| Foran |
 Foran L Plate Warrior
 Posted: 18:41 - 10 May 2013 Post subject: Sudden loss of power while riding |
Hey there. A tad new to the forum so don't scald me if I get it wrong
I have an AJS Daytona 125, custom cruiser, 2010, and I've been riding for about three weeks now without any issues. Bike's only done 1500 miles and has been fine up to this point during my time with it, with one previous owner.
When I took it out this afternoon I was a tad more hasty than usual in getting it out the garage and didn't let it warm up which I usually do.
I got it on the road for about 2-3 minutes, vastly down hill, until I hit a slight gradient uphill and the bike simply lost power and cut out when it stopped. I geared down straight away, though it was like I had my foot on the brake. I was forced to pull over and wait by the road side as I was fiddling with the choke trying to get it started.
After about five minutes of trying to start it, I managed to get it going again on half choke. Whenever I tried to start it it just wouldn't catch, almost, but didn't. After five minutes I did manage to get it going again and once it was it was fine.
Yet again, this evening it stalled twice, once going up a slight pitch, then about 10 minutes later going up another one on the way back. Exactly the same deal, just lost all power even though I was throttling it up and gearing down.
I did notice, on the third time however, that before I actually lost all power it was starting to pull back, more and more until I hit the hill and I lost power. To get it started again I kept trying different levels of choke, half, more than half, then in the end after a number of tries it started on half, like the other two times.
Does anyone have any ideas? Anything is appreciated. Maybe I need to leave the choke on a bit longer? Maybe I need to warm it up for a bit longer before I get it on the road?
I am a novice but already love riding. Thanks again.
George. |
| Copycat73 |
 Copycat73 World Chat Champion
| Foran |
| andy_uk |
 andy_uk World Chat Champion
| Foran |
| Scotsman37 |
 Scotsman37 World Chat Champion
| Foran |
 Posted: 22:33 - 10 May 2013 Post subject: |
| Scotsman37 wrote: | If the electrics are working ie lights come on and the horn works, etc, try another spark plug to see if it is starting to fail because that happened to me many many years ago on a 125cc
Another possibility is that your carbs have got crap in them and you're getting fuel starvation because you mention after opening up the throttle to go up hill shortly afterwards you lose power when you open up the throttle ie your engine isn't getting enough fuel when being driven harder! Your bike sits for a while allowing the carbs to refill very slowly, but as you apply hard only throttle not enough fuel filling the carbs in time then the engine starts to die! |
That would make sense - fuel starvation. I also noticed that, past the fuel switch to set main tank, reserve, and shut, there is a small, plastic cylinder, possibly some kind of filter(?) Could this be the problem do you think? It looks pretty run down and worn from the outside, though I'm not sure what they're called to replace them... |
| Ariel Badger |
 Ariel Badger Super Spammer
| Scotsman37 |
 Posted: 10:24 - 11 May 2013 Post subject: |
| George Foran wrote: | | Scotsman37 wrote: | If the electrics are working ie lights come on and the horn works, etc, try another spark plug to see if it is starting to fail because that happened to me many many years ago on a 125cc
From your pic I can see it is an inline fuel filter which makes me think either it is clogged up with rust particles or the previous owner installed it knowing/suspected it had an internally rusting fuel tank? I do hope if the previous owner did have problems with the carbs it was cleaned out and the inline fuel filter was installed at the same time to prevent further clogging of the carbs.
Inspect the filter to see if it is clogged up with rust particles and, if so, rinse it out & dry it out before re-installing or replace, and I would keep an eye on it from now to see if more rust particles accumulate over time because the fuel tank may need to be removed to be cleaned out properly with a special liquid solution that eats away the rust.
Inline fuel filters come in different sizes to fit particular internal diameter sized rubber tubes to it, but also the amount of fuel that flows through it too. So your bike is 125 and you can use small/average size one except the large one is for the bigger cc bikes. Remember the fuel tank has its own internal filter (good at catching the bigger pieces of rust/crap not the very tiny ones) located at where the fuel comes out (above the fuel valve control switch) which is usually held in by 2/3 screws, but if you do want to check to inspect for rust particles and/or it to clean out make sure you empty the fuel tank first as you don't want gushing fuel over your engine especially if it is very hot!
https://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313.TR0.TRC0&_nkw=inline+fuel+filter&_sacat=0&_from=R40
Personally, I always tie wrap the tubing connected to the inline fuel filter to prevent any possibility of it slowly popping back out from either vibration overtime causing the rubber tubing to slacken off or being accidentally pulled out. |
| Fozz |
 Fozz L Plate Warrior
 Posted: 15:00 - 13 May 2013 Post subject: |
Mine kept doing the same thing..... I filtered all my fuel out and then swilled out the rust and crap that was in the tank, and haven't had a problem since ..... |
| Ilyin |
 Ilyin Renault 5 Driver
| Foran |
| flumpy7 |
 flumpy7 Could Be A Chat Bot
The last post was made 13 years, 41 days ago. Instead of replying here, would creating a new thread be more useful? |
