NJD |
NJD World Chat Champion
Nobby the Bastard |
NJD |
ThatDippyTwat |
kramdra |
kramdra World Chat Champion
Posted: 14:54 - 02 Aug 2020 Post subject: |
NJD wrote: | Purchased some cheap used braided brake lines (front and rear) for the yet to arrive bike and discovered some damage on one of the front lines.
Set up a makeshift platform to test if there was a leak. Idea being I'd pour an awful lot of used brake fluid into the tear from the outside and if any appeared to be coming from the slot in the banjo part that the bolt attaches to (where fluid should come out from normally) I'd consider it fubar, but none did (idea being gravity and an awful lot of fluid would force any getting into the hose from outside downwards).
Will test on bike eventually, and if it holds pressure overnight then should be good to run (after being taped over / covered up to prevent further damage, of course).
Usually it looks like the type of part that I'd be wide eyed about, but for now it looks like nothing more than a tear in the outer sleve.
Torn between £22 was a bargain for a full set (F/R) and people really should learn what their selling (eBay ).
https://i.postimg.cc/MGRyKMkk/20200802-131052.jpg
https://i.postimg.cc/XJkddR7Q/20200802-131100.jpg |
Your test methodology wont tell you anything. You will now have brake fluid under the outer plastic sheave waiting to drip everywhere, and looking like shit. Good luck getting it clean, and convincing a mot that it doesnt leak.
Testing under hydrualic pressure is required. You could connect it up to a master, but Id suggest blanking off the banjo with a solid bolt and nut. You will achive higher testing pressures with no pistons to move and a low fluid volume.
As to the damage, its minor. it has worn through some braid, so Id suggest the failure mode being, sharp ends rubbing or puncturing the inner core. It looks like the damage wont cause any change to feel. You could bend the sharp braids out and wrap the area with silicone self amalgamating tape, or heatshrink. It will always look shit.
Brake lines are not expensive, just get new ones.
ThatDippyTwat wrote: | I'd be sending those back for a refund pronto unless that damage was advertised. |
Too late, Id say. Soaking a part in brake fluid is a good reason to reject a return. |
Fisty |
Fisty Super Spammer
hellkat |
hellkat Super Spammer
Posted: 21:33 - 02 Aug 2020 Post subject: |
Rode off with the chain still locked round the back wheel.
Snapped off half of the bracket from the back fender but no apparent major damage - just a few flakes of paint.
____________________ Not nearly as interesting in real life. |
NJD |
Hetzer |
Hetzer Super Spammer
Posted: 23:27 - 02 Aug 2020 Post subject: |
Ragged the fuck out of it. ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
recman |
recman World Chat Champion
Fisty |
Fisty Super Spammer
Nobby the Bastard |
Posted: 19:30 - 03 Aug 2020 Post subject: |
Finally got round to replacing a couple of seals on the front brake that were a bit sticky.
Tool of the day, brake piston slide hammer. No pissing about with that.
https://www.bikechatforums.com/files/img-20200803-wa0007.jpeg ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
Fisty |
Fisty Super Spammer
Posted: 19:44 - 03 Aug 2020 Post subject: |
Pleased you got the slide hammer over the pliers type. Much better tool. ____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
NJD |
blurredman |
Posted: 08:13 - 04 Aug 2020 Post subject: |
Changed the clutch springs on my MZ ETZ 251 for the 2nd time.
First time I took the clutch unit off and inspected all I needed to- and then replaced the springs with new Indian ones. Clutch still slipping after a test ride-
So, with the clutch still on the taper I put in some 'hungarian' ones - closest to OEM.
Much much better- I think the slip has gone. But I have decided that I will use a mineral oil next time.
I will now be throwing those indian ones in the bin I think. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 17k. , 1979 Suzuki TS185ER - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k |
A100man |
A100man World Chat Champion
Campbell SOUP |
Campbell SOUP Two Stroke Sniffer
kramdra |
Fisty |
Fisty Super Spammer
Posted: 14:45 - 05 Aug 2020 Post subject: |
Fisty wrote: |
That rack isn't going to last long with that box on, I give it 2 months. |
It's still there a year and 4000 miles later, heaviest load was 12 cand of stella and take away for 4.
No bends, snaps or cracks. ____________________ Quietly and consistently taking the piss.
recman |
Posted: 16:32 - 05 Aug 2020 Post subject: |
Hong Kong Phooey |
Posted: 22:51 - 05 Aug 2020 Post subject: |
CBR, fixed the horn, one connector had slipped off. Nice easy fix for the pending MOT.
RC8, set suspension to comfort, it's sharp as fook but unforgiving, I'll get better traction on normal roads this way.
Also made a phone mount from an old electric sofa brace bar and bike innertube, mainly for when you want satnav. It's mounted at the top of the screen so in the best position, you don't normally get that with purchased mounts.
Was intended to be a mockup proof of concept, but worked so well, and is disguised enough by sliding the innertube over it that it can stay on for now. ____________________
arry |
arry Super Spammer
recman |
Posted: 16:42 - 06 Aug 2020 Post subject: |
arry |
arry Super Spammer
Posted: 17:35 - 06 Aug 2020 Post subject: |
Have in the end. Took a serious amount of persuasion though. |
Nobby the Bastard |
Posted: 17:41 - 06 Aug 2020 Post subject: |
Did you add the manufacturers recommended level of oil? ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
The last post was made 3 years, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
