ThatDippyTwat |
Scotsrick |
Scotsrick Two Stroke Sniffer
FretGrinder |
FretGrinder World Chat Champion
NJD |
NJD World Chat Champion
Posted: 18:27 - 16 Mar 2020 Post subject: |
Used a el-cheapo oil filter wrench to remove the oil filter after the socket cup type decided to brake and brute force didn't work.
https://i.postimg.cc/CLvLFs05/20200316-130323.jpg ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
redeem ouzzer |
Fisty |
Fisty Super Spammer
Posted: 18:28 - 19 Mar 2020 Post subject: |
Fitted a set of genuine Bandit 1200 mirrors as the chinesium ones fitted let me see my elbows and nothing else. Popped in a nightbreaker bulb while I was at it.
Before......
https://i.imgur.com/6VrRm50.jpg?1
After.....
https://i.imgur.com/l3cebPz.jpg?1 ____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
seeyalater |
seeyalater Trackday Trickster
NJD |
Posted: 20:54 - 20 Mar 2020 Post subject: |
"26 Nm isn't that much, I'll use this and it should be good enough" I foolishly thought as I used an el-cheapo Lidl oil filter wrench (pictured 4 posts up) to tighten the new oil filter after my cup type wrench broke attempting to remove the old oil filter. It got me out of a hole and allowed me to remove the old oil filter, sure, but I hadn't planned on it being as ineffective in tightening as it was.
Test started the bike multiple times on the day and even went for a test ride. All good, I thought.
Went to start the bike today and saw a puddle of oil: excellent.
Ensue a trail of oil as I went back inside to get my tools out.
https://i.postimg.cc/PJ9rbCT7/20200320-125744.jpg
After I'd fixed that I picked up another cup wrench type and returned to torque it up to spec. I'll cry if this one falls apart when I attempt an oil change next time round. £10 at my local bike shop, ffs. Should have just gone to Halfords. Mind, he did take an oil filter out the cupboard and try it for size to make sure it would work before I purchased it.. not bad service.
Currently hating the hoarding going on at supermarkets so carried on fiddling with the bike. Removed aftermarket exhausts and put the standard ones on (complementary last summer, much cleaner, photo of how dull they are):
https://i.postimg.cc/ZYBHr0PF/IMG-6162.jpg
I haven't used them since I got the bike last summer, and I could cry inside at how quiet they are. I went past a run down car and it made louder noise than me. I'd put the aftermarket ones back on but (a) can't use panniers with them, (b) an arse to fit and (c) not that greatly made where copying the original mounting points -- and also they don't have the packing at the connecting point (bike to downpipes) so are loose even when clamp is tightened.
Hopefully dogs will like me more now. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
Pigeon |
Pigeon World Chat Champion
NJD |
Fisty |
Fisty Super Spammer
Posted: 17:49 - 21 Mar 2020 Post subject: |
Got the girls out of isolation while I fixed the shed.
Mice have chewed the loom on the busa.
https://i.imgur.com/5FKNOoZ.jpg?1 ____________________ Quietly and consistently taking the piss.
ThatDippyTwat |
Posted: 18:16 - 21 Mar 2020 Post subject: |
Pulled the camera off the 750 and fitted to the 600. Discovered more wire bastardising from a PO in the process of tapping the 12v feed on the rear light. Proper crimp connectors and water resistant boots fitted.
https://i.imgur.com/BXguJ5Zl.jpg
Removed the worlds smallest indicators and replaced with some non-obtrusive but visible ones on the 600.
https://i.imgur.com/bLtgHyWl.jpg
Charging the Honda's battery so I can start it and look for the problem tomorrow.
Decided it was probably the clutch rattling on the 250. Need to drop oil and investigate. If anyone knows what motor this is/based on, yell out so I don't have to ship from Korea. (Linuxyeti & pepperami - help is appreciated). Pic is pre clag removal, rust removal and painting. It's a cheap workhack, it'll be fine.
https://i.imgur.com/9X7qukEl.jpg
Got stuff ready to strip front end on the VFR if we get locked down. Might as well if I have it all here. I'll have a while to figure it out.
Rust convertor on all the bikes now the salt is probably done with. Painted over in an appropriate colour once dried off. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
seeyalater |
ThatDippyTwat |
Posted: 15:55 - 22 Mar 2020 Post subject: |
Viffer - 90's Honda wiring. What joy.
My bodge job fixing a dangerous mess that a PO did fell apart. Also started getting melty. Ripped the lot out, started again. Reg/Rec was fine, put a new connector on, ran some 30A cable for the DC out, there's was already 30A cable for the AC in. Heavy duty 30A connectors. Ran cloth loom tape up the lot.No pics of after, I was tired and wanted to thrash... I mean ride, the 600 before I baffled the poor thing. Rust treated and painted while I had the rear cowl off.
https://i.imgur.com/cg4c9D1l.jpg
https://i.imgur.com/LAWlh3rl.jpg
GSX-F - Ghetto-baffled the Remus. Remus HQ responded very quickly to my request to buy a baffle for this can, but the UK importer not so much. I have to be at work by 06:00 for the next few weeks, assuming we're not shut down, so stainless pot scourers it is. The hardware is to stop it getting blown out the back. Also discovered the 600 has been put 1 down on the front and 2 up on the back.
https://i.imgur.com/23YQUjRl.jpg
Just for Donk - One of my cat's helped by sunbathing, sorry, supervising, from the neighbours car. He'll probably shit in the flower bed later on.
https://i.imgur.com/7BhGExel.jpg ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
FretGrinder |
Fisty |
Fisty Super Spammer
Whosthedaddy |
Whosthedaddy Super Spammer
Posted: 11:47 - 23 Mar 2020 Post subject: |
Attempted an oil change.
Could I undo the sump plug?
Er, nope!
____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
linuxyeti |
linuxyeti World Chat Champion
Posted: 12:10 - 23 Mar 2020 Post subject: |
NJD wrote: | "26 Nm isn't that much, I'll use this and it should be good enough" I foolishly thought as I used an el-cheapo Lidl oil filter wrench (pictured 4 posts up) to tighten the new oil filter after my cup type wrench broke attempting to remove the old oil filter. It got me out of a hole and allowed me to remove the old oil filter, sure, but I hadn't planned on it being as ineffective in tightening as it was.
Hopefully dogs will like me more now. |
THink you need to do something with your chain !! ____________________ Beware what photos you upload, or link to on here, especially if you have family members on them |
ThatDippyTwat |
pepperami |
pepperami Super Spammer
Fisty |
Fisty Super Spammer
Posted: 19:41 - 25 Mar 2020 Post subject: |
So day 2 of cabin fever turned into a sunny bike day.
The busa:-Fitted a bracket for the front brake reservoir and a carbon cap, because I like the way it looks.
https://i.imgur.com/btamFMy.jpg?1
The TL1000R:- Fitted a 200 section rear tyre and wheel, I paid £7 for wheels and tryes from ebay. The guy I bought them off wouldn't come to the door when I collected them so he sent his wife because he was so pissed off he sold them so cheap.
I only wanted them for the wheels as they are in better condition than mine. But let's see how it handles with a 200 rather than a 190.
Fitted a carbon front mudguard.
Cleaned and bled the brakes.
https://i.imgur.com/2XkUSDp.jpg?1
The TL1000S:- Fitted a new screen as the old one was cracked, repaired the loom.
Made it go brap.
https://i.imgur.com/hTXfCTb.jpg?1
Tomorrow I will do some cleaning. ____________________ Quietly and consistently taking the piss.
ThatDippyTwat |
Clanger |
Clanger Stirrer
Posted: 21:22 - 25 Mar 2020 Post subject: |
Day 5 of not-being-on-holiday-in-the-Canaries, and I still haven't wrestled the bike out of the garage for must needed clean. I did promise myself and the Black Kwak that it would happen...perhaps tomorrow. ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss |
Hong Kong Phooey |
Posted: 22:09 - 25 Mar 2020 Post subject: |
Not mine, but a mate who's going through a rough patch.
On top of that he crashed his CBR600. Stator case and engine case cracked, bolts snapped inside, fairings knackered, bar end and levers, gear lever and footpeg all broke.
Previously fixed the gear lever and footpeg, fitted stator casing to keep moisture out.
Tonight's episode was removing all bodywork. He's got China's finest fairings en route. Charged the battery, started below 7v hope it can be rescued. Trying to keep costs down.
It was at 11.6v before I pulled the plug. Will top it up some more tomorrow.
Oiled the chain, loads of stiff links as it's been sat a few weeks outside neglected. Will try waggling them free with pliers tomorrow.
Loosened the forks and reset the bars and axle, must have been quite low impact as there was not much movement.
https://i.postimg.cc/TwDd9GzQ/20200325-190000.jpg
Best part yet to come will be getting engine case bolt/studs out and repairing the engine case. ____________________
pepperami |
The last post was made 4 years, 32 days ago. Instead of replying here, would creating a new thread be more useful? |
