| uk_kmx |
 uk_kmx Derestricted Danger
| bladerunner |
 bladerunner World Chat Champion
| uk_kmx |
| Boxing |
 Boxing World Chat Champion
| stevo as b4 |
 Posted: 17:12 - 09 May 2013 Post subject: |
I take it with the 13T front sprocket your going for acceleration and not top speed, seeing as they run 14/48T as std, and in full power form are a fraction undergeared for road only use in that they run into the red in top.
Is the bike in good condition, with good compression, and been properly maintained within accordance to the service/maintainence schedule? If so and it's full power I am quite surprised your not finding first and second gear wheelies reasonably easy especially with a 13T front sprocket. You can certainely wheelie in 1st/2nd on the KMX without needing the clutch, but it's down to preference. If your slipping the clutch near the red-line, I suspect it's more your technique that you need to work on and not the bike.
What exhaust system do you have? new expansion chamber and silencer or has just the silencer been changed?
The Gianelli system gives the bike the most top end power of the two available aftermarket front pipes, but for say an extra 0.8bhp-1bhp more at the top end your lose a lot of low down power compared to a std de-restricted pipe.
What airfilter or airbox mods have you done and what jetting are you running at the moment?
You can get around 27-28bhp (crank figure) or 23-24bhp at the rear wheel with some fairly easy tuning mods and a few aftermarket parts, reedblock, airbox mods, and a bigger 28/30mm Flatslide Mikuni. With light cylinder porting and skimming and re-profiling the head to raise the compression slightly you should manage around 30bhp the same as the 200cc engine that's in a lower state of tune, but with a far more peaky delivery and less usable power by comparison.
I personally think you can make a KMX125 go very nicely with some careful simple mods, as mentioned, and be happy with the performance. The 200cc conversion is an alternative route, but my preference would be to buy a complete 200cc motor and re-build that, instead of converting your 125 with a 200cc top end and all the hassle and different bits that you need to do it.
Lastly get some pics up of your KMX so we can see another example of one of the best 2stroke 125 trail bikes ever made.  |
| Compo |
 Compo Nova Slayer
| uk_kmx |
| bladerunner |
| Compo |
 Compo Nova Slayer
| uk_kmx |
The last post was made 13 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
