Electrical Issue
GeordieChambe...
PostPosted: 13:48 - 19 May 2013    Post subject: Electrical Issue Reply with quote
Hey peeps, I've had an on going problem with my bike not starting immediately (usually have to turn ignition on and wait 5 mins then she starts Sad weird, i know lol)
Anyway due to being stranded and having to get her transported back home I decided to finally track down the Gremlin. I've checked the battery and all the switches and there fine but when I checked the starter switch wire I got loads of resistance (1400+) so I've worked backwards checking the wire and it's took me back to my CDI unit.
Now I know nothing about electrics, so my question is could my CDI unit be faulty and causing my bike to have the delayed starting issue.
Any help with this would be greatly appreciated Smile
Suzuki GZ125 (03) - March 2013, CBT - April 2013
Aff
PostPosted: 16:06 - 19 May 2013    Post subject: Re: Electrical Issue Reply with quote
So will it crank but not fire? Or does it not do anything for 5 mins?
Electric Bike Project
Andy_Pagin
PostPosted: 19:02 - 19 May 2013    Post subject: Reply with quote
Could be that the wiring has corroded internally, I had this with a Ford Fiesta, the +ve ht lead literally collapsed in a heap of rust when I jiggled it.
GeordieChambe...
PostPosted: 17:38 - 23 May 2013    Post subject: Reply with quote
Thanks for the replys, She's still in pieces in the garage while I've been running over her with a multimeter. I've disconnected the ignition switch and tested the ignition wire (orange/yellow) to the CDI and I'm getting loads of resistance (2600ohms).
I've then disconnected the wire from the CDI and checked both ends for continuity only to find there's no problem with continuity. WTF Sad Am I doing this right peeps????
Pete.
PostPosted: 17:51 - 23 May 2013    Post subject: Reply with quote
Can't imagine why the starter switch is connected to the CDi unless it's a signal used to retard the ignition for starting or something. If so, I would indeed expect it to have a high impedance.
You didn't answer the question - what exactly is delayed for 5 mins? Does it crank and not fire or just not crank?
a.k.a 'Geri'
GeordieChambe...
PostPosted: 17:56 - 23 May 2013    Post subject: Reply with quote
Lol sorry mate nah doesn't crank or fire just silence. Then after 3-5 mins clutch in hit start and she fired up.
Aff
PostPosted: 18:09 - 23 May 2013    Post subject: Reply with quote
Have you tried shorting the starter relay?
And can you bump start it in this 5 min delay?
GeordieChambe...
PostPosted: 18:13 - 23 May 2013    Post subject: Reply with quote
Yep shorted the relay and the starter motor spins
Aff
PostPosted: 18:14 - 23 May 2013    Post subject: Reply with quote
So starter spins when you bypass the relay, but it wont fire?
Same happen when you try and bump it?
GeordieChambe...
PostPosted: 18:16 - 23 May 2013    Post subject: Reply with quote
Yeah exactly the same mate
GeordieChambe...
PostPosted: 18:17 - 23 May 2013    Post subject: Reply with quote
and yes i doesn't fire either
Aff
PostPosted: 18:25 - 23 May 2013    Post subject: Reply with quote
The only way to really test a CDI is to replace it with a known good, but thinking logically this should work:
With the bike cranking (during your 5 minutes of nothing), the CDI should be receiving a voltage from the battery/stator to charge the capacitor, it should also be getting a signal from the triggers to release the charge to the coils, if you have this, then everything pre CDI should be OK.
There should then be voltage coming from the CDI unit to the ignition coils, if there is no voltage coming from the CDI unit to the ignition coils then the CDI unit is faulty.
If there is voltage entering the CDI then something after the CDI is broken.
GeordieChambe...
PostPosted: 18:55 - 23 May 2013    Post subject: Reply with quote
Thanks for that, when you say cranking does that apply to an electric start or a kickstart as my bike only has an electric start.
Aff
PostPosted: 18:57 - 23 May 2013    Post subject: Reply with quote
You will have to bridge your starter relay, so may need an extra pair of hands.
GeordieChambe...
PostPosted: 19:08 - 23 May 2013    Post subject: Reply with quote
Okay, will that not damage my bike if I keep it bridged for more than a few seconds?
Aff
PostPosted: 19:10 - 23 May 2013    Post subject: Reply with quote
Just crank it in 10 second bursts, and get ready to charge your battery. Laughing
GeordieChambe...
PostPosted: 11:53 - 26 May 2013    Post subject: Reply with quote
Right so finally got the time to test that previous comment and I am getting voltage to the ignition coil from the cdi but am now stuck on what I would check next. Anyone got any ideas???
Pete.
PostPosted: 11:59 - 26 May 2013    Post subject: Reply with quote
Shorting the relay only proves that the starter is working.
I think you have an electrical breakdown in a switch or connector. first I would check that the clutch switch is not sticking in, then I would check the run switch and probably clean the contacts, then I would check the fuses for corrosion then I would unplug the CDi and check the terminals for corrosion.
a.k.a 'Geri'
GeordieChambe...
PostPosted: 12:03 - 26 May 2013    Post subject: Reply with quote
Done all of them mate, the last tip I was told was to bridge my contacts then check voltage is getting to my ignition coil to make sure my CDI is working. So since I'm getting voltage at my coil I pretty sure the CDI isn't faulty, the only thing is I don't know where to go from here Sad lol
GeordieChambe...
PostPosted: 14:17 - 26 May 2013    Post subject: Reply with quote
Just out of curiosity where would the ground points be on my bike or does it only have one? As I can only find one Very Happy
Aff
PostPosted: 14:26 - 26 May 2013    Post subject: Reply with quote
Have you already changed the plug?
What condition is the HT lead in? and are you getting voltage all the way to the plug?
Do you get a spark when the plug is out of the engine?
Try running an earthed wire (with insulated gloves on) along the length of the HT lead/coil pack whilst cranking and see if you get any arcing.
GeordieChambe...
PostPosted: 14:49 - 26 May 2013    Post subject: Reply with quote
The plugs a spare I had under my seat and yes my multimeter is saying im getting voltage to the HT lead.
No I'm not getting a spark at all.
I don't have the earth wire or gloves to try that last part tho mate Sad
Aff
PostPosted: 14:56 - 26 May 2013    Post subject: Reply with quote
Is the plug a known good?
And what voltage you getting?
mentalboy
PostPosted: 15:07 - 26 May 2013    Post subject: Reply with quote
Does this problem occur every time you start her up or just when she's cold?
It does sound more like an electronics issue than a random electrical one ( by that I mean items that control electrical system rather than wiring/plugs etc.) Poor contacts/wiring are usually more random when they start to breakdown, but I'd try lubing all safety contacts (clutch, sidestand etc) first
Make mine a Corona.
The last post was made 12 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 133.5 Kb
