What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 309, 310, 311 ... 407, 408, 409  Next
Kris
PostPosted: 10:05 - 23 May 2018    Post subject: Reply with quote
Had a great few days Rolling Eyes
First, whilst changing the oil, the sump bolt slipped out of my fingers and got stuck in the catch pan hole, blocking it causing 3 litres of used engine oil to cover the driveway... Grrr. Awesome.
Then, after cleaning it and going for a ride Sunday, on the way to work Monday managed to hole the radiator with a stone. Awesome.
Managed to limp home and remove for taking to Engineering shop.
https://www.bikechatforums.com/download.php?id=101129
https://www.bikechatforums.com/download.php?id=101128
www.prisonplanet.com
recman
PostPosted: 11:06 - 23 May 2018    Post subject: Reply with quote
Pigeon wrote:
I've probably missed the post, but what happened?
The cables weakened and broke right at the edge of the ignition case but the plastic outer sleve wasn't cut.
Its a concentrated fatigue break.
On posting the problem on a Street Triple forum, it seems the problem is not exclusively mine.
Some have experience of the problem, others are checking and discovering signs of fatigue.
A bit of factory reinforcing in this area wouldn't have gone amiss.
AshWebster
PostPosted: 11:51 - 23 May 2018    Post subject: Reply with quote
New tank pads
Honda cg125 J reg peice of shit ---> CB650F ---> 2016 CBR600RR
Ford KA ---> 93' MR2 ---> 94'MR2 ---> 98' Subaru WRX STI Ver 3 (track car)
linuxyeti
PostPosted: 22:59 - 23 May 2018    Post subject: Reply with quote
After replacing the luggage carrier on the Mash yesterday, today was time to put a top box on it, I didn't use the 1 that I'd originally put on it, as the 1 I had lying around had a better base plate ..
https://cdn.bcf.44bytes.net/files/mash_xy-400_roadstar_2015_20180523_coalport_1.jpg
lilredmachine
PostPosted: 00:09 - 24 May 2018    Post subject: Reply with quote
Stuuuuffff. Lowered it and such. Also installed some electrickery.
https://s7.postimg.cc/iq8bx4m7v/32955251_10156394124058485_7072916181291630592_n.jpg
https://s7.postimg.cc/fbuquuqij/33403361_10156409210748485_4284168545627013120_o.jpg
https://s7.postimg.cc/kojl8jyuz/33404538_10156409214783485_3563860980574191616_o.jpg
Fisty
PostPosted: 17:45 - 24 May 2018    Post subject: Reply with quote
Yesterday:-
Spanked it down an airstrip.
https://i.imgur.com/i6TvKW8.jpg?1
Fatter and faster than Fret
bacon
PostPosted: 22:09 - 24 May 2018    Post subject: Reply with quote
Fisty wrote:
Yesterday:-
Give me some figures!?
Fisty
PostPosted: 18:46 - 25 May 2018    Post subject: Reply with quote
XL jacket
38" waist
size 12 boots.
FretGrinder
PostPosted: 18:53 - 25 May 2018    Post subject: Reply with quote
Fisty wrote:
XL jacket
38" waist
size 12 boots.
Don't forget the 36F moobs
Yamaha MT-09
ಠ_ಠ
Courier265
PostPosted: 15:44 - 26 May 2018    Post subject: Reply with quote
Replaced my damaged PR4 tyre with a new one...
ThatDippyTwat
PostPosted: 16:15 - 26 May 2018    Post subject: Reply with quote
Ordered EBC clutch plates, & springs, and normal cable & gasket. The recently replaced ones are slipping already, but they were cheap. Adjusted it as best I can.
Chain clean, tension, lube. Air pressure, rear was a bit low.
Tidied up some cable routing and wires.
wr6133
PostPosted: 19:00 - 26 May 2018    Post subject: Reply with quote
New YSS shock on the ZZR
https://farm2.staticflickr.com/1746/41466266545_bcaf3c5679_b.jpg
Despite being low miles the old one was like a pogo stick and made cornering a bit hit and miss.
It now handles vastly better also as a bonus the new one weighs 1.8KG less..... I think Kawasaki had the OEM one injected with lead or something.
ThatDippyTwat
PostPosted: 19:53 - 26 May 2018    Post subject: Reply with quote
Every ZZR1100 I rode had a fucked/shit rear shock, all were sub 30K. My one was replaced with a Maxton. Had them tweak the forks while I was there, the extra cost was minimal over the shock, not horribly far off for a bloke my size, they said.
Totally transformed the bike, you had confidence chucking it into a corner as long as you weren't *too* silly about it, it's still a big old bike after all.
Octapode
PostPosted: 21:53 - 26 May 2018    Post subject: Reply with quote
Greased the rear brake up to make it stop sticking. Stops better now too.
ThatDippyTwat
PostPosted: 17:21 - 28 May 2018    Post subject: Reply with quote
Played with the clutch some more. Think I've got it, no idea how long it'll last for.
Did 150ish miles. Clutch seems bedded in nicely, for now, and there's adjustment left in it.
Pro-tip - If I can keep up with you on your big old adventure GS, you're doing it wrong. Not sure if he was scared of the bike, road, or both.
Pigeon
PostPosted: 21:43 - 28 May 2018    Post subject: Reply with quote
Want Gixxer to be able to stand in for Striple when going away.
So committed a heinous crime. Topbox on sportsbike Embarassed (already had boxes, just needed a bracket and spare seat to attach it to. All in, cost less than just the frame / arms on a givi rack and I've not messed with the standard bike).
https://i.imgur.com/Mkjhs49.jpg
https://i.imgur.com/w27sg9Z.jpg
Then an R&G Tail Tidy (first pic, side by side for comparison)
https://i.imgur.com/vmUAWQm.jpg
https://i.imgur.com/qNaWF42.jpg
https://i.imgur.com/y728rvI.jpg
And finally, a Pigeon special chain luber. Only cable tied in place, so easily removed. But did drill a hole in top of chain guard.
https://i.imgur.com/DeFxdD2.jpg
Listened to IoM practice on Manx Radio, ate a Madras while watching the sun go down. A good day Smile
Octapode
PostPosted: 22:05 - 28 May 2018    Post subject: Reply with quote
Realigned the forks, unbent the left footpeg, replaced the wrecked mirror, unbent the indicator bracket and welded up the cracked frame ear.
You wouldn't think you could do so much damage just from dropping a bike at 10 mph in a field. That's what I get for letting my dad have a ride, I guess.
Courier265
PostPosted: 22:08 - 28 May 2018    Post subject: Reply with quote
Not really, I knew a bloke who did the same on an R1.... he even went the extra mile by mounting the number plate on the top box WITH an LED light.. 100 percent legal.
Fisty
PostPosted: 21:37 - 29 May 2018    Post subject: Reply with quote
Fitted the fairing clips, adjusted the chain on mine.
Fitted new fuel hoses and clutch to a mates TL1000S
PostPosted: 23:51 - 29 May 2018    Post subject: Reply with quote
Investigated a slight clunking while pushing the Ninja backwards, to discover that the rear caliper was being held on by one bolt rather than the two suggested by Kawasaki-san, and was therefore free to rotate - fortunately backwards rather than forwards.
It did somewhere between 12 and 25 miles like that today, surprisingly few kittens were murdered. The front bolt is just for show, right? Whistle
M.C
PostPosted: 00:01 - 30 May 2018    Post subject: Reply with quote
Rogerborg wrote:
If you want something done right, and all that.
Whistle
PostPosted: 00:36 - 30 May 2018    Post subject: Reply with quote
M.C wrote:
Whistle
I'm going to use a black cable tie to hold it in place. Strength through diversity. Folded arms
UncleFester
PostPosted: 05:56 - 30 May 2018    Post subject: Reply with quote
Weld it - have you learned nothing?
Module 1 and 2 passed - October 2014. Happy owner of a 2017 Z1000SX, ex owner of a YBR125 / CB500 / VFR800.
PostPosted: 08:29 - 30 May 2018    Post subject: Reply with quote
I'll never get it within 4/1000". Crying or Very sad
Hong Kong Phooey
PostPosted: 15:37 - 30 May 2018    Post subject: Reply with quote
He surely means JB weld it right?
The last post was made 5 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 310 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 0.24 - MySQL Queries: 17 - Page Size: 136.05 Kb
