wr6133 |
wr6133 World Chat Champion
Posted: 09:02 - 26 Mar 2020 Post subject: |
Their partnership with Honda was in the '70's. I wouldn't be surprised if that is a long forgotten aircooled motor modified to the modern age with LC, FI, etc. |
seeyalater |
seeyalater Trackday Trickster
Clanger |
Clanger Stirrer
Posted: 17:19 - 26 Mar 2020 Post subject: |
I've actually cleaned, then polished and then protected The Black Kwak with ACF50 today...the bike is officially clean and shiney again. No pics because I can't for the life of me remember how to load an image via the laptop. ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss |
SDFarsight |
SDFarsight Nova Slayer
Fisty |
Fisty Super Spammer
Posted: 14:38 - 27 Mar 2020 Post subject: |
The baby bandit.
Drilled out and tapped the clip ons to fit bar end weights.
Re routed the speedo cable.
Cleaned and polished it.
Fitted some paddock stand bobbins.
Straghtened the headlight bowl as it was dented.
https://i.imgur.com/lxUN0Gw.jpg?1
Just need to sort the scabby rocker cover now, ____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
seeyalater |
Posted: 16:12 - 27 Mar 2020 Post subject: |
Fisty wrote: | The baby bandit.
Just need to sort the scabby rocker cover now, |
had no idea there was a 400 bandit.. looking good.. |
Skudd |
Skudd Super Spammer
Fisty |
Fisty Super Spammer
Clanger |
Clanger Stirrer
Posted: 18:18 - 27 Mar 2020 Post subject: |
I'd be tempted to chop that exhaust...it's a tad long. A little stubby exhaust like the Honda Bros 400 would look ideal. I used Bandit 400 indies on my sv. They are lovely little things, they looked good, hard to believe they're stock. ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss |
Fisty |
Fisty Super Spammer
seeyalater |
ThatDippyTwat |
Posted: 16:23 - 28 Mar 2020 Post subject: |
Rear brake caliper rebuild with stainless pistons. It was weeping a touch when you stood on the rear in anger, but would probably pass an MOT. That said, it wasn't hard or expensicve, so why not?
https://i.imgur.com/AYJHEnsl.jpg
All apart, no flying piston injuries.
https://i.imgur.com/cS2ha4Nl.jpg
Old pistons were millered. Looks like someone had mole grips on them.
https://i.imgur.com/y0E5YmUl.jpg?1
Cleaned out, new seals and pistons fitted.
https://i.imgur.com/CyW2j8il.jpg
Rebuilt, refitted, and I also gave the wheels a good scrubbing as they were manky. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
yen_powell |
yen_powell World Chat Champion
Hong Kong Phooey |
Hong Kong Phooey |
Posted: 20:16 - 29 Mar 2020 Post subject: |
Got it all sealed up, oil tight. Filled with oil, charged battery fully.
Tried cranking, spinning up but not firing.
No FI error code flashes, killswitch, sidestand switch, fuel relay all tested ok.
I'd only forgot to plug the headlight unit back in.
The bank angle sensor is attached to the top of the headlight, without it attached the fuel pump cuts off, no warnings given. I realised when I couldn't hear the fuel pump priming.
Running ok now, will check closely for oil seeping out tomorrow and charge the battery again as the repeated cranking had drained it.
Just needs chain and sprockets, indicators on the front and fairings, parts ordered just waiting for delivery. ____________________
ThatDippyTwat |
recman |
recman World Chat Champion
Easy-X |
Easy-X Super Spammer
Posted: 18:21 - 30 Mar 2020 Post subject: |
I went to fit new foot pegs and then discovered the pins holding them together are peened over Ordered some generic clevis pins after drilling out the old ones. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
ThatDippyTwat |
Hong Kong Phooey |
Posted: 21:56 - 30 Mar 2020 Post subject: |
Thought I'd work on one of my own. RC8 will be having the secondary air injection (PAIR, SAI, SAS whatev) valve removed to make it less antisocial (reduced backfiring) and smoother on the throttle.
While I'm down there I'll be checking the valves, changing plugs and air filter, oil was done recently.
Getting the airbox off was a Brian CANT of a job. This needs to come off to clear out the emissions crap, and valve clearance checking. Changing plugs will be a doddle while it's off so it would be rude not to.
The airbox rubbers are held on with clamps, and getting to the 3mm allen heads in such a confined space inside the airbox was hard enough. But on top of that the rubbers were held on with years of never being off friction. Plenty of WD40 squirted between the intake and the rubbers meant it came off eventually with assistance of a big crow bar. After it came off I saw the removable access hole cover to make it easier to get to the machine screws that were holding the rubbers on
Air filter was manufactured in 2015, I'm guessing that all sales people are lying bastards, they said it had been serviced. Well by the amount of shit that blew off when blasted with compressed air they're talking turtle bollox.
New air filter, plugs, sas blanking plates & 16T front sprocket on order.
Will get the cam covers off tomorrow for valve check. Bet that's never been done either!
https://i.postimg.cc/xCcsg6gg/20200330-204215.jpg ____________________
1198 |
1198 World Chat Champion
Fisty |
Fisty Super Spammer
redeem ouzzer |
Posted: 15:05 - 02 Apr 2020 Post subject: |
1100 came back last week after being on holiday since November 2018. Full engine rebuild using only genuine Suzuki parts in the original bags. Rings, shells, camchain, 3rd gear all replaced.
https://live.staticflickr.com/65535/49727719247_cb27b4051f_h.jpg
Decided to replace the wiring loom as the old one is starting to throw up some odd issues, oil light working only intermittently and an occasional fault somewhere in the sidestand cutout / diode circuit where you lose neutral light and sparks untill the stand switch is operated again. Still available new.
https://live.staticflickr.com/65535/49727719332_8b0bdd998f_h.jpg
While doing this I also have a ZX10 radial master cylinder to fit (ordered new hoses), new ignition switch to sort (security bolts ). Can't even test ride or MOT the thing so might as well do fucking everything. ____________________ Be a REAL MAN! |
Fisty |
Fisty Super Spammer
redeem ouzzer |
The last post was made 4 years, 17 days ago. Instead of replying here, would creating a new thread be more useful? |
