What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 308, 309, 310 ... 407, 408, 409  Next
Fisty
PostPosted: 22:24 - 14 May 2018    Post subject: Reply with quote
grr666 wrote:
So I've been tinkering with the brother in law
Oh aye?
Fatter and faster than Fret
grr666
PostPosted: 22:41 - 14 May 2018    Post subject: Reply with quote
I wish I could say I wasn't a deviant. But...
tom_e
PostPosted: 20:03 - 15 May 2018    Post subject: Reply with quote
Lubed some bits and filled my tires with Bike Seal.
ThatDippyTwat
PostPosted: 20:18 - 15 May 2018    Post subject: Reply with quote
I Introduced Mr Stubborn Bolt to Mr Angle Grinder.
Exhaust is now secure, and not hanging on a perished rubber bushing and moving itself loose every day (I hope). I'll sort it properly at the weekend.
bacon
PostPosted: 21:56 - 15 May 2018    Post subject: Reply with quote
Pilot Road 5s fitted to the MT09, my recent spat of 2nd gear power wheelies killed off the stupidly soft Bridgestone S20 rear the previous owner had been running.
I'm shit at wheelies for the record, but it's fun that they are so easy to do with this bike. Once I get used to the front coming up I intend to learn with the clutch instead.
While I had the front and rear wheels off I gave the swingarm a good clean and cleaned out the front and rear calipers, copper greased the back of the pads and the slide pins etc.
Gave it a quick around the block to make sure everything was in order and that I hadn't done anything daft.
Job jobbed Thumbs Up
thx1138
PostPosted: 22:03 - 15 May 2018    Post subject: Reply with quote
got 50ft of garden hose from junk shop, got drill out and put retainer clips from tap in back garden all the way down the side of house wall and hung attached hose to it, put hose lock attachments either end of hose
washed dirt bike in street using onable and offable water spray, beats lugging buckets of water back and forth
can't really use a jet wash out the front, cos it would go all over neighbours cars and houses, but a £2 quick rinse at the petrol station jet wash before a proper clean back at home will do
Fin
PostPosted: 22:35 - 15 May 2018    Post subject: Reply with quote
Replaced the chain, sprockets and rear disc then took it for a little test ride.
Rather shocked how bad the rear brake was, rarely use it much but full on stomping wasn't really doing shit.
Eventually it started gripping and locking up the rear, when I got back all I could smell was brake pads and the paint melting off the edge.
https://i.imgur.com/af1USa6.png
New chain is so much better, there's no knocking or the weird chaffing sound, I don't feel like I'm going to die so soon now.
Islander
PostPosted: 17:38 - 16 May 2018    Post subject: Reply with quote
Put the Monster 750 through its MOT. Straight pass, no advisories Thumbs Up
Moxey
PostPosted: 21:42 - 17 May 2018    Post subject: Reply with quote
Some progress on the 750
Bought some CMA alloy wheels over winter finally knocked the old bearings out and removed the sprocket/discs ready for powder coat tomorrow.
https://i.imgur.com/EwHHmeF.jpg
Had the barrels rebored and the pistons blasted, gapped and fitted new rings (its still original 61mm bore only a thou skim as there was light scouring on the bores).
https://i.imgur.com/EtdGgkF.jpg
https://i.imgur.com/bjMxsRn.jpg
Then fitted bearings to swing arm (suspension and spindle) taped up the roller bearings for the time being.
https://i.imgur.com/LtQ6Np6.jpg
Off to acquire a new stainless grease nipple for it tomorrow then refit to the bike, first bit of progress in a while!
Current: 55 FZS 1000S, 02 FZS 1000, 77 CG 125, 04 XR 125 Some Bike Pics...
ThatDippyTwat
PostPosted: 15:09 - 19 May 2018    Post subject: Reply with quote
Put on replacement rear light to replace the one fucked by spunkbubbles hitting it with a car. Original is fecking mahoosive. Had to crimp up a new 3 pin connector after testing it, as it came with bullets.
https://i.imgur.com/ZYWRSwRl.jpg
This needed to be mounted in a totally different way, so brackets were cobbled together from 1.5mm Alu and painted matt black.
https://i.imgur.com/xgLUPf6l.jpg
Finished product - a bit on the piss, but so is the rest of the bike. Indicators were properly wired in as well.
https://i.imgur.com/QCNZhKrl.jpg
Added a spring to the clutch cable. The stock one had it, replacement didn't. With bedded in clutch plates, it shows.
https://i.imgur.com/2boFYs1l.jpg
recman
PostPosted: 15:11 - 19 May 2018    Post subject: Reply with quote
Removed the seat, tank, bars, air box and top yolk.
Hopefully we'll be able to do a proper repair on the ignition cables tomorrow.
If not, at least I'll be able to drill out the ignition assembly sheer bolts.
https://s9.postimg.cc/ptm7v01ov/20180519_135202.jpg
Doesn't look great but it got me home.
https://s9.postimg.cc/z2oe4mafj/20180519_141116.jpg
Fisty
PostPosted: 17:59 - 19 May 2018    Post subject: Reply with quote
Had a play with the power commander.
The map that was installed was seriously over fuelling the bike. I installed a zero map took it for a spin then a map for yoshis and a filter.
It idles better, no longer chucks out black smoke and seems to pull better.
https://i.imgur.com/jXbTTaN.jpg?1
https://i.imgur.com/AoIBZhr.jpg?1
PostPosted: 19:17 - 19 May 2018    Post subject: Reply with quote
Bash plate removed, oil and filter changed, air filter cleaned and fixed rotten rubber gasket, rev counter fitted, electrics scoped out for sat nav fitting later. Found the spark plug is an NGK BP5ES, am now wondering why it's not a 6.
PostPosted: 21:20 - 19 May 2018    Post subject: Reply with quote
Discovered a whopping great hole in the Enfield end can, bodged it with foil, a pineapple tin, and exhaust wrap, and went for a ride.
Got eyed up by a yummy mummy. I mean, the bike. She'd done 6 months in India on one before getting sprogged up. Well, it makes a change from being buttonholed by older chaps reminiscing about their BSAs and Nortons.
M.C
PostPosted: 21:48 - 19 May 2018    Post subject: Reply with quote
I followed pigeons advice and got a second-hand top yoke off eBay Smile They use them on the seat lock as well which's a PITA, especially when you can easily pop the seat off...
recman
PostPosted: 16:35 - 20 May 2018    Post subject: Reply with quote
Hopefully this'll be the last instalment.
We were able to perform a much better repair today, bit more confidence inspiring.
https://s7.postimg.cc/hokm4889n/20180520_133646.jpg
https://s7.postimg.cc/4kf1rqya3/20180520_134550.jpg
https://s7.postimg.cc/e4yoeqasb/20180520_155356.jpg
Very little flex in the cable from lock to lock now so all should be ok for the foreseeable. Back in the game. Thumbs Up
Oh yeah I might have asked this before, can't remember, does anyone have a clue what this blanked off connection might be used for? Possibly something the R model has that mine doesn't?
https://s7.postimg.cc/p8iajz8tn/20180520_153231.jpg
ThatDippyTwat
PostPosted: 16:59 - 20 May 2018    Post subject: Reply with quote
Changed main jet down (102>100), cleaned everything while in there. Adjusted tension on accelerator pump cable (Y type cable, slide and pump arm). Idle needs dropping, she sits really high when she's got up to temp.
Pissed about with clutch some more.
Still something amiss if it's loaded up in too high a gear, but it's good enough for now, so I caned it round some nice Welsh roads to make a nice change for it.
Irn-Bru
PostPosted: 17:04 - 20 May 2018    Post subject: Reply with quote
DRZ: did the oil and filter, cleaned air filter, new front pads, refit the headlight for upcoming MOT, and replaced one of the LED indicators that was on its way out. Also got new tyres, pilot powers instead of supercorsas that I've used for years.
M.C
PostPosted: 20:13 - 20 May 2018    Post subject: Reply with quote
I think that's for a quickshifter.
Fisty
PostPosted: 15:18 - 22 May 2018    Post subject: Reply with quote
New tyres fitted on the aBusa.
Pilot power 3's from ebay £110 the pair
Fitting to loose wheels £12
That new tyre feeling, priceless.
linuxyeti
PostPosted: 16:29 - 22 May 2018    Post subject: Reply with quote
Fitted the replacement rear luggage rack to the Mash, after I broke the last 1. Not bad, 1/2 the price of a UK supplied one, even before any postage is added to the UK supplied one. And it arrived a week to the day I ordered it
Hawkeye1250FA
PostPosted: 17:42 - 22 May 2018    Post subject: Reply with quote
Just a basic strip and clean if the rear brake. Was very spongey and wouldn’t hold the bike on a slight hill! 😳
15mins work and good as new now.
Best do the front ones next ....
Pigeon
PostPosted: 22:35 - 22 May 2018    Post subject: Reply with quote
I've probably missed the post, but what happened?
Another case of the ignition sheath being too short and working loose over time and the hard plastic edge of the ignition barrel guide slicing through wires?
Or attempted theft?
Or...?
Top repair Thumbs Up
I also used some plastic tubing to wrap the cables in in the hope it adds further protection. That was a year ago I think.
Fisty
PostPosted: 22:43 - 22 May 2018    Post subject: Reply with quote
Shakedown #2- New tyres edition.
Pilot Powers stick like shit to a blanket, the new Power Commander settings are making it pull like a train and use a lot less fuel.
130 mile to 2/3rds of a tank. It did 145 on a full tank last time out.
Also buzzed Fret on a 175mph flyby.
Front suspension needs a gnats more preload and less rebound.
https://i.imgur.com/1St5UIt.jpg?1
New boots fitted and ready to go.
https://i.imgur.com/0jSV4Q1.jpg?1
Tintern at twilight.
https://i.imgur.com/bZs3ced.jpg?1
5mm chicken strip on new tyres
Tdibs
PostPosted: 23:31 - 22 May 2018    Post subject: Reply with quote
Prepping the SV for taking down to the alps and south of france at the end of the week.
https://my.mixtape.moe/dwfvzk.jpg
Valves done
New rear tyre
Full service
Fork oil changed
Installed usb charger
Just a lot of other cleaning and regular maintenance bits on it.
The last post was made 5 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 309 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.42 - MySQL Queries: 17 - Page Size: 137.28 Kb
