What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 283, 284, 285 ... 407, 408, 409  Next
thx1138
PostPosted: 18:43 - 14 Nov 2017    Post subject: Reply with quote
Crashed it. Laughing
https://s20.postimg.org/ikymxhe4d/WP_20171114_14_32_44_Pro.jpg[img]
https://s20.postimg.org/q0xwj9u3x/WP_20171114_14_32_23_Pro.jpg
https://s20.postimg.org/fe43dvw99/WP_20171114_14_33_47_Pro.jpg
https://s20.postimg.org/b4zdboazh/WP_20171114_17_28_50_Pro.jpg
M.C
PostPosted: 18:48 - 14 Nov 2017    Post subject: Reply with quote
You don't like number plates do you Razz
thx1138
PostPosted: 18:53 - 14 Nov 2017    Post subject: Reply with quote
ironcially I ordered two the other day, and they got delivered when I was out Laughing
Petemate
PostPosted: 19:34 - 14 Nov 2017    Post subject: Reply with quote
Managed to get the old tacho drive gear out of the casing. Initially thought I'd have to make up an extractor screw, but not needed. Cut the gear in two, pulled the two halves out then popped the spade end back in and gave it a tap with a small hammer and out popped the seal and thrust washer.
Now just waiting for the new gear but tomorrow I will take the oil pump off and clean the filter screen, also poke around in the bottom of the crankcase with a magnet to check that there are no gear teeth bits in there.
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
BLB_Rich
PostPosted: 10:45 - 15 Nov 2017    Post subject: Reply with quote
Had new Bridgestone T30 Evo's fitted!
Rear was squaring rapidly & front felt rough (jittery & slow to turn/lean & a effort to cross white lines/cats eyes). Plus they were old.
Cadbury
PostPosted: 13:30 - 15 Nov 2017    Post subject: Reply with quote
To my NC - Fitted a fender extender & rear hugger in prep for winter, and (reluctantly) my big Givi top box, because storage.
NC700x.
thx1138
PostPosted: 17:13 - 15 Nov 2017    Post subject: Reply with quote
started prepping my Honda CRF250L which is more road focused these days, for a trail ride I'm leading on Sat as my Beta is out of action
Removing mirrors, sorting out tools, and finding spares to take, and re-attaching Kriega packs and haul loops, etc
Petemate
PostPosted: 19:02 - 15 Nov 2017    Post subject: Reply with quote
Removed the oil pump, stripped and checked it, no damage or excess wear. The mesh screen was a bit mucky, and did a good job of holding back the tiny slivers of the tacho gear teeth.
Just waiting for the gear to arrive, should be back on the road by the weekend.
Petemate
PostPosted: 20:58 - 16 Nov 2017    Post subject: Reply with quote
Tacho gear arrived this morning, bike now back on the road.
Falco
PostPosted: 18:19 - 18 Nov 2017    Post subject: Reply with quote
Fitted Oxford heated grips (straight to battery, relay to be added at later date). Weirdly it was the non-throttle side that was really tight. Seemed a bit weedy but I only gave them a couple of minutes, then got paranoid about draining battery.
Monday will be the true test
I look forward to having marginally smaller blocks of ice for hands when I arrive.
Also lost the end for the tyre pressure gauge Evil or Very Mad
I tell you what, mathematically, I'm having it
ThatDippyTwat
PostPosted: 20:44 - 18 Nov 2017    Post subject: Reply with quote
Re-Bodged exhaust, but as the hole is at right up against the falnge/collar it's probably going to blow out again fairly soon.
thx1138
PostPosted: 15:10 - 19 Nov 2017    Post subject: Reply with quote
Jet washed Honda, a special extra sticky kinda clay mud yesterday and it took over 7inutes.
I then cleaned chain and lubricated, and made a bit of a hash of adjusting the chain. Phoned a friend. Did not help that last time I had wheel off I put guide spacer in backwards, and that adjustment bolts were seized got shown how to do it properly, and cleaned spacers. We had to take wheel off and use a socket set to free them. :-/
Serendipity
PostPosted: 15:33 - 19 Nov 2017    Post subject: Reply with quote
Dented my tank!
My 5 year old muffs were wearing out. My hands had gradually worn away some of the rubber sleeves that go over the bar ends and they would come loose on the motorway. So I purchased some new Tucano Urbano R363-X muffs because they could be screwed to the bar ends and went about fitting them.
Turns out that with a washer, the rubber end cap and a little spacer I made up to stop the rubber sleeve fouling the throttle, the bar end weight screw was too short. I need to find something longer and there was nothing appropriate in my tub of bolts.
So I decided to go down the path of using the supplied zip ties to clamp the rubber sleeves around the bar end weights on both sides. I’d already removed the bar end weights and they were jammed into the rubber sleeves of the muffs. I just needed to pop them out and reattach them to the bike before trying the zip ties.
So I stood facing my bike, holding one of the muffs and carefully squeezed the rubber sleeve to pop the loose end weight out. Well it came out like a bullet, nearly got a hand to it as it flew through the air. Could’ve hit the seat, or a foot peg, or even a bit of tough old plastic, but no, of course it had to spank off the tank leaving a neat little dent……. Bollocks!
Center of the picture, just at the top of the reflection of the tree….
https://i.imgur.com/S26nI6ih.jpg
Meh! Put it down to the scars of a London commuter. It’s hardly immaculate anymore and with the excessive mileage it’s not exactly going to affect the value… … because there is none. Laughing
2007 CBF1000-ABS - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
Howling Terror
PostPosted: 16:59 - 19 Nov 2017    Post subject: Reply with quote
^^^Dented my thumb!
Back to the ST2....
New bolts going in nicely.
https://i.imgur.com/rtHy3TA.jpg
Hmm...may just give that bearing a final tap home. Doh!
https://i.imgur.com/1xKsNOR.jpg
1st aid kit was improvised.
https://i.imgur.com/0nP9Kl9.jpg
https://i.imgur.com/vASrh5u.jpg
Cut away from the body.
https://i.imgur.com/pWP67N5.jpg
Devil's in the detail.
https://i.imgur.com/MEZOr3U.jpg
Replace lost fluids
https://i.imgur.com/UVK0ECR.jpg
Dirty little caliper.
https://i.imgur.com/HD7akaB.jpg
Pin cleaning.
https://i.imgur.com/qnxao2i.jpg
Dirty back end.
https://i.imgur.com/bPqCjZD.jpg
Needs hammerite again.
https://i.imgur.com/SrCAxc2.jpg
More to do but got the wheel back in.
https://i.imgur.com/SbbdjCJ.jpg
Falco
PostPosted: 20:01 - 19 Nov 2017    Post subject: Reply with quote
Cleaned and lubed chain (takes forever now the weather has turned, making sure each roller is turning freely) - decided life is too short and ordered a chain oiler.
Checking front wheel noticed some binding. Pads off, caliper out, break cleaner, tooth brush and rag around the back of the pistons. Lightly greased piston sides and pushed them back in. Nice free running wheel again Thumbs Up
Tracked down weird intermittent problem with front right indicator. little metal tab on the back wasn't making good contact with the back of the bulb. Nothing a little bending won't solve.
Courier265
PostPosted: 22:08 - 20 Nov 2017    Post subject: Reply with quote
Insured all 3 bikes, £580 TPFT Courier insurance...
Fisty
PostPosted: 22:17 - 20 Nov 2017    Post subject: Reply with quote
Howling Terror wrote:
^^^Dented my thumb!
Man plaster. 11/10
Fatter and faster than Fret
Falco
PostPosted: 23:23 - 20 Nov 2017    Post subject: Reply with quote
rode it with heated grips for the first time....about 100yards down the road. Fuel line got kinked when putting the tank on yesterday Embarassed
Heated grips though! Wub Once the hand guards arrive, winter riding might not be such a chore.
Petemate
PostPosted: 18:00 - 21 Nov 2017    Post subject: Reply with quote
Rotated the gear lever one tiny spline to bring it up slightly. I now have a nice pair of boots to use instead of my old shoes. When returning to biking a few years ago after a 22 year gap, I couldn't find a pair of boots which I could use, due to severe arthritis in my left ankle. I had this when I was last on bikes prior to 1993, but the ankle was then not as huge as it is now and I was able to use boots. Just bagged myself a pair of leather/goretex Oxtars for a tenner from FB Marketplace. They are used but excellent soles and the zips on both boots perfect, also no scuffs etc. The important bit is that they have been well waxed regularly and the ankles are really flexible - just what I needed. However, as I only have limited rotation of my left foot, I needed to get the lever in position where I could get the foot under it. Over the last couple of years back on two wheels I have got used to having to lift the whole lower leg to change up lol. Job's a good 'un.
ADSrox0r
PostPosted: 00:36 - 23 Nov 2017    Post subject: Reply with quote
Stared at the Zed in disbelief after filling it up. You've done what mpg?! Good god I haven't even caned it yet. Pff, I don't have a good relationship with gas mileage.... Rolling Eyes
Snodvan
PostPosted: 21:06 - 23 Nov 2017    Post subject: Reply with quote
Nothing at all on the bike today - or yesterday - or for the last 5 months. And that pattern is set to go on for a month or so until I get all the bits/ spares/ paperwork together and put the bike up for sale.
Lung cancer has struck and there is no way I can now safely ride. Sad, sad, sad but there is no cure for Asbestosis and I can only hope that someone else can in future get as much fun out of riding as I did in the past
Not a common bike but mint condition and trivial mileage. I post an advert when I make the final decision
Snod
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
Hawkeye1250FA
PostPosted: 22:49 - 23 Nov 2017    Post subject: Reply with quote
Fitted cheapo fog lights - actually really happy with them! £9.50! Obvs from China originally - but shipped from brum.
5 day turn around. Result.
Added bonus I didn’t know about.
They come with a completely illegal (yet fun) modulating setting. 😂👍
https://splice.gopro.com/v?id=VLzKge
Dave....
PostPosted: 22:58 - 23 Nov 2017    Post subject: Reply with quote
Bought a TomTom satnav and realised the mounting ram thingy was shite so machined one instead once I found out how much one that would suit costs..
Slow day at the workshop.
Honda Africa Twin
The last post was made 6 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 284 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.51 - MySQL Queries: 17 - Page Size: 137.78 Kb
