What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 281, 282, 283 ... 407, 408, 409  Next
Howling Terror
PostPosted: 17:01 - 29 Oct 2017    Post subject: Reply with quote
Made a start on the duke. Was in two minds whether to get the wheels painted...decided to carry out 1 last 'touch-up' bodge job.
Making a start on the wheel bearings (y'know I jet washed that paving 4 months ago FFS!).
https://i.imgur.com/a4w8EX2.jpg
I remembered this bolt from last time.
https://i.imgur.com/gfVSz8Y.jpg
So that's new bolts all round then.
https://i.imgur.com/qehOSAN.jpg
Thankyou Brembo for providing a clouting-it-out notch.
https://i.imgur.com/PXBUyar.jpg
The offending bearing.
https://i.imgur.com/uruBtBW.jpg
Lightweight alloy spacer.
https://i.imgur.com/MMVdVOW.jpg
Should add 5mph. Mr. Green
https://i.imgur.com/WXJ0TGK.jpg
Heat to get them in and out.
https://i.imgur.com/8ol1vIN.jpg
Sexy spacer ...(almost forgot to put it back).
https://i.imgur.com/ZY2BNPM.jpg
Yeah I'll admit it...This pic gives me a twinge.
https://i.imgur.com/1YgOApD.jpg
Waiting for bolts is bobbins...so cleaned them.
https://i.imgur.com/MOpsPfs.jpg?1
Only 2hrs daylight left so going out on the other bike for a play.
ThatDippyTwat
PostPosted: 17:25 - 29 Oct 2017    Post subject: Reply with quote
Removed rear tyre so I can sand down flaky paint on rim causing a slow leak. Caused yet more leaks. Removed again, sanded some more. Even more leaks. Tyre goop it is. Slime on order, Tyreweld will have do for a day or two.
Courier265
PostPosted: 23:21 - 30 Oct 2017    Post subject: Reply with quote
Beadseal would of done the job...
Islander
PostPosted: 00:58 - 31 Oct 2017    Post subject: Reply with quote
Wet & Forget for that paving. Thumbs Up
Islander
PostPosted: 01:00 - 31 Oct 2017    Post subject: Reply with quote
Removed the annoyingly hard to see LED indicators from the Bandit 1200. Fitted a nice new set of bulb indicators. Thumbs Up
M.C
PostPosted: 02:08 - 31 Oct 2017    Post subject: Reply with quote
A job I've been putting off; replacing the seat lock. Had a bit of a job getting the old one off, I dunno why Triumph make it so difficult, you can pop the seat off in seconds with very little force Rolling Eyes
ThatDippyTwat
PostPosted: 07:02 - 31 Oct 2017    Post subject: Reply with quote
I'd rather remove the cause of the problem if I can. The Rim is beyond sanding and needs blasting, which is fine, I can do that in work, but I need the bike to get to work...
CBFcarl
PostPosted: 13:41 - 31 Oct 2017    Post subject: Reply with quote
Passed the 28k mark on the odometer. Might treat her to some Shell fancy petrol on the next fill up.
*edit* - casually dropping 1k off the mileage. Like that bike place in peterborough Wink
thx1138 wrote: Well if you had a car, I'd bet it would smell like urine had had drunken sex with vomit and made a poo baby.
Polarbear wrote: They are all old now. Probably had more abuse that a Rotherham schoolgirl.
Hellkat wrote: I want to know if Nigella smells of garlic, or just minge.
Matt B
PostPosted: 14:04 - 31 Oct 2017    Post subject: Reply with quote
Got rid of the brick sized indicators and fitted some mini ones. reduced drag factor must be good for +eleventy mph.
https://i.imgur.com/nHrUs3h.jpg
I think, for it's age, they got the styling of the 929 pretty well spot on. How the hell did they come up with those monstrous standard indicators and think they looked good on the bike?
What amazes me more is that it's lasted 17 years before anybody has changed them!
pompousporcup...
PostPosted: 00:26 - 01 Nov 2017    Post subject: Reply with quote
Started on the thundercats prewinter service. Took the Fuel tank off, turned the tap off and set it aside.
10 minutes later the tank was empty and my carpet was saturated.
Bugger.
secretagentmo...
PostPosted: 17:32 - 01 Nov 2017    Post subject: Reply with quote
New front brake pistons, seals and pads.
M.C
PostPosted: 18:31 - 01 Nov 2017    Post subject: Reply with quote
Another job I've been putting off, changing the fuel tank lock. It went fine until I realised some of the holes were arranged differently, resulting in:
https://i62.servimg.com/u/f62/15/13/82/47/tank10.jpg
Evil or Very Mad Gonna see if I can find another bolt to cut down. Also when putting the battery tray back I found two loose gromits and I can't for the life of me workout where they came from Laughing
Howling Terror
PostPosted: 18:40 - 01 Nov 2017    Post subject: Reply with quote
^^^Chafing wires in 3-2-1. Razz
trevor saxe-coburg-gotha
PostPosted: 19:04 - 01 Nov 2017    Post subject: Reply with quote
electrical fire and igniting fuel line ball of fire on M25 in 3 - 2 - WHUMPFFF!!!
Howling Terror
PostPosted: 19:06 - 01 Nov 2017    Post subject: Reply with quote
but no before the battery explodes showering crotch in acid.
pompousporcup...
PostPosted: 10:44 - 02 Nov 2017    Post subject: Reply with quote
Dragged the petrol soaked carpet out of the garage as it wasn't evaporating and replaced it with some of those Sealey lock together mats from Halfords.. temp solution but better than the fire risk carpet.
The petrol had soaked through and started to eat away the paint on the garage floor Evil or Very Mad Evil or Very Mad Stupid issue to have but an issue nonetheless. Tap repair kit has been ordered but will take a few days to arrive. Its an on/off tap so it doesn't matter too much right now
Added Oxford heated grips, a K&N filter and a new fuel filter to the Thundercat.
Tonight will see the rear wheel bearings being replaced as the rear wheel stops randomly when i spin it even with the caliper off Thumbs Up
Because the daily is out of action i had to take the Gpz Cool
Two formally worlds fastest heavy weights Cool
https://s19.postimg.org/a3rd2w5zn/IMAG4158.jpg
secretagentmo...
PostPosted: 11:42 - 02 Nov 2017    Post subject: Reply with quote
Standard Honda ones as used on the Dulville, NTV650 et al and a lazy designer????
kramdra
PostPosted: 20:16 - 02 Nov 2017    Post subject: Reply with quote
Mot done and passed. 13.5k miles last year, upto 89500. Only work done I rotated the front pads to even the wear on leading edge.. And a bodge to quieten the leaky exhaust. Few minor advisorys that will never be fixed, nothing unknown. Very Happy
The sod cleaned the plate but not rest of bike Mad
pompousporcup...
PostPosted: 11:53 - 03 Nov 2017    Post subject: Reply with quote
Need to buy my guardian angel a case of beer.
Continued the Thundercats pre-winter going over last night by removing the rear wheel to change the bearings. Keep in mind that the rear wheel span freely up until Monday/Tuesday night when i noticed it wouldn't spin a full revolution without stopping.
I genuinely check my wheels every day.. tyres mostly but i give the wheel a shake to check for play. There was no weird noises or anything like that to hint at an issue.
What a bearing should look like.
https://s19.postimg.org/i2iuvfwtf/IMAG4177.jpg
What mine looked like.
https://s19.postimg.org/jhkfk65mb/IMAG4163.jpg
https://s19.postimg.org/p5qqb2x43/IMAG4159.jpg
https://s19.postimg.org/5nw2v4sgj/IMAG4168.jpg
https://s19.postimg.org/xo06feo77/IMAG4172.jpg
It has started eating into the wheel face. There were bits of metal in and underneath the cush rubbers... I didn't use any force at all to remove the bearing... The metal covers you see are how they fell out, all mangled. The sprocket carrier spacer was all that was keeping the ball bearings in the outer cage..
ThatDippyTwat
PostPosted: 18:38 - 03 Nov 2017    Post subject: Reply with quote
No pics of bearing gore showing up for me.
Figure out the Reg/Rec was toast.
After I fixed (bodged) the also toast connection.
https://i.imgur.com/46xq4Okl.jpg?1
https://i.imgur.com/hVjUsswl.jpg
There's something fucky with the rear light. Normal illumination is fine, but brakes no longer illuminate the 2nd filament. New bulb didn't cure it.
Howling Terror
PostPosted: 15:44 - 05 Nov 2017    Post subject: Reply with quote
Brakes and more bearings today.
Cleaning kit; Paraffin, hot water and some mucoff.
https://i.imgur.com/gSMenlI.jpg
Plenty left.
https://i.imgur.com/wf5L0gV.jpg
Original pistons and seals (17yrs) Brembo make exceedingly good brakes.
https://i.imgur.com/gnqGU65.jpg
About as clean as I can get without a complete stripdown.
https://i.imgur.com/5vsZbkV.jpg
I'll be passing on the pot of copper grease to my yet unborn grandchildren.
https://i.imgur.com/HXNNtEt.jpg?1
Well doesn't that look lovely. Neutral
https://i.imgur.com/DQRN5x8.jpg
Ad break.
Bloody adverts. Rolling Eyes
The rear wheel bearings were uneventful.
On to the sprocket...which either chrome or imgur scales incorrectly.
https://i.imgur.com/caegj5r.jpg
https://i.imgur.com/OTUCntV.jpg
Knock 'em in.
https://i.imgur.com/IIrCMHw.jpg
Circlip in and time for a brew. i.e splurge photos all over BCF.
https://i.imgur.com/zFUX0zA.jpg
So...question is do I clean and paint (bodge) the rear wheel..clean the brakes and reassemble then bleed the front/rear/clutch.....[shudders]
No...It'll keep for another day. The sun is out so tools away and quick spin on the MV. Thumbs Up
chickenstrip
PostPosted: 16:37 - 05 Nov 2017    Post subject: Reply with quote
...which seems to have taken a bit of abuse at one end? Presumably not a problem?
M.C
PostPosted: 18:47 - 05 Nov 2017    Post subject: Reply with quote
I once overflowed a petrol can draining the bike at work, in my panic I pulled it out the container first then the bike Rolling Eyes Embarassed
Anyhoo there was a sticky patch there for ages until they eventually put something over it.
Hope not Shifty
Hawkeye1250FA
PostPosted: 18:48 - 05 Nov 2017    Post subject: Reply with quote
Bit of a cheat clean
Rinse dirt off
Spray with wonder wheels type cleaning stuff
Agitate stubborn bits
Have a fag
Rinse off
Actually looks better than I expected considering took 10 minutes
Also ACF50'ed everywhere. (And ran it for 15 minutes to burn off the excess to stop the "Is your bike on fire?" questions at lights on my commute tomorrow. )
M.C
PostPosted: 18:54 - 05 Nov 2017    Post subject: Reply with quote
Getting high off the fumes' half the fun Neutral
The last post was made 6 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 282 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.34 - MySQL Queries: 17 - Page Size: 145.95 Kb
