What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 289, 290, 291 ... 407, 408, 409  Next
PostPosted: 16:44 - 16 Jan 2018    Post subject: Reply with quote
Irn-Bru wrote:
I rolled the bike forwards and one of the pads ripped clean off
Good job that was a one off which will never happen again.
M.C wrote:
I've only ever seen [spacker blankets] on scootays, I assumed it was to keep your vagina warm.
It keeps your outie from becoming an innie in the cold.
I had one on my Burgman, it was even acer. Tucano do scootay specific models that seal round the bodywork to make a cosy cocoon. You could wear slippers and still be comfy, not that I did, much.
M.C
PostPosted: 16:51 - 16 Jan 2018    Post subject: Reply with quote
See underseat exhausts not only look cool but roast your nads nicely Wub
sickpup
Old Timer
PostPosted: 17:37 - 16 Jan 2018    Post subject: Reply with quote
Fitted a new set of Tucano R321's to the 700 Deauville, rewired a heated jacket and put new power plugs on two more so I have a few spares now.
Ordered some thermal fuses so I can repair a heat controller but need to perfect my circuit board soldering before I do the repair as well as soldering micro switches to a couple of more heat controller circuit boards.
Washed and reproofed various Goretex Textiles that I have picked up cheap 2nd hand over the last few months, £120 for top of the range Proshell suits is always worth it.
PostPosted: 17:41 - 16 Jan 2018    Post subject: Reply with quote
Ah, this did ring a bell. A cash register bell.
Irn-Bru wrote:
ktm [...] one of the pads ripped clean off
That's compo bruv, legit, I ain't even lyin'.
https://www.motorcyclenews.com/news/2017/may/ktm-motorcycle-brake-failure/
Irn-Bru
PostPosted: 00:47 - 17 Jan 2018    Post subject: Reply with quote
Well aware of that, but it was the rear brake for me, the front is in good nick possibly already seized in the past and fixed Laughing
Oldie
PostPosted: 14:48 - 17 Jan 2018    Post subject: Reply with quote
Hoisted mine in the air Very Happy https://s10.postimg.org/8d1z4yih5/IMG_20180117_092409753_HDR.jpg[/url][/img]
Irn-Bru
PostPosted: 19:37 - 17 Jan 2018    Post subject: Reply with quote
Very posh, I've just got the abba lift + wheels and it's excellent, when I have a garage I want one of those skylift things.
Got my bike back from the garage today (in for a major service), excellent service from M&S in Newcastle, they had a winter discount + free pick up and delivery deal on. Cleaned the bike and checked it over, cleaned the brakes and oiled and adjusted the chain. Even got progress pics Laughing
Oldie
PostPosted: 19:26 - 18 Jan 2018    Post subject: Reply with quote
Great caliper pics Thumbs Up
Moxey
PostPosted: 00:36 - 20 Jan 2018    Post subject: Reply with quote
Installed new races in the 750 ready for the new tapered bearings.
https://i.imgur.com/a6ylEV4.jpg
https://i.imgur.com/z1Kyf7O.jpg
Top race is supposed to sit proud, was going to fit the new bronze swing arm bushes but the ID allowed for more play than I found acceptable.
Picked this idea up from members of the sohc forum in lieu of a bearing press, unfortunately one of the 49mm washers I made at work was a little too soft and it distorted a little. "Luckily" my parents washing machine packed in the other week and the bearing cage happened to be the ideal size of 48/49mm (the lower race sits slightly recessed in the headstock tube).
https://i.imgur.com/r0B7P3h.jpg
New/alternative swing arm bushes are in order (otherwise I may modify the swing arm roller or something of the sort).
Current: 02 FZS 1000 Some Bike Pics...
Pigeon
PostPosted: 22:27 - 20 Jan 2018    Post subject: Reply with quote
XR250 - New oil + filter + plug. Adjusted chain and gear lever height.
ThatDippyTwat
PostPosted: 13:37 - 21 Jan 2018    Post subject: Reply with quote
Chain lube & tension.
Removed road shit from rear brake drum and linkage.
Re-wire will have to wait, because I had to do the above in the snow.
M.C
PostPosted: 20:25 - 23 Jan 2018    Post subject: Reply with quote
Bodyguard wrote:
Cleaned the number plate and lights I had the afterburners engaged all the way home today.
https://i.imgur.com/bnRZnr0.jpg
https://i.imgur.com/M600UIC.jpg
Noob. I never clean my plate.
TheSmiler
PostPosted: 00:03 - 24 Jan 2018    Post subject: Reply with quote
Got an old garden feature from a friend, it was damaged. So messing around when a DPD driver comes by he has to wait so I can sign. Start showing him the bike and we came up of using this to carry tweety pie for the local charity run. Needs some work to it strengthening and a base being made plus paint.
https://i.imgur.com/uiMLQkAl.jpg
Skudd
PostPosted: 00:23 - 24 Jan 2018    Post subject: Reply with quote
I took an old tax disc holder off.
thx1138
PostPosted: 16:25 - 25 Jan 2018    Post subject: Reply with quote
Put on Acerbis front fender bag, haven't drilled holes and cable tied, probably will after first outing, want to see how I get on with it, might need to move it nearer to light, don't want to drill holes everywhere.
Bodged Kreiga 5litre dri-pack onto back, rather than four bolts with the restraining straps, traditional cable ties, and extra bodge points for using part of an old dog harness. slip it over back end, then thread it through bag, and use locking clip. Back end is already bodgetastic after smashing it up, so lots of holes for cable ties already, and don't want to drill more holes in back end. Embarassed
https://s20.postimg.org/s9bogbi71/WP_20180125_13_40_43_Pro.jpg
https://s20.postimg.org/yn0rjkust/WP_20180125_13_40_23_Pro.jpg
Tigerlea
PostPosted: 21:22 - 25 Jan 2018    Post subject: Reply with quote
Reinstalled the fully charged battery in the Duc.
https://farm5.staticflickr.com/4658/38998124195_6fe61a3d9b.jpg
https://farm5.staticflickr.com/4753/39897657971_ccd4eb8b8c.jpg
Started up just fine. Finished cleaning it then changed to go for a ride. Started her back up, checked the lights, then was about to leave only for the bike to... not be working any longer.
Will be posting query in the Workshop.. because I'm not entirely sure whyyyy...
waffles
PostPosted: 21:38 - 25 Jan 2018    Post subject: Reply with quote
Started both bikes up, did a small celebratory dance that they both ran (sorry Tigerlea!) and then checked the forecast for the weekend. Looks alright so I might actually go out on one or both!
But not at the same time.
Tigerlea
PostPosted: 22:09 - 25 Jan 2018    Post subject: Reply with quote
You should do both at the same time - I hear it's fun!!
may only be encouraging dangerous activities because of jealousy.. Who knows
Kawasaki Jimbo
PostPosted: 22:16 - 25 Jan 2018    Post subject: Reply with quote
Where there's a will, there's a way.
https://m.youtube.com/watch?v=J2zCHPo8Pdg
bladerunner
PostPosted: 23:23 - 25 Jan 2018    Post subject: Reply with quote
I wheeled my RDLC and the pair of KDX200's out into the garden a week ago to live in the rain...new garage roof time so they can rough it for a while!
WULFSTAN
PostPosted: 09:47 - 27 Jan 2018    Post subject: Reply with quote
I much prefer to see bodyguards used bike than some toy dragged out for picture and then put back away. Bodyguard please keep the lovely pictures coming. Thumbs Up
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
The last post was made 6 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 290 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.74 - MySQL Queries: 17 - Page Size: 140.58 Kb
