'95 600 Monster fuel line run.
jjdugen
PostPosted: 22:09 - 22 May 2013    Post subject: '95 600 Monster fuel line run. Reply with quote
Hi all.
I'm in the process of renovating a '95 600 Monster and need some input. Its been stripped to bare frame and all the years of clag and neglect put to rights. Engines back in, carbs fitted. Came to install the fuel lines. The line from frame mounted tap to the vacuum control unit makes a very tight loop just in front of the base of the vertical cylinder. It runs so close that it must be borderline dangerous as well as superheating the actual fuel. I'm of the thought that the vacuum control unit can be ditched and the lines run from the tank to tap to carb. Anyone else run into this?
The last post was made 13 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.92 - MySQL Queries: 14 - Page Size: 27.74 Kb
