KMX125 Cutting out when warm
Captain Liberious
PostPosted: 07:16 - 22 Mar 2013    Post subject: KMX125 Cutting out when warm Reply with quote
Hi fellas,
I've got a KMX125 field bike that runs great until its warmed up, then it cuts out and wont start again for a few minutes.
I think this may be down to a faulty ignition coil, I was wondering if anybody knew how much resistance these should have?
I'm reading around 17000ohms when cold, I've got it sat on a heater now but cant see any noticeable increase in resistance.
One thing thats strange is that the bike will start easier if I pop the choke on, which is weird seeing as the engine's hot. Get it to rev once and I can knock the choke off and it'll run fine for a couple of minutes then bog down and cut out again.
The bike was definently running lean, could this have affected it in this way?
I've got some sealant setting on the inlet manifold which was perished, and I've sealed up the hole from the oil pump which I dont use, so that should hopefully cure that problem.
Any thoughts very welcome!
A squid eating dough in a polyethelene bag is fast and bulbous, got me?
Ariel Badger
PostPosted: 10:36 - 22 Mar 2013    Post subject: Reply with quote
Fuel tank vent blocked, run it with the cap off.
Compo
PostPosted: 13:46 - 24 Mar 2013    Post subject: Reply with quote
Primary Coil Resistance ( Conector to connector ) Should be measure on the x1k range and give between 0.153-.0207
Secondary Coil Resistance connect between ht lead ( Spark plug cap off and terminal that would have the black/yellow lead ) Should give you 3.84 -5.76
The last post was made 13 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.44 - MySQL Queries: 14 - Page Size: 35.91 Kb
