Thundercat - Speedo stopped working after minor repairs
pehi
PostPosted: 09:22 - 20 Jun 2004    Post subject: Thundercat - Speedo stopped working after minor repairs Reply with quote
Hi all - Hi - I recently changed the oil and oil-filter in my '97 YZF-600 (Marketed as the Thundercat in Europe). After doing this (and misc other minor stuff - chain-tension, fluid-level checks etc), I tested all actions OK, then replaced the cowling. The next day I took it out, it worked fine for a short journey through town, but then when I got out onto the highway, after accelerating down the on-ramp, I noticed it was resting on 0 and the tachyometer was also inactive. Any idea where I could start looking? N.B: Rev-counter still works, and back-lighting still works - all normal diagnostic lights still work.
Thanks in advance
Pete
Lost in a world of sprouts.
Danny
Ask Me About Stoppie School
PostPosted: 19:51 - 20 Jun 2004    Post subject: Reply with quote
You checked the cable hasn't simply come loose?
pehi
PostPosted: 09:20 - 21 Jun 2004    Post subject: How can I "health-check" the cable? Reply with quote
Thanks, but the cable seems to be in place, I've tried disconnecting it from the speedo, walking the bike forward and seeing if the cable rotates, but it doesn't...
deputy
PostPosted: 16:10 - 23 Jun 2004    Post subject: Speedo Reply with quote
Have recently had similar problem with my bike. Initially discovered that the peg that locates into the speedo cable had worn down, go this fixed and then found that there is an oil seal on the wheel hub that has lugs that drive the speedo drive, this was a loose fit and was spinning in the hub.
paulthewitt
PostPosted: 19:40 - 23 Jun 2004    Post subject: Reply with quote
if the cable doesnt rotate the speedo cable may be broke.
The last post was made 19 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 17 - Page Size: 43.43 Kb
