izzi81 |
izzi81 Could Be A Chat Bot
Posted: 17:13 - 21 Jun 2004 Post subject: NSR rear suspension |
Just took my NSR to be MOT'd, and it failed Mainly because the rear suspension has seized. I thought this sounded very bad, but apparently all that needs doing is to take the suspension apart, give it a clean, re-grease it and put it back together.
So.... where do I start with that! I don't have a Haynes manual, can I get the required info online? ____________________ "The problem with the French is they have no word for 'entrepreneur' " George W Bush
Age doesn't matter unless you're a cheese
https://www.bikepics.com/members/izzi81 |
mr jamez |
mr jamez World Chat Champion
Posted: 17:59 - 21 Jun 2004 Post subject: |
It is pretty easy
Their is a bolt that goes through the centre stand that holds the horse shoe shaped linkage on, so you will need to get the bike of the ground to remove that. The second linkage connects to the swing arm, and the shock absorber connects to the linkages and the frame. What year is the NSR? the bushings in the linkages will either be the roller pin bearings or just rubber bushes with metal inserts. Probably a good idea to check them out, they are about £70 for a set, ouch
I think the farings will have to be removed to get the shock off, again check the bushing.
If you need a new shock or linkages I have the lot, all with low mileage on it so is in good condition
Hope that helps |
izzi81 |
Posted: 20:57 - 21 Jun 2004 Post subject: |
its a 1993 model, so it's been around a while!
Thanks for the advice... hope I don't have to take the fairing off because that's always a hassle... ____________________ "The problem with the French is they have no word for 'entrepreneur' " George W Bush
Kickstart |
Kickstart The Oracle
McJamweasel |
McJamweasel BCF Junkie
Kickstart |
The last post was made 19 years, 313 days ago. Instead of replying here, would creating a new thread be more useful? |
