| reinax |
 reinax L Plate Warrior
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 15:40 - 06 Jul 2013 Post subject: |
It does sound like the points , although cleaning the carb bowl and checking the choke slide is'nt sticking can help .
Cos they are old you should check the needle jet is on the right central notch .
Cb100N engines are a direct swap out , having the two peice cyclinder head . Choose your spares carefully as the 125 j engine is a reworked 125s engine and has different components / specs .
What can help is a bible , when carried around all the time it will improve that cable disc 100% , or at least make you think about the afterlife to stop you getting too close to traffic . Good tyres are a must .The origional nylon ones will kill you in the wet . If you have little money then just have the best tyre on the front for improved braking .
the 125 j will take a lot of later honda cb/cg spares and chinese stuff , especially cg clones . The main problem is the points . ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| unitynotsocri... |
 Posted: 14:17 - 08 Jul 2013 Post subject: |
one tip that might help is NEVER turn the engine backwards when timing points , as most point models use a mechanical advance/retard mechanisim to ensure clean ignition timing .
Turning the engine backwards can upset the stationary springs that hold the timing cam . ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Fizzer Thou |
The last post was made 13 years, 113 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.02 - MySQL Queries: 14 - Page Size: 42.62 Kb
