KLE500 sputtering and stalling at motorway speeds
Vracktal
PostPosted: 21:05 - 01 Jun 2013    Post subject: KLE500 sputtering and stalling at motorway speeds Reply with quote
For the past couple of months, i've had an annoying fault with my 1993 KLE500. Riding around town and on windy roads it's generally okay, but getting on a motorway and riding it at around 70mph for more than 20 or so miles causes it to start spluttering and coughing.
Weirdly, when it does this, I can "cure" the spluttering temporarily by opening the throttle more, it'll magically run clear and fine again as I accelerate, but once I stop accelerating it'll go back to spluttering and coughing, with the power cutting out and in sporadically while it splutters.
Another thing is, if I pull off the motorway, it will either die completely as I close the throttle, or come close to dying, but after a few seconds I can fire it up and it'll run perfectly fine again, as long as I stay off motorways.
This also seems to happen more often on an emptying tank (less than half full) than on a full one. Although, even on a full tank I can make the problem happen by taking it up to around 100mph, which will immediately make the symptoms occur.
So far, the possible problems I can think of it being are:
1) Vapour lock?
2) Dirty carbs?
3) Failing pick-up coil?
Anyone got any ideas how I can nail down exactly what's causing this and fix it?
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
P.
PostPosted: 21:11 - 01 Jun 2013    Post subject: Reply with quote
What is your fuel taps set up? vacuum or completely gravity fed?
Vracktal
PostPosted: 21:19 - 01 Jun 2013    Post subject: Reply with quote
I believe it's vacuum fed, but on the tap I have the option to turn it to "PRI" which lets the fuel flow freely (tested with the tank off, fuel runs at a good rate)
Turning it to "PRI" when it's sputtering has no noticeable effect on the problem though. Should also mention I have checked the fuel filter and line to the carb, it's an inline filter type and doesn't inhibit fuel flow as far as I can tell. (tested this with the tank off too, when set to pri fuel runs through the filter and hose to where the carbs would be if they were connected)
Ariel Badger
PostPosted: 21:48 - 01 Jun 2013    Post subject: Reply with quote
Make sure that your tank is venting properly.
weasley
PostPosted: 21:49 - 01 Jun 2013    Post subject: Reply with quote
I know it's summer now (pfffffft!!) but this sounds like classic carb icing. Water in the fuel tank maybe? Unseasonable cold weather?
Or maybe float height?
dansp1
PostPosted: 21:51 - 01 Jun 2013    Post subject: Reply with quote
Sounds like carb icing, lots of Kawasakis used to suffer with it, does the bike have heater pipes on the carbs? if it does check they are still flowing coolant.
There are fuel additives that will stop it so you can find out for sure that that is what is occurring
dansp1
PostPosted: 21:52 - 01 Jun 2013    Post subject: Reply with quote
must type faster Smile
Nexus Icon
PostPosted: 23:13 - 01 Jun 2013    Post subject: Reply with quote
It hit 22 degrees here today. No one is getting carb icing.
More likely vapour lock. As Ariel suggested, check the vent in the filler is clear.
Does it hissssssssss when you open the filler cap?
Greetings from Shitsville!
dansp1
PostPosted: 06:50 - 02 Jun 2013    Post subject: Reply with quote
Carb icing is affected by humidity as well as temperature and we have had enough cold and damp days over the last couple of months i would have thought.
https://en.wikipedia.org/wiki/Carburetor_icing
If it were a blocked tank vent it wouldn't cure itself after a couple of seconds as quoted.
Vracktal
PostPosted: 11:11 - 02 Jun 2013    Post subject: Reply with quote
The problem is that if I slow down and stop, by the time I can get the fuel cap unlocked and open, it's running fine again.
Will do some test runs with a key in the tank cap so I can open it faster today though... hmm...
Also will feed it some Silky PRO FST since it can't hurt either way.
Vracktal
PostPosted: 12:57 - 04 Jun 2013    Post subject: Reply with quote
-UPDATE-
Okay, so ordered some FST Pro, while I was waiting for it to arrive I decided to take the bike to the shops - only it refused to start at all. Engine turned over, but wouldn't catch.
Swore a lot, stripped off all my bike gear and prepared to walk, only just before I gave up, decided to give it one last go (about five minutes after I last tried) and it started fine. No trouble at all.
After that it ran fine. Took it to the shops and back, even made a 35 mile round trip on motorways to collect a tyre, cruising at 70mph with no issue whatsoever.
Hopefully the FST Pro will arrive tomorrow, so will throw a 2% dilution into the tank and fill it with premium juice just as a bonus. If that doesn't work and the problem comes back will strip the carbs down, clean everything with a toothbrush and a microscope, take them to be professionally balanced and set up, and see if that cures it.
P.
PostPosted: 13:07 - 04 Jun 2013    Post subject: Reply with quote
What colour is your spark.
Also, have you taken the tank off and removed the fuel tap..
cb1rocket
PostPosted: 15:26 - 04 Jun 2013    Post subject: Reply with quote
Classic symptom my bros was doing. Tank vent was blocked. Splutter at motorway speeds and dies. Leave for a few minutes and it will restart ok
Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852
Fizzer Thou
PostPosted: 15:50 - 04 Jun 2013    Post subject: Reply with quote
The easiest way to test for a blocked tank breather is to support the tank off the bike and to drain petrol into a measuring container.Time the amount of fuel that it takes to get to a measured level and see if it slows after a few minutes.Then do the same test with the filler cap open.
I suspect that the CV carb slides are sticking,especially as this only seems to be happening once the slides will have opened ie. above 4-5,000 rpm.Ensure that the diaphragms are seated correctly and that the very small 'O' rings that go between the carb top and the body of the carb are not split.Clean the slides with WD40 and the inside of the carb with cleaner.Fuel residue can build up after some time and cause the slide to stick.Then,once the carb has cooled,the spring will push the slide back to its seated position.
Carbs are easily cleaned and balanced.It does not need to be done 'professionally'.
Always have a 'Plan B'
unitynotsocri... This post is not being displayed because the poster is banned. Unhide this post / all posts.
Vracktal
PostPosted: 16:59 - 17 Jun 2013    Post subject: Reply with quote
Time to update this thread
So far, i've swapped the carbs for a pair that I know work fine, are clean and in balance, as well as cleaning all the pipes including overflow pipe, breather pipe and main fuel pipe. I also swapped the fuel tap for one I know to be good. I've changed the ignition coils and checked the airbox and air filter. I also filled it up with BP Ultimate + a 1.5% FST mix.
And it still does it. Not only that, but now sometimes at startup from cold it does it as well. I'll start it up, and it'll be sluggish to rev and splutter, and won't rev past 6k. If I ride it, it'll behave like the original symptoms for a while, and then after about a quarter of a mile or so it'll suddenly stutter a bit and run completely fine. Once it's done this it'll behave as long as I keep under 70mph.
I made a video showing the difference between running from cold, and running after a ten minute ride. The exhaust note is different, and sounds laboured, and won't rev properly until i've taken it out for a ride.
https://youtu.be/gY6OpsXYfJQ
cb1rocket
PostPosted: 21:27 - 17 Jun 2013    Post subject: Reply with quote
Is there a fuel pump on this?
Irn-Bru
PostPosted: 21:59 - 17 Jun 2013    Post subject: Reply with quote
Nope. Very simple bikes, but judging from OPs sig he has not had much luck with them Surprised
Vracktal
PostPosted: 01:44 - 18 Jun 2013    Post subject: Reply with quote
After several beers pondering A thought has come to me:
I wonder if I could set it on fire and claim off insurance?
When I've put the tank back on i've never checked if the fuel was feeding directly from the tank to the carbs, maybe if the fuel pipe was getting a ubend in it like a toilet that could explain why it runs rough for a while, until i take it out for a ride and the engine being under load creates enough vaccuum to overcome this.
And then when i'm on the motorway maybe the engines trying to draw down fuel so fast that the ubend is enough to interrupt the fuel flow makin it stutter at speed?
cb1rocket
PostPosted: 08:33 - 18 Jun 2013    Post subject: Reply with quote
try running with a separate makeshift tank, we def now know its fuel related
Vracktal
PostPosted: 19:26 - 13 Jul 2013    Post subject: Reply with quote
Resurrecting this thread because a month later and the problem is still there. Took the bike out for a ride, when I started out I noticed the throttle was lagging slightly, i'd wind on and it would take about a second for the engine to respond. This went away after about two or three minutes, so I kept going. After about four or so miles of 50-60mph riding the bike started spluttering and coughing as usual, as if it was running out of petrol. Pulled over, opened the tank cap while it was idling just to see if it was something breather related, but it just shut down alltogether. After that, it refused to start. I tried opening the choke full, and it would just about idle raggedly if I did that, but attempting to open the throttle at all would cause it to shut off.
In the end I had to push it home (well, most of the way, it's still about a mile away after I gave in to exhaustion and abandoned it.)
I really am at my wits end with this bike. Some days it runs without issue, although it feels slightly underpowered at all times, and other days it'll just be a complete shit.
The list of things checked so far=
Carbs- Cleaned thoroughly, balanced, checked that nothing is sticking open. Currently it's on the stock jetting, but it was running fine with these for years before the problems began so I can't think what would cause a change.
Spark plugs- Gap is correct, no fouling on the plugs
Fuel lines- Cleaned all of them, checked for kinks (none) and made sure there were no hose leaks.
Fuel tap- Checked flow was good
Fuel tank breather- Cleaned out with pipe cleaner.
CDi unit- Swapped over for a good spare I have from my other KLE.
Ignition coils- Swapped over for two nearly new ones from my other KLE, and double checked with a multimeter from cold, and again after running up to temp for ten minutes.
H/T Leads- Switched for clean, almost new ones from my other KLE.
Wiring- Checked for any breaks or fraying.
Also have been filling up with 98 and running a 1.5% FST mix, problem remains.
Out of desperation I might rig a transparent plastic bottle fuel tank as suggested earlier and see if I can replicate the fault, problem is it's so intermittent I can never pin it down when I want to observe it.
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 132.67 Kb
