Newb123 |
Newb123 L Plate Warrior
Posted: 21:09 - 03 Apr 2013 Post subject: Engine dies when clutch is released!?? |
Hi folks
After too many years on 4 wheels, I finally made the jump.. and already I have tech issues!
I just bought a Kawasaki Eliminator Bn125 (waits for the laughter to subside... hey, I like it!) which unfortunately spends much of it's time sitting around under a cover, due to work. It was serviced and MOTd (I'm told) just before I took hold of it and up to now has started and ridden very nicely.
Having had some decent weather I started it up this morning, started fine with a bit of choke and idled well. After a good warm up period I went to pull away but as soon as I released the clutch the revs died and so did the bike! It doesn't matter how much you rev the throttle, as soon as you release the clutch it fades and dies. I'm not stalling it I can assure you, a mate has tried it too and he's been riding for 30 odd years.
The kickstand switch has been bypassed by a previous owner, I've moved the bike around and the brakes aren't binding, it revs fine, starts fine, idles fine.. but it cuts out as soon as you release the clutch! There is no spluttering or anything either.
Does anyone have any experience with this type of thing?
Any help would be hugely appreciated. |
That_Hornet |
That_Hornet World Chat Champion
whitedevil |
whitedevil World Chat Champion
Newb123 |
Posted: 21:36 - 03 Apr 2013 Post subject: |
Thanks for your time J4ck
It's not actually spluttering, it just cuts out. Doesn't lurch forward like it would if I stalled it (I know that feeling too well!).
The best way I can describe it, if you give it plenty of revs and then partially release the clutch then squeeze it again it sounds as though you're throttling on and off, if that makes any sense? But if you fully release the clutch, the bike doesn't even move forward, it just dies.
The bypass looks pretty solid and as you say, it continues to run fine when you select 1st gear. I've tried pulling away in 2nd too as a process of elimination but that was the same.
I hadn't ruled out a fuel issue from experience with car engines. I'd be unsure where to start with a bike though in all honesty! |
shereen |
shereen World Chat Champion
Newb123 |
shereen |
Newb123 |
Posted: 22:02 - 03 Apr 2013 Post subject: |
yen_powell |
yen_powell World Chat Champion
shereen |
Posted: 12:23 - 04 Apr 2013 Post subject: |
Newb123 wrote: |
Yes it does! |
At the other end of this cable you'll have a locknut. Turn the screw/bolt and you'll notice the freeplay going up or down at the clutch lever. Turn it a little at a time as a couple of turns can make a big difference. ____________________ "The Internet is the first thing that humanity has built that humanity doesn't understand, the largest experiment in anarchy that we have ever had" |
whitedevil |
Newb123 |
Posted: 13:04 - 04 Apr 2013 Post subject: |
Hey guys, all sorted!
Yen_powell, I missed your post last night, apologies! I wasn't aware there was a kill switch on the clutch lever too. A bit of creative wiring and Bob's your mother's brother, no more issue!
Thanks very much to all of you, really appreciate your time. |
The last post was made 11 years, 22 days ago. Instead of replying here, would creating a new thread be more useful? |
