 SQL World Chat Champion
 Posted: 01:26 - 12 May 2013 Post subject: Voodoo Shango bike [FOR SALE] £150ono |
https://www.gumtree.com/p/for-sale/voodoo-shango-dirt-jump-bike-150ono/1018267699
or
Selling my Dirt Jump bike (Pedal Bike) as I no longer use it.
Good Bits
The paint isn't bad a few chips here and there
The gearing is great it allows you to get up to speed quickly and hold it consistant for a single speed
The brakes are immense you can stoppie on a penny (Spec of them Below)
Bad Bits
Needs new grips to put it nicely the grips are horrid
Maybe a new seat as it has seen better days
Rear tyre is a little low
https://www.voodoobikes.co.uk/bikes/dirtbikes/shango
<!---Insert Specs Here ---->
Alloy Rims: Yes
Approximate Weight (KG): 15.5kg
Brake Type: Hydraulic Disc (F&R)
Chainset: Black tubular 3 piece
Forks: Full Chromoly with disc mount
Frame: Dirt Jump Full Chromoly
Frame Colour: White
Frame Material: Full Chromoly
Front Brake: Tektro Gemini Hydraulic disc 180mm rotor
Gears: Single Speed
Handle Bars: Riser 31.8mm
Headset: FSA Impact 1 1/8 Aheadset
Hubs: Formula 36 hole disc hub
Pedals: Wellgo BMX Type alloy black
Rear Brake: Tektro Gemini Hydraulic disc 180mm rotor
Rims: Double wall black rear and green front 36 hole disc rim
Saddle: VL-7100
Seatpost: Satori Pivotal SC
Stem: Dirt Jump
Tyres: Innova 26 x 2.5
Wheel Size: 26"
Tyre Size: 2.5"
Exact Frame Size: 13"
https://www.thebikelist.co.uk/images/models/Voodoo/2011/voodoo-shango/voodooshango_360_0101.jpg
^ Its this model (Stock photo)
Looking for around £150 ono or maybe swap for something just try me
Pick up from Croydon
PM me  |
