| GeordieChambe... |
 GeordieChambe... Renault 5 Driver
 Posted: 13:48 - 19 May 2013 Post subject: Electrical Issue |
Hey peeps, I've had an on going problem with my bike not starting immediately (usually have to turn ignition on and wait 5 mins then she starts weird, i know lol)
Anyway due to being stranded and having to get her transported back home I decided to finally track down the Gremlin. I've checked the battery and all the switches and there fine but when I checked the starter switch wire I got loads of resistance (1400+) so I've worked backwards checking the wire and it's took me back to my CDI unit.
Now I know nothing about electrics, so my question is could my CDI unit be faulty and causing my bike to have the delayed starting issue.
Any help with this would be greatly appreciated  ____________________ Suzuki GZ125 (03) - March 2013, CBT - April 2013 |
| Aff |
 Aff World Chat Champion
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| Vincent |
 Vincent Banned
| GeordieChambe... |
 Posted: 17:38 - 23 May 2013 Post subject: |
Thanks for the replys, She's still in pieces in the garage while I've been running over her with a multimeter. I've disconnected the ignition switch and tested the ignition wire (orange/yellow) to the CDI and I'm getting loads of resistance (2600ohms).
I've then disconnected the wire from the CDI and checked both ends for continuity only to find there's no problem with continuity. WTF Am I doing this right peeps???? ____________________ Suzuki GZ125 (03) - March 2013, CBT - April 2013 |
| Pete. |
 Pete. Super Spammer
 Posted: 17:51 - 23 May 2013 Post subject: |
Can't imagine why the starter switch is connected to the CDi unless it's a signal used to retard the ignition for starting or something. If so, I would indeed expect it to have a high impedance.
You didn't answer the question - what exactly is delayed for 5 mins? Does it crank and not fire or just not crank? ____________________ a.k.a 'Geri'
| GeordieChambe... |
| Aff |
| GeordieChambe... |
| Aff |
| GeordieChambe... |
| GeordieChambe... |
| Aff |
 Posted: 18:25 - 23 May 2013 Post subject: |
The only way to really test a CDI is to replace it with a known good, but thinking logically this should work:
With the bike cranking (during your 5 minutes of nothing), the CDI should be receiving a voltage from the battery/stator to charge the capacitor, it should also be getting a signal from the triggers to release the charge to the coils, if you have this, then everything pre CDI should be OK.
There should then be voltage coming from the CDI unit to the ignition coils, if there is no voltage coming from the CDI unit to the ignition coils then the CDI unit is faulty.
If there is voltage entering the CDI then something after the CDI is broken. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project
| GeordieChambe... |
| Aff |
| GeordieChambe... |
| Aff |
| GeordieChambe... |
| Pete. |
 Pete. Super Spammer
 Posted: 11:59 - 26 May 2013 Post subject: |
Shorting the relay only proves that the starter is working.
I think you have an electrical breakdown in a switch or connector. first I would check that the clutch switch is not sticking in, then I would check the run switch and probably clean the contacts, then I would check the fuses for corrosion then I would unplug the CDi and check the terminals for corrosion. ____________________ a.k.a 'Geri'
| GeordieChambe... |
 Posted: 12:03 - 26 May 2013 Post subject: |
Done all of them mate, the last tip I was told was to bridge my contacts then check voltage is getting to my ignition coil to make sure my CDI is working. So since I'm getting voltage at my coil I pretty sure the CDI isn't faulty, the only thing is I don't know where to go from here lol ____________________ Suzuki GZ125 (03) - March 2013, CBT - April 2013 |
| GeordieChambe... |
 Posted: 14:17 - 26 May 2013 Post subject: |
Just out of curiosity where would the ground points be on my bike or does it only have one? As I can only find one  ____________________ Suzuki GZ125 (03) - March 2013, CBT - April 2013 |
| Aff |
| GeordieChambe... |
 Posted: 14:49 - 26 May 2013 Post subject: |
The plugs a spare I had under my seat and yes my multimeter is saying im getting voltage to the HT lead.
No I'm not getting a spark at all.
I don't have the earth wire or gloves to try that last part tho mate  ____________________ Suzuki GZ125 (03) - March 2013, CBT - April 2013 |
| Aff |
| mentalboy |
 mentalboy World Chat Champion
The last post was made 12 years, 213 days ago. Instead of replying here, would creating a new thread be more useful? |
