Heated gear on sale at Maplin
PostPosted: 15:03 - 30 Mar 2013    Post subject: Heated gear on sale at Maplin Reply with quote
Heated hat tip to trikeschick for the info, Maplin are "end"-of-Winter selling off electrically heated gear including fleece vest (£7), insoles (£4) and gloves (£4).
It's battery powered stuff, using 3xAA cells per unit. The vest has 2 units = 9V though, and 10 minutes of hack-and-tape had them wired in serial into my bike electrics. Surprisingly little scorching of nipples has occurred.
ExclamationExclamationExclamation SOME SCORCHING OF NIPPLES HAS OCCURRED AT 14V+ WITH A THIN MERINO UNDERSHIRT. ExclamationExclamationExclamation
The pads only cover the upper chest, but it's decently cosy just as a vest. Very pleased, slightly moderately at risk of catching on fire. Thumbs Up
carlosthejack...
PostPosted: 15:07 - 30 Mar 2013    Post subject: Reply with quote
Really stuck for which Karma to award, nearly all would have been warranted. Thumbs Up
Kai.Wilson
PostPosted: 17:23 - 30 Mar 2013    Post subject: Reply with quote
Could you post up how to connect to bike wires?
PostPosted: 18:41 - 30 Mar 2013    Post subject: Reply with quote
Wire in a 12V lighter socket (fused, relayed ideally), and a lighter plug with two wires.
Cut the battery boxes off of the 2 vest packs, leaving you 2 female plugs with 4 wires.
Wire the two female plugs in series, i.e. one after the other. Exclamation For the love of your nipples, don't wire both of the +ve and -ve wires straight into the +ve and -ve from the bike. Exclamation
The +12V red wires in this totully prufeshnul diagram are actually black-and-white in the real world.
https://i.imgur.com/E1yxdua.png
Adding a resistor inline is strongly advised. It should be... some... Ohms.
Also, don't do this at all, it's very silly and will likely end in death, best case.
covent.gardens
World Clap Champion
PostPosted: 18:58 - 30 Mar 2013    Post subject: Reply with quote
Y'know, at that price I might just buy some.
doggone
PostPosted: 19:03 - 30 Mar 2013    Post subject: Reply with quote
super diagram, should have been labelled Vest of Scorchio though
covent.gardens
World Clap Champion
PostPosted: 23:52 - 30 Mar 2013    Post subject: Reply with quote
Did buy some.
Any recommendations for suitable waterproof plugs/connectors that I can easily add to each end of the wiring so as to be able to quickly plug in and unplug? I only have spade terminals, which would work (until they rusted anyway) but they're not ideal.
Pete.
PostPosted: 23:58 - 30 Mar 2013    Post subject: Reply with quote
Thanks Roger - getting the gloves before my knackered finger falls off. I'm working at night and suffering badly from the cold.
a.k.a 'Geri'
Ichy
PostPosted: 00:55 - 31 Mar 2013    Post subject: Reply with quote
Any idea what wattage?
A 7809 voltage regulator and two .1uf capacitors will cost about £2 and will give a steady 9v from 12v but is only good for about 1 amp so 12 watts.
I've ordered the gloves and fleece to try out.
PostPosted: 01:34 - 31 Mar 2013    Post subject: Reply with quote
About 2nd degree.
colin1
Captain Safety
PostPosted: 01:42 - 01 Apr 2013    Post subject: Reply with quote
Anything designed to run with AA batteries is going to be very low wattage, and wiring it up to the bike isnt going to change that. My mum gave me something similar a few xmass ago (gloves) and they were useless. I returned them and got a nice bodywarmer instead.
Ichy
PostPosted: 08:49 - 01 Apr 2013    Post subject: Reply with quote
Good point although a decent AA battery will do 2.4amps. Given that, and the fact that they are supposed to run for 2 hours, 1 amp output should be about right.
Tried it with the voltage regulator yesterday and it was nice and toasty with another coat over the top.
The last post was made 13 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 80.89 Kb
