| Fladdem |
 Fladdem World Chat Champion
 Posted: 12:47 - 27 Apr 2013 Post subject: Honda MT50/H100 project |
I posted this in offroad and supermoto then thought that here was probably a better place for advice on this sort of thing.
Hello all, I'm currently ruining a Honda MT50, I have the engine, exhaust, carb, air filter but I still need the CDI for the H100 engine. I also have upgraded shocks on the back and a jack-up kit, I also have some MTX125 forks and drum braked wheel to go on the front. I'll be giving it a new paint job as well eventually. I would like to get a h100 wheel for the back too, as it is 18 inch rim compared to the 50's 16 inch, it will fit as the MB50 shares the same swinging arm which has an 18 inch rim. My question is just wondering what the H100 spindle diameter is? I was just wondering if the spindle will fit in the swinging arm without any hassle. Another problem is the MT5 expansion chamber is rusted to the engine and the exhaust studs are rusted up, its just a block of rust down there, I need to remove the exhaust before I can drop the engine out and I want to keep it undamaged as I want to keep all the original parts with the bike if I need to go back for some reason, How will I get the exhaust off? Another thing is; the back-end will be three inches taller than standard with the new wheel as well as the suspension but the forks are 6 inches longer so the front end will be 7 inches taller with the wheel as well, I am aware this will make turning awful, will dropping as much fork through the yokes as possible help to counter-act this a bit?
Any advice on any of these things will be much appreciated,
Adam
P.S. This has been planned for two years, I know it would have been easier and cheaper to have bought an MTX80, same size and the same power as mine will be when it’s done, but I want to do this, so please no “Buy another bike” like I always get when asking for help. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 07:36 - 29 Apr 2013 Post subject: |
shouldnt make too much difference to the handling, it'll be different to the h100 but you'll get that when you ride any dirt oriented bike
as for the spindle size wemoto says the rear bearings are 12x37x12mm
so a 12mm spindle and also the mb/mt50 has the same size bearing so that should pose you no problems,
exhaust, i might be easiest just to buy a nut cracker and break the nut off the post so you can slide the exhaust off, rather than risk breaking the post it self,
once the exhaust is off you can make an informed decision on whether to replace the posts, or just clean up the thread of the original posts
make sure you do a build thread in the show and tell section ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| truslack |
 truslack World Chat Champion
| Fladdem |
 Posted: 22:07 - 29 Apr 2013 Post subject: |
Thanks for getting back to me. Are you saying that I could probably use an SJ wheel with a 12mm spindle so long as the bearings fit around? I suppose I could just get a wheel, try it and if it doesn't work sell it on again or have a play on the swing arm.
With the exhaust studs I have new ones anyway, so I just need to get the old studs out then swap engines round which is puzzling me, when I get a chance I'll take some pictures of the studs to show you. I'm in no rush to do the build, I was thinking of just putting the engine in first before playing about with wheels and suspension and bodywork and what not.
I'm still planning but once I'm ready to go, with all the bits, probably in the summer, I'll start up a build thread. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| truslack |
| Fladdem |
 Posted: 22:26 - 29 Apr 2013 Post subject: |
I make it 200mm, but it's not very accurate as the wheel is still on, I'm not gonna start taking it apart tonight.
I reckon that seems like a good idea, I'll begin the hunt for parts right away. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| truslack |
| Fladdem |
 Posted: 19:28 - 30 Apr 2013 Post subject: |
I've been eyeing up that wheel for a while now, when I first decided to get a bigger wheel on the back of the slow-ped.
I would have used an MB5 wheel but it isn't spoked like the h100 wheel.
Thanks. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
The last post was made 12 years, 286 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.54 - MySQL Queries: 14 - Page Size: 61.66 Kb
