 deputy Scooby Slapper
 zzr_peak Renault 5 Driver
 Posted: 12:33 - 25 Jun 2004 Post subject: |
i'm not to sure as to where you can go to get them cleaned up cheap. but if it was me i would go and buy a bottle of metal cleaner and have a stab at it myself.
maybe a spray if they need it  |
 Ste Not Work Safe
 Posted: 22:05 - 25 Jun 2004 Post subject: |
You can do it yourself, it's basically how much you value the time and the end result done by a metal workshop will be better.
Get from B&Q or somewhere a bottle of paint stripper as that takes all the stuff like old paint and general crap off. Then comes the hard bit which is sanding/ rubbing them down with different levels of wet and dry paper. I can't remember what grade you should go down to but it's something like 1500 grade off the top of my head. This is going to take a long time, and you cut corners out of this step and you're messing the end result up basically. Then in a clean and dry place you can spray it with metal paint, then you'll need to put a coat of clear laquer over the top to protect it. You should be able to get more info about this if you're needing it, or with a bit of poking around on google.com for stuff on car paint.
Good luck and happy painting.  |
 divuk83 World Chat Champion
