big2dave |
big2dave Scooby Slapper
Ian (GPX) |
Ian (GPX) Brolly Dolly
big2dave |
Kickstart |
Kickstart The Oracle
Posted: 23:42 - 20 Jun 2004 Post subject: |
You do not need to take the wheel off.
The calipers are held on with 2 bolts. Undo these and take one caliper off. Take off the cap from the master cylinder. Push the pistons back in the caliper. Watch out for fluid coming out of the master cylinder (especially as brake fluid removes paint).
I think the GPX calipers are the same as on the GPZ500, or at least very similar. In which case the pad that is on the piston side of the caliper should pop out quite easily. Then push the carrier (the bit the caliper slides on, and which holds the other pad) as far into the caliper as possible. It should then be possible to unhook the other pad.
Ian (GPX) |
The last post was made 19 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
