Brakes seizing in traffic
The Disapproving Brit
PostPosted: 17:20 - 05 Jul 2013    Post subject: Brakes seizing in traffic Reply with quote
If I'm in slow traffic where I'm having to use the front brakes a lot, it will start to stick, getting gradually worse and worse. Earlier this week, it got to the point where the front wheel was smoking by the time I could safely pull over.
I'm looking to change the brake fluid and pads at the weekend - is this likely to be all it is? It's an old VF400, so it's got the Honda inboard ventilated discs on it.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
m3-paul
PostPosted: 17:28 - 05 Jul 2013    Post subject: Reply with quote
Sounds more like the calipers need a refurb. Get new seals and clean up the pistons as start in my opinion.
Yamaha TZR250 - love the smell of TTS!!!!
CBR900RR Fireblade - so much fun
Quote Me Happy
PostPosted: 17:39 - 05 Jul 2013    Post subject: Reply with quote
At the very least pump out the piston and give it a good clean. Push it back in and repeat until it's moving better. If you're very careful you might be able to remove the seals, clean out the corrosion and crud behind and refit but based upon your post I'd be looking at doing a full rebuild.
Do it before they spit you off the bike.
Guzzirat
PostPosted: 18:32 - 05 Jul 2013    Post subject: Reply with quote
Check that the brake lever is letting the master cylinder piston return fully and that the piston itself is not sticking. If this happens then the fluid can't return to the reservoir and the brakes will bind as things heat up and expand.
Islander
PostPosted: 19:40 - 05 Jul 2013    Post subject: Reply with quote
All of the above and check that the calipers are sliding freely on their mounting pins. Don't leave this - if the brakes seize on when your moving at any speed then it'll spit you off.
PostPosted: 09:58 - 07 Jul 2013    Post subject: Reply with quote
Thanks guys...looks like she's having a good strip down and rebuild tomorrow then!
whitedevil
PostPosted: 12:40 - 07 Jul 2013    Post subject: Reply with quote
Also worth a mention that you should be using rear brake and clutch to control the bike a low speed. It takes a while to get the hang of it but when you do you will find the bike a lot easier to flick about.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
The last post was made 13 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.93 - MySQL Queries: 14 - Page Size: 50.89 Kb
