 antoniolozada L Plate Warrior
 Posted: 16:25 - 03 Jun 2013 Post subject: wr250F Carb drip |
I'm having a carburator leak at the Float chamber
I try tighting it all 4 nuts with no results
How can I solve it with out geting the whole carb kit that is not available in this part of the world  |
 Posted: 20:47 - 03 Jun 2013 Post subject: |
The fuel shouldn't be that high up anyway.
If it's leaking round there either your needle valve is failing to seal or the float height is wrong (possibly a punctured or stuck float).
Firstly, I would give the carb a few sharp taps with a piece of wood, this can free off a stuck float.
If that doesn't work, I'd take it apart and check the needle valve and float for signs of damage.
Do not tighten the screws any further, you'll strip the threads. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
