Oxford heated grips and bar end weights
cimbian
PostPosted: 22:14 - 31 Mar 2013    Post subject: Oxford heated grips and bar end weights Reply with quote
I've just fitted some heated grips to my TA but even cut-down to their smallest they still overhang the end of the bars by about 1/2 inch.
I removed the built-in bar weights as I'd planned to fit external weights to cover the open-end of the grips but the end weights will not reach.
The left-hand weight will just about fit but no-way on the throttle-side as it will bind.
Because the TA is a v-twin it is very buzzy in the hand so needs the weights and there's a bleedin'-great hole in the ends that needs capping.
Any ideas?
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
andi
PostPosted: 07:55 - 01 Apr 2013    Post subject: Reply with quote
would a spacer be any good? I could turn a pair in stainless if you can provide sizes?
Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929
Ichy
PostPosted: 08:18 - 01 Apr 2013    Post subject: Reply with quote
Can you not move the switchgear inwards a bit? Spacers would work.
cimbian
PostPosted: 08:30 - 01 Apr 2013    Post subject: Reply with quote
Thanks guys.
Itchy, there is no room to move further inwards.
Andi, thanks. I will try J&S today to see if they have anything standard but I may-well take you up on that. Thumbs Up
Edit: Been over to J&S and got some nice heavy stainless ends that have quite a long shank.
Will wait until tomorrow to hear from Oxford but I reckon I can cut-off the soft rubber overhang as I think the heating element is based on wires wrapped around the plastic-core-tube. If that is the case I should be okay.
Seems to me there is a market for end-bars that contain a bearing so can rotate with the throttle-grip. Thinking
Bloody handlebars are so buzzy now!
22PlusY
cimbian
PostPosted: 09:42 - 02 Apr 2013    Post subject: Reply with quote
Well, the good news is that I received a reply from Oxford this morning confirming that I can cut the grips down to 112mm (basically to the plastic liner) without damaging them so will take a look at this today and, hopefully, have a workable solution. Smile
22PlusY
The last post was made 13 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.38 - MySQL Queries: 14 - Page Size: 44.91 Kb
