garth |
garth World Chat Champion
Posted: 12:40 - 18 Sep 2020 Post subject: |
I've literally run out of superlatives regarding the 765RS.
It just does everything I want it to do. The brakes are insane, the quickshifter amazing on the track. It's quick, but it's not intimidating, and it sounds the tits. And I can put the plate back on and ride it to work the next day, comfortably.
So put that in yer pipe and smoke it, former-749.
Yet I still cover the clutch on track
https://i.ibb.co/rvcbDYY/15-09-2020-Cadwell-Park-No-Limits-Trackday.jpg ____________________ You ain't a has been if you never was |
MarJay |
MarJay But it's British!
Posted: 14:50 - 18 Sep 2020 Post subject: |
garth wrote: | I've literally run out of superlatives regarding the 765RS.
https://i.ibb.co/rvcbDYY/15-09-2020-Cadwell-Park-No-Limits-Trackday.jpg |
So I did an airfield day a few weeks back, and a guy there had a 765RS, decatted and remapped, and his bike was keeping with a GSX-S1000 on the straights, and pulling away from me as if I was standing still. The rider reckons 140bhp or so... ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
garth |
MarJay |
ThatDippyTwat |
NJD |
NJD World Chat Champion
Posted: 18:54 - 19 Sep 2020 Post subject: |
Purchased a used Syntech evo clutch lever as the O.E.M one had too much up and down wobble for my liking, wasn't adjustable and not only did the bike try to stall at times from pulling away but was also slow to pull away from low down revs / dead stop (yes I'd adjusted it correctly).
The evo lever is slightly worse in that I can't use my handguards with it, and so I need to try and find the "small" lever end to purchase, but apart from that its all good. Bike flies like a rocket and control is so much easier and smoother.
https://i.postimg.cc/JncJt4RF/20200919-152302.jpg
Had to fix the thread on clutch lever (that the screw-in part / lock-ring attaches to) as the shop had decided to give me one with a damaged thread for good measure.
https://i.postimg.cc/ydzcVSC9/20200919-135659.jpg ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
om15 |
om15 Nova Slayer
Posted: 08:27 - 20 Sep 2020 Post subject: |
Took the Interceptor out for a run yesterday, it has done 1200 miles, so run in complete and it can enjoy it's self more. Carried out a quick overtake of three or four cars on a convenient bit of road, went from 50 to about 75 almost instantly and all was well, I was very impressed at the performance. I suddenly became aware that it seemed rather louder than it should, carried on and arrived home to find that I had blown the starboard exhaust baffle out, it is now somewhere on the A30 near Wilton.
I removed the other exhaust baffle and will use it like that until I can source a replacement. It does sound rather nice though, it is an aftermarket exhaust.
I found it rather un wieldy at first, all the weight seemed to be in the wrong places, but now I have got used to it I think that it is a great bike, recommend having a test ride at the dealers, but beware, you might not go home empty handed. ____________________ Alcohol doesn't solve problems, but neither does milk |
pepperami |
pepperami Super Spammer
Posted: 14:57 - 21 Sep 2020 Post subject: |
The excitement on ‘Project Scrappy Hyosung’ gets to much sometimes.
Today I did buy twenty new bolts to replace the corroded ones on the bike, I even included washers just in case I didn’t have enough at home .
Whoop whoopty do! ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Bhud |
Bhud World Chat Champion
Posted: 17:47 - 21 Sep 2020 Post subject: |
As much as I could, for now.
A brass wire drill bit hardly touched the rust on the front wheel, so I ended up removing as much as I could, before stabilising it and then giving the rim and the hub a few coats of Simoniz Underguard Black. This paint is legendary - I might do the whole frame in it.
Relaced it with 35 out of 36 spokes (the seller failed to count out the right number, so I have to just wait for the 36th ). These spokes are much heavier duty than the standard Kawasaki ones (NOS ones are extremely expensive), and I had to enlarge the holes in the rim ever so slightly to accommodate the new nipples. It was also a bit tricky shoving the spokes through the holes in the hub.
Also finished off work on the exhaust. As it came to me, the exhaust was a downpipe that had been crudely hacked away by someone, who then fitted 2 sleeves and, with the help of exhaust paste/gum and a heavy duty clamp, bodged a short straight pipe on the end. All I've done here is welded it up and ground it down, closing up the holes and making it sort of look like it's one exhaust pipe. It may end up being too annoying / loud, but, for now, that's the exhaust done. Painted in a couple of coats of Hycote ultra high temp paint, and the fake "silencer" polished with a bit of metal polish.
https://i.ibb.co/yQkcbRk/exhaust-and-front-wheel.png |
pepperami |
Bhud |
Bhud |
Fisty |
Fisty Super Spammer
Posted: 17:10 - 24 Sep 2020 Post subject: |
3 are wrong.
I will leave you to find them......
____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
Bhud |
Bhud |
Posted: 18:20 - 24 Sep 2020 Post subject: |
Clutch cable replaced
New oil filter fitted
Oil strainer cleaned in petrol
Front inner tube and tyre fitted (after vaguely truing the wheel by eye, spinning it on a piece of metal tube)
New clutch plates (standard) fitted
Heavy duty clutch springs fitted
Kickstarter shaft seal replaced
https://i.ibb.co/27SfGhB/24-sept-stuff.png |
Poseidon |
Poseidon World Chat Champion
A100man |
A100man World Chat Champion
Posted: 23:03 - 24 Sep 2020 Post subject: |
Bhud wrote: | As much as I could, for now.
How old is your rusty rim ? Looks almost as bad as teh 45 year old one off my GT250! ____________________ Now: A100, GT250A, XJ598, FZ750
Bhud |
Whosthedaddy |
Whosthedaddy Super Spammer
Posted: 08:12 - 25 Sep 2020 Post subject: |
The little MSX125 will be getting new tyres front and rear, thankfully I removed the wheels and will be taking that to the shop rather than riding as its pi$$ing it down at the moment.
Last time I had new tyres on this bike I managed to low slide when grabbing the brakes on the wet greasy roads ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
pepperami |
Posted: 09:39 - 25 Sep 2020 Post subject: |
I should put this in “Grinds My Gears”.
Bought a few bits for ‘Project Scrappy Hyosung’ and I have four days off work.
However I have things to do and that means no working on bikes .
At least I get to clean it’s little screen today, maybe even run a clean cloth over the seat!
It might not be fixed, but a least it will be clean
EDIT : done. ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Fisty |
Fisty Super Spammer
Posted: 16:18 - 26 Sep 2020 Post subject: |
The busa...
Fitted ductile iron discs, Brembo RCS Brake master cylinder, clutch master cylinder andy dinky reservoirs with carbon lids.
It now stops like its hit a wall.
https://i.imgur.com/GkqmKoK.jpg?1
https://i.imgur.com/mJTutUT.jpg?1
I will sort better mounts over the winter.
Took it for a test ride then lubed the chain. Still didnt get any omn the rear tyre. ____________________ Quietly and consistently taking the piss.
P. |
P. Red Rocket
Posted: 16:49 - 26 Sep 2020 Post subject: |
https://i.imgur.com/hn3fq8n.gifv |
MarJay |
recman |
recman World Chat Champion
NJD |
Posted: 17:55 - 28 Sep 2020 Post subject: |
Installed some heated grips.
Spent forty-thousound years attempting to figure out why the throttle was not as snappy as it should be, and then narrowed it down to an excess of glue and a small plastic circular piece I'd put back between the grip and housing (god knows why it was there in the first place). And then another four hundred years doing some cable management and ensuring it behaves as it should.
Test ride that will throw me into a hedge en-route.
https://i.postimg.cc/TwxdRG41/gripo.jpg ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
The last post was made 3 years, 209 days ago. Instead of replying here, would creating a new thread be more useful? |
