Fisty |
Fisty Super Spammer
Posted: 18:50 - 26 Jan 2020 Post subject: |
Fisty wrote: | The Blandit 400.
When I bought it it was sold as a none runner, backfiring and not going above 4000RPM.
In the paperwork was a receipt for £450 for a full carb rebuild. Odd it still wasnt running right.
Today I found the culprit. The wrong spark plugs were fitted.
A quick trip to Hellfrauds and the correct plugs bought.
It now runs like a new bike!!
https://i.imgur.com/oHzkHEj.jpg?1
Next on the list is fork seals. |
Little update.
Turned up a set of OE clocks on ebay to replace the bodged on aftermarket set.
Luckily the old wiring harness and plug was untouched so it was a straight swap.
The clocks needed a little bit of repair internally as the mounts were cracked and the fuel gauge does not work but the look much better than the bodge job.
https://i.imgur.com/wJYfJcb.jpg?1
https://i.imgur.com/iODWzoU.jpg?1
https://i.imgur.com/z0zl65p.jpg?1
The shopping list is growing.
This evening I bought genuine fork sels and bushes, fork oil, a lithium battery, speedo cable.
I would like to fit some braided hoses and a Coerce top yoke with raisers.
I really want to find a period yoshi or beet system for it the same as when I owned it in the 90's.
https://i.imgur.com/mJ9PV9H.jpg?3 ____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
redeem ouzzer |
Posted: 19:00 - 26 Jan 2020 Post subject: |
Didn't see your original post that you were now a fellow Suzuki 400 owner hun
Have to say i'd be wary of the VVT engine knowing what i know now regarding valve shim and camchain availability.
Anyway if you are sourcing a fruity pipe it really needs a FacPro pod kit or a set of TMR33's on it ..fap.. ____________________ Be a REAL MAN! |
Fisty |
Fisty Super Spammer
recman |
recman World Chat Champion
wr6133 |
wr6133 World Chat Champion
Posted: 12:24 - 28 Jan 2020 Post subject: |
Last few days on the Enfield
Changed oil (twice used 1 as a flush), when I bought it it still had original oil.
Cleaned or replaced filters.
Cursed the design of the oil filler cap and the crank sensor wire (they interfere with each other).
Fitted dual seat and cowl, the solo seat was a torture rack.
Replaced Battery.
Setup preload/sag on the arse end. The criticism journalists gave these shocks was unfair they work fine. I suspect some of the panning came from bikes not setup properly, this was still on "factory" settings and the preload was set quite differently on each side. The real weak link in the suspension is the front end, bottoms out easily.
It needs a Power Commander and some dyno time to sort the filter and pipe (the cost of this to make it idle better and sound less like a major mortar strike on the over run though is not proportionate). I'm pondering if just deleting the o2 sensor will force it to run slightly richer? Or if this is retarded.
Been eyeing up Hitchcocks website, could be dangerous it appears you can burn crazy sums modifying these bikes.
Also polished it alot
https://live.staticflickr.com/65535/49454290466_218394d281_k.jpg |
sulphur |
sulphur Trackday Trickster
zachary54 |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
zachary54 L Plate Warrior
Posted: 21:09 - 28 Jan 2020 Post subject: |
after buying a Benelli TNT 1130 cafe racer at the weekend, today i started washing and inspecting what ive actually bought!
https://youtu.be/glWw4Vt4Iyc |
Fisty |
Fisty Super Spammer
Posted: 23:22 - 28 Jan 2020 Post subject: |
Fisty wrote: | Fisty wrote: | The Blandit 400.
Little update.
https://i.imgur.com/mJ9PV9H.jpg?3 |
Another evening on the Blandit.
Sorry no pictures as I left my phone at home and its in a mates garage.
Tried to balance the carbs but struggled, whipped them off and found 33bhp (or whatever the restriction is now) restrictors behind them.
Once removed and the carbs refitted and seated correctly it starts, runs and idles perfectly.
Banged a new battery in.
Stripped the forks to replace the seals only to find it needs bushes.
SGP bushes ordered, found a pair of braided hoses in the shed. They are slightly too long but will fit.
Needs a headlight bulb, i think I have a nightbreaker somewhere.
It needs a loud can. ____________________ Quietly and consistently taking the piss.
pepperami |
pepperami Super Spammer
Posted: 02:11 - 29 Jan 2020 Post subject: |
Took the Hyosung GT250r in to the shop today for an MOT and while it was there I got them to put on a nice new shiny Black Widow full exhaust.
No re-jetting required happy days,!
It’s half the weight of the original and is only a little bit louder than the original.
Happy Pepperami is a happy Pepperami ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Benson_JV |
Benson_JV World Chat Champion
Posted: 10:51 - 29 Jan 2020 Post subject: |
Does wiping the dust off it count? Need to get it back out & cleaned up this weekend, take stock of what needs doing. ____________________ Willson - "If you go out on that CBR600 in the winter, you're going to do more miles on your side than on your wheels."
Previous Bikes: '96 Bandit 600, '96 GPz305 |
P. |
P. Red Rocket
Benson_JV |
Polarbear |
Polarbear Super Spammer
Posted: 14:17 - 29 Jan 2020 Post subject: |
That is utterly lovely. ____________________ Triumph Trophy Launch Edition |
Hong Kong Phooey |
Posted: 00:38 - 30 Jan 2020 Post subject: |
Polarbear wrote: |
That is utterly lovely. |
Not my kind of bike, but I can appreciate it - old school cool.
Old school reliability too no doubt ____________________
Hong Kong Phooey |
wr6133 |
Easy-X |
Easy-X Super Spammer
wr6133 |
Fisty |
Fisty Super Spammer
Bhud |
Bhud World Chat Champion
Easy-X |
Posted: 14:40 - 01 Feb 2020 Post subject: |
As per my other post, skipped messing with the exhaust on the Rebel and sorted the mudguard instead:
https://i.imgur.com/JE0NHAa.jpg?1
Weather Protection 1 : Self Respect 0 ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Fisty |
Fisty Super Spammer
kramdra |
kramdra World Chat Champion
Easy-X |
Dave.... |
Dave.... Trackday Trickster
The last post was made 4 years, 84 days ago. Instead of replying here, would creating a new thread be more useful? |
