What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 332, 333, 334 ... 407, 408, 409  Next
redeem ouzzer
PostPosted: 23:21 - 11 Mar 2019    Post subject: Reply with quote
At weekend had a day on the Dyno.
YR5 was slightly down on previous peak (possibly down to running rich / slightly blowing head), but we coaxed another few torques out of it. Ended up just over 35 ft/lb torque which is ridiculous for an aircooled twin with a fixed exhaust port. Might do a “wet” map as I think it’ll be a handful on a wet circuit.
GSXR400 went on with bigger mains (to richen it up at the top without the baffle) and dropped needles (to cure the excessive richness under 5k). First try was bang on. 57.2 bhp, 22 ft/lb torque and AFR in tolerance through the rev range. About a 2bhp gain over the airbox but no real trade off in torque or driveability. But the best thing is I’ll never need to wrestle the fucking airbox on and off ever again. Oh and the filters and pipe sound absolutely feral at 15000 rpm....
Be a REAL MAN!
ThatDippyTwat
PostPosted: 07:40 - 12 Mar 2019    Post subject: Reply with quote
Put a flap of 6mm rubber over the shock on the viffer, stop it getting coated in shit. This is more in prep for probably getting Maxton to put a decent shock in there.
Tidied up wiring. Put accessories (Voltmeter, USB, camera) on 2 pin connectors and ran a fan of them out to one ring, rather than a stack of ring connectors. Should make connecting batteries much easier.
Chain tension, clean and lube.
Pulled exhaust and carbs off parts bike.
Wyberton John
PostPosted: 15:39 - 13 Mar 2019    Post subject: Reply with quote
Cossetted it with a luvvly new Oxford Raintex Premium cover Smile
Oh - and my new pillion pegs arrived today, so Felicity (my bike) will be chuffed to rocks
Fazer Thou Gen 1
wr6133
PostPosted: 17:46 - 13 Mar 2019    Post subject: Reply with quote
Having been made redundant and sitting on gardening leave I finally got back to the GSXR I tore apart over Christmas.
Today managed too
Drain oil and coolant
Flush out coolant system
Repair the damaged bits of the loom
Harpic cleaned the headers and link pipe
Degunged any gungy bits I came across while doing the above.
If all goes to plan tomorrow will be putting the loom back and connecting it all up, reattaching subframe, new oil in, get it ticking over and refilling coolant, rebuild rear brake calliper, fairings on and then all I need is a front tyre and an MOT.
notabikeranym...
PostPosted: 18:12 - 16 Mar 2019    Post subject: Reply with quote
Stopped neglecting it
https://i.imgur.com/0NTGuQb.jpg
ThatDippyTwat
PostPosted: 22:01 - 16 Mar 2019    Post subject: Reply with quote
Chains clean, lube and tension on both bikes.
Replaced rusty screws in Viffers master cylinders with stainless ones.
Rearranged the locks over between bikes to make it less of a faff.
B0ndy
PostPosted: 15:34 - 17 Mar 2019    Post subject: Reply with quote
Oil change, shoutout to the dummy who put the last filter on - really enjoyed spending 1 hour to do an oil and filter change instead of 15 minutes Thumbs Up
https://i.imgur.com/AEHX7Ev.png
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H
Courier265
PostPosted: 18:51 - 17 Mar 2019    Post subject: Reply with quote
Changed the headlight bulb and "position" bulbs on the inazuma, also adjusted the chain again, farking swift chain crap...never again.
I would of washed the bike but it started to rain with hail mixed in and it was to farking cold.
BigTim
PostPosted: 01:28 - 18 Mar 2019    Post subject: Reply with quote
New stator on my Biffer, Oil and filter change. put my pannier and top box racks back on and only two bits left over?? WTF! Confused
FretGrinder
PostPosted: 09:45 - 18 Mar 2019    Post subject: Reply with quote
How many stators have you been through?
I went through 4 on my cbf in 47k
Yamaha MT-09
ಠ_ಠ
PostPosted: 10:59 - 18 Mar 2019    Post subject: Reply with quote
Not a lot of chain adjustment left there. Laughing
Triumph Trophy Launch Edition
derillius24
PostPosted: 11:50 - 18 Mar 2019    Post subject: Reply with quote
A few bits and bobs done to prepare the big Yam for the new season:
New tyres
3Pistons bar end mirrors
Evotech and GB Racing crash protection
Radial master cylinder from a 2015 R1 fitted and Brembo SA pads
Brake fluid change
Evotech levers
Carbon fibre bits
Rad and oil cooler guards
Tail tidy and 7x5
Oxford Hot Grips
Stompgrips
Silver panels painted black
rearsets powdercoated
https://i.postimg.cc/8PHfvsmw/IMG-5754.jpg
https://i.postimg.cc/hGJXNsW3/IMG-5755.jpg
https://i.postimg.cc/qvDtmYY3/IMG-5757.jpg
https://i.postimg.cc/zGGbF5dN/IMG-5758.jpg
https://i.postimg.cc/d0zhFCJQ/IMG-5770.jpg
shell near me
CG125, CBF250, DRZ400-SM, Z750, Street Triple R, Tuono V4R
ThatDippyTwat
PostPosted: 22:31 - 18 Mar 2019    Post subject: Reply with quote
Sold it.
Parts bike went to another home, after I pulled the wheels off, they stay with me.
pompousporcup...
PostPosted: 10:32 - 19 Mar 2019    Post subject: Reply with quote
not today but last week i wrote it off -_- RIP gpz900
ride_to_die
PostPosted: 15:27 - 19 Mar 2019    Post subject: Reply with quote
Lubed chain & bled the clutch on the rsv because finding neutral was becoming a bit of a sod.
I'm not here for a long time, I'm here for a good time.
Hong Kong Phooey
PostPosted: 11:16 - 20 Mar 2019    Post subject: Reply with quote
Have I missed the spill thread entry?
pepperami
PostPosted: 14:00 - 20 Mar 2019    Post subject: Reply with quote
Cleaned a few cruddy bits and plugged the Hyosung GT250r into the Optimate.
Oh and checked the tyre pressures Thumbs Up
Serendipity
PostPosted: 23:46 - 20 Mar 2019    Post subject: Reply with quote
I paused to take a picture:
https://i.imgur.com/MhIEFZPh.jpg
I've done lots of miles with lots of vehicles, but this is the first one I've taken over the 100k mark. I bought the CBF1000 with 20k on the clock and added the 80k over the last 6 years. It would have got to 100k sooner, but I tend to give the bike a break over the summer while I ride the cooler CB500.
The bike is still in pretty good shape. The heel plates and heated grips are worn and there's a frame brace hidden behind the radiator that's almost rusted through, but otherwise it cleans up quite nicely.
Another 100k ahead? Meh, I don't know. The mileage effectively makes the bike worthless so I'll probably keep knocking out the miles until something expensive breaks, then move on to something made in the current decade.
2007 CBF1000-ABS - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
pompousporcup...
PostPosted: 09:58 - 21 Mar 2019    Post subject: Reply with quote
you haven't, am waiting on the pictures to come through the post -_-
wasn't done on the road but at the track.
Wyberton John
PostPosted: 09:23 - 22 Mar 2019    Post subject: Reply with quote
Having a right time with the "chap from further corners..." who sold me these on ebay. Turns out they are not rear pegs at all, but front ones.
I asked for a return and explained the issue precisely, but he's being a dick and demanding photo's showing exactly how they won't fit on the rear. Getting a bit pissed off with him.
Took him a while to respond to the return request, yet if I don't respond to his messages within hours, he's complaining at me.
Anyway, I'm guessing he's someone who knows sod-all about bikes or the internet, cos it took me less than 3 minutes to find the Yamaha diagrams online that show the difference between front and rear peg fittings.
Needless to say, I haven't fitted my new pegs yet - but I must admit I'm thinking of keeping them, as my fronts are well worn - just want this twat to describe what he's selling accurately.
Fazer Thou Gen 1
Hong Kong Phooey
PostPosted: 09:54 - 22 Mar 2019    Post subject: Reply with quote
Play the game properly. ebay?
Well they will rule in your favour, the onus on the seller to sort out return postage as it's his mistake.
That would likely be too expensive and he'll probably let you keep them for free or ask you to accept them for partial refund.
sickpup
Old Timer
PostPosted: 14:18 - 22 Mar 2019    Post subject: Reply with quote
Ordered new Hyperpro suspension front and rear for the 2008 ER6. Built to order so will take about a month to arrive.
Need to decide if I should fit PD valves when the front end is apart.
ThatDippyTwat
PostPosted: 18:19 - 22 Mar 2019    Post subject: Reply with quote
Changing wheels to the earlier 90-93 ones. Thought I would change pads while I have the wheel off. Back wheel already on and sorted at this point.
Front right caliper was no problem. Cleaned it up, greased slider, new pads, bosh.
Left? Slider jammed solid. Heat, drill - Nothing moves it. New caliper and rebuild kit. ordered.
Skudd
PostPosted: 18:21 - 22 Mar 2019    Post subject: Reply with quote
Just fitted sat nav to the GS and bled the brakes on the Cagiva.
Whosthedaddy
PostPosted: 21:48 - 22 Mar 2019    Post subject: Reply with quote
Washed it.
Well, used some snow type soap and rinsed off with the hose.
The last post was made 5 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 333 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.63 - MySQL Queries: 17 - Page Size: 136.27 Kb
