01 - 17 Sep 2017    Post subject: Reply with quote
^^^It's like looking through a keyhole at that velocity....Well for me at 150 it is.
Musketeer
PostPosted: 12:38 - 17 Sep 2017    Post subject: Reply with quote
Last ride and early end of the season Crying or Very sad Thumbs Down
Inevitable happened. The alternator in my Fireblade is dead.
I thought maybe previous owner replaced it (I think this part was recalled and replaced under warranty), because I've had no problem with it since I bought the bike. But no.. As long as the bike was running it was all fine, once I stopped the engine and tried to start it again, there was nothing left in MotoBatt battery fitted. I'm charging the battery now, but there is a chance it's fked now too.
thx1138
PostPosted: 16:38 - 17 Sep 2017    Post subject: Reply with quote
thx1138 wrote:
handed over £100 for the Zontes that has been knocking around my garden for a few weeks as mentioned in my sig. Shocked
and SORN'd said Zontes.
Me and some mates will attempt to get this back on the road with a minimum amount of cash being spent on it. Laughing
We sold it for £600 today.
PostPosted: 17:12 - 17 Sep 2017    Post subject: Reply with quote
Fettled a new mounting bracket for the Enfield's reg/rec to replace the one that cracked on the run today. Apparently it's very common.
RhynoCZ
PostPosted: 18:22 - 17 Sep 2017    Post subject: Reply with quote
Well, today I wiped a puddle of gearbox oil from under the MZ. There are more leaks than I thought. I re-sealed the gearbox output shaft recently and I thought I was done with it, as I could actually see the oil leaking through there.
Fisty
PostPosted: 18:48 - 17 Sep 2017    Post subject: Reply with quote
It was like a computer game, everything in my peripheral vision was a blur, like looking down a tunnel.
172 was my previous best, this didnt feel faster untill I came to slow down.
Not today but yesterday.....
Serviced it, fitted K&N air filter then took It to JHS racing in Bristol who did a remap of the power commander and set up the suspension for me.
Just need a new rear tyre now.
Fuck me sideways it's a different bike. £220 well spent.
thx1138
PostPosted: 18:50 - 17 Sep 2017    Post subject: Reply with quote
I haven't done warp speed for some years now, touched 95 the other day and backed off cos brain couldn't process Embarassed
ThatDippyTwat
PostPosted: 20:13 - 17 Sep 2017    Post subject: Reply with quote
Pulled tank, applied more rust converter (See a theme here?), checked 1-2 throttle cable, re-seated and re-routed that, made sure bodged seal works... it doesn't. Revs like crazy on start, can get it to drop to normal by playing with the choke. Won't rev at all though, so I'm suspecting the inlet manifold seal isn't sealing.
Proper seals located and ordered.
kramdra
PostPosted: 02:53 - 18 Sep 2017    Post subject: Reply with quote
Front wheel bearings
The last post was made 6 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 276 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.73 - MySQL Queries: 17 - Page Size: 139.07 Kb
