| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 18:48 - 03 Sep 2013 Post subject: ZZR600 jerky front brakes |
My bike had a service a while ago and I asked the guy doing it what might be causing the jerkyness in the front brake. (present since buying it)
I've been told that it's probably just the disk not being perfectly flat but it's been annoying me lately so I'm wondering what can be done.
The calipers are the standard upgrade to the ZZR being nissin (think from a fire blade)
Should I start replacing rotors in the hope of resolving it or just get over it?
It doesn't affect braking performance, just not as smooth as could be when drawing to a stop unless you ease off and allow the rear to bring the bike to a stop. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| SteveZZR |
 SteveZZR Scooby Slapper
 Posted: 06:52 - 04 Sep 2013 Post subject: |
Use a socket to tighten a nut and bolt through the semi floaters and spray with brake cleaner as you do. Should sort it
And might as well get Nissins done whilst you're at it |
| Wonko The Sane |
 Posted: 07:00 - 04 Sep 2013 Post subject: |
It has nissins on and everything seems to be tight.
The mechanic checked everything over while fitting new pads during it's last service and couldn't find anything wrong which is where the conclusion that the rotor isn't constant thickness came from. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| ashfieldrob |
 ashfieldrob Derestricted Danger
| sickpup |
 sickpup Old Timer
| c_dug |
 c_dug Super Spammer
| garth |
 garth World Chat Champion
| SteveZZR |
| Wonko The Sane |
| Ariel Badger |
 Ariel Badger Super Spammer
| Wonko The Sane |
 Posted: 22:35 - 04 Sep 2013 Post subject: |
I don't know if he did or not, I was abroad while he was servicing my bike.
There were a number of things I was having him look into doing while he was servicing it but I presume he did.
What I understood from him was that my disk might have a slightly wider bit somewhere on it, but he could have been trying to explain run-out and I wasn't understanding.
My mechanical knowledge is classic car / old car based ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| Kickstart |
 Kickstart The Oracle
| Wonko The Sane |
| ZedPowered |
 ZedPowered L Plate Warrior
 Posted: 19:05 - 05 Sep 2013 Post subject: |
Did the bobbin release thing from the video on my ZX6R recently. Pretty sure they are the same discs. It does not take that much effort to move the bobbin so any bolt will be fine. I put a slither of red rubber grease on the bobbin to lube it a bit. Seems to have worked fine, got rid of my jerky braking.
PS i miss my ZZR. Such good bikes. ____________________ 2011 ZX10R in Green  |
| Wonko The Sane |
| SteveZZR |
| Wonko The Sane |
The last post was made 13 years, 71 days ago. Instead of replying here, would creating a new thread be more useful? |
