Baotian BT49QT-9 running problems
C_peto
PostPosted: 14:29 - 27 May 2013    Post subject: Baotian BT49QT-9 running problems Reply with quote
I have recently purchased this bike and it was running fine but now it has developed a problem where it will not full throttle without choking and then dying. If i let off the throttle and then gently re-apply i can keep it running but it just will not go above half throttle. The bike idles ok a revs ok in low range. I have fitted a new carb, plug, checked the valves and changed oil but the problem still remains. Could this possibly be a problem with the fuel valve on the bottom of the tank?
C.peto
yen_powell
PostPosted: 14:53 - 27 May 2013    Post subject: Reply with quote
Baotians are famous for doing this sort of thing Shocked .
Did you make the name up?
Anyway, sounds like you make have a blocked or kinked fuel line. Fine until you ask the bike to speed up.
XT1200Z and a DR350 in bits
Az
PostPosted: 15:33 - 27 May 2013    Post subject: Reply with quote
Replace/clean the air filter, see if it makes a difference and report back. Thumbs Up
The last post was made 12 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.42 - MySQL Queries: 14 - Page Size: 34.82 Kb
