Wonko The Sane |
Wonko The Sane World Chat Champion
Posted: 08:44 - 06 May 2013 Post subject: why does my ZZR fuel gauge not work? |
Finally got out on my ZZR yesterday evening and it's all good
although, for some reason since I bought it the fuel gauge isn't working (it worked after the first time I took the tank off)
so I have absolutely no idea how much fuel I have, nor how far I can get before i need to re-fuel. (so other ZZR owners, how far can you get on a motorway run when taking it easy?)
any ideas?
ta ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
Polarbear |
Polarbear Super Spammer
Ilyin |
Ilyin Renault 5 Driver
Wonko The Sane |
Ilyin |
Wonko The Sane |
moppy |
moppy World Chat Champion
Cheeseybeaner |
Cheeseybeaner World Chat Champion
Posted: 10:53 - 06 May 2013 Post subject: Re: why does my ZZR fuel gauge not work? |
Black Sheep wrote: | Finally got out on my ZZR yesterday evening and it's all good
any ideas?
ta |
I take it the fuel warning light still comes on? If so I'd assume you'd probably have about a gallon or so left at that point to go and find yourself some more juice. Personally I reset the trip meter every time I fill up the bike so I know how far I roughly have left, after a few tankfuls you'll get a fair idea of the distance you can travel before your warning light comes up.
Not familiar with the sender unit on the ZZR but its possible for the pickup contacts to wear and break off, or even for the float arm detach itself or move the little pickup cam to the side (which results in poor contact) if its a loose fit which will give you no readings. If you pull out the sender unit from under the tank you should be able to see what's going on. They are fragile things however which play up quite often on bikes.
Also try playing around with the lead a bit and maybe dose it with some wd40 inside.
If you have a reserve tap though its not that big a problem. ____________________ My bikes: 2003 KAWASAKI ZRX1200R, 1996 YAMAHA DIVERSION XJ900S |
Wonko The Sane |
P. |
P. Red Rocket
Wonko The Sane |
johnsmith222 |
johnsmith222 World Chat Champion
Cheeseybeaner |
The last post was made 10 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
