map |
map Mr Calendar
tatters |
tatters Exxon Valdez
Posted: 13:04 - 15 Jun 2004 Post subject: |
neutral light is not needed for MOT but check the connectors at the dash and the gearbox rust and erosion can make a high restance on the connectors and a electrical connection will not be made, just clean the connector with some sandpaper and if the crimp is loose on the connector squezze it tighter with a pair of pliers l get it all the time on my vfr ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650 Present:G650XC,C12,KZ750,1190ADV |
Jammy-G |
Jammy-G Banned
dibbster |
dibbster Nearly there...
Posted: 13:50 - 16 Jun 2004 Post subject: |
Just a few questions.
Does the horn work?
When main beam indicator on dash didn't come on was the speedo light on the dash on?
Is there a good connection to the frame from battery?
Do the brake lights work?
I think rear light and indicators may have been dull in first case due to low battery? when you swapped flasher units back only indicators were on so less load on the battery and therefore brighter.
There is a connector that the rear light branches out from (brown wire[i think] ) and a wire that feeds horn and a connector where front light branchs out of (green wire[i think]) It could be worth checking the connectors to make sure there is a good contact.
Also check the sidelight bulb, i had a problem where the sidelight bulb was shorting out stopping the headlight/tail lights from working.
Hope that is of some help. ____________________ Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's
www.bikepics.com/members/dibbster |
map |
map Mr Calendar
map |
map Mr Calendar
Posted: 09:39 - 17 Jun 2004 Post subject: |
Now have Haynes manual with the circuit diagram.
Appears all the green wires should be tied down to earth (the frame). However, looking at the loom it looks like other colours have been patched in
Still looking for any suggestions where to start looking into this. Ta. |
dibbster |
dibbster |
Posted: 23:29 - 02 Jul 2004 Post subject: |
Haven't got back to you as been away on holiday.
Have you managed to sort out the electrical problem? ____________________ Suzuki RF 600 - The two wheeled Testarossa (Deceased)
The last post was made 19 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
