bikerestorer |
bikerestorer Two Stroke Sniffer
Posted: 19:32 - 03 Jun 2013 Post subject: Charging fault, strange! |
Hi People, havent posted for a while but i have a charging problem i cant sort out, i need help.
I have an XR 125 honda year of 08 model L6
Problem i have is battery wont charge and all parts are good? have changed generator, rectifier, battery, and ecu but still the battery discharges when you rev up??
I swapped the engine so new generator coils etc from a known good bike, from the same bike i also swapped the rectifier and battery and ecu as the doner bike was charging fine but still i have the problem, any ideas? i am allout of ideas.
Steve
J.M. |
J.M. World Chat Champion
bikerestorer |
Fizzer Thou |
bikerestorer |
lihp |
lihp World Chat Champion
Posted: 19:45 - 03 Jun 2013 Post subject: |
Your name is quite ironic ____________________ covent.gardens: lihp is my most favourite member ever |
J.M. |
bikerestorer |
Fizzer Thou |
bikerestorer |
bikerestorer |
bikerestorer |
bikerestorer |
Fizzer Thou |
bikerestorer |
bikerestorer |
Fizzer Thou |
bikerestorer |
tomh |
tomh Scooby Slapper
unitynotsocri... |
unitynotsocri... Banned
Posted: 12:49 - 04 Jun 2013 Post subject: |
i'll put 10 % of my giro and go with Fizzer Thou on this,one green earth wire....somewhere............double check your control gear,genny ,loom and bits are correct.......then double check the wiring in the headlamp.............can be all to easy to shove the earths...greens...into each other except one of them greens is'nt a normal green ,as in to earth..........its a from earth.....as in the other side of the genny coils.....i.e. proper ground. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
Pete. |
Pete. Super Spammer
Posted: 15:08 - 04 Jun 2013 Post subject: |
I had a similar problem on my bike last year. It checked out fine on a meter but one of the loom connections in the earth circuit was breaking down under load. Drove me crazy until I found it.
Go-over all your loom connectors and if that doesn't help run a separate earth wire from the rectifier to the battery and one to the engine. That will complete the return-circuit for charging and at least pinpoint the faulty circuit. ____________________ a.k.a 'Geri'
bikerestorer |
The last post was made 11 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
