CB1300 Won't Start........Again!
Renton
PostPosted: 19:39 - 26 Jul 2013    Post subject: CB1300 Won't Start........Again! Reply with quote
I had to leave my bike at work this evening because I couldn't get it to start.
The starter motor made a horrible noise as it was trying to engage but it just wouldn't fire. Also worth noting is that the instrument panel would reset itself once I had released my finger from the stater button.
I have been reading some information that suggests it is possible that the starter clutch is failing to engage the fly wheel.
Any suggestions?
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
Timmeh
PostPosted: 19:42 - 26 Jul 2013    Post subject: Reply with quote
It's not something stupid like the battery is it? Dash resetting itself would indicate lack of voltage.
Aff
PostPosted: 19:43 - 26 Jul 2013    Post subject: Reply with quote
Would it not bump?
Electric Bike Project
Renton
PostPosted: 19:48 - 26 Jul 2013    Post subject: Reply with quote
I forgot to mention that I tried jumping it with leads from a car, but that didn't work, so I ruled out the battery.
Having said that, the clock did reset itself two days ago, but the bike has been in constant use since.
Aff wrote:
Would it not bump?
After the bike failed to start with jump leads I didn't expect it to start from bumping. And I was not particularly excited about the prospect of pushing that lump around with only a pregnant lady to help.
Huambo81a
PostPosted: 19:59 - 26 Jul 2013    Post subject: Reply with quote
On my VFR800 the clocks resetting and the bike failing to start is often the regulator/rectifier. No idea about CB1300's. I had a similar problem and was advised well by people on here. What is the voltage of the battery?
Present: 2017 KTM Super Adventure S
Past: 97 Bandit 600 / 05 Bandit 1200 / 03 ZX6-R / 2006 Tuono R / 2001 VFR 800 / 2010 Street Triple R / 2013 Speed Triple S / 2017 S1000XR
Renton
PostPosted: 20:26 - 26 Jul 2013    Post subject: Reply with quote
The reg/rec seems like a good place to start. Although, it would be an expensive test if not.
Voltage is only 'electric potential'. The power comes from the current, which cannot be measured without a Load Tester. And I do not have access to one.
Aff
PostPosted: 20:31 - 26 Jul 2013    Post subject: Reply with quote
If it started from bumping, it would have pointed to a starter issue. It would also give you the opportunity to check and see what the RR is doing with a multimeter.
benvanwell
PostPosted: 21:06 - 26 Jul 2013    Post subject: Reply with quote
When the battery died on my Sprint the clocks reset and it wouldn't bump or jump. A new battery fixed it all.
Currently Riding: Triumph Sprint ST 1050
Previous: GSF600s, GS500, BMW F45, CG125
Efes123
PostPosted: 07:44 - 27 Jul 2013    Post subject: Re: CB1300 Won't Start........Again! Reply with quote
Have you had it apart? I had this on my little Suzuki project (obviosly not the dash problems), turned out to be this Crying or Very sad
https://gallery.dogfriendlysuffolk.com/albums/BikePics/Suzuki/normal_Suzuki-starter.jpg
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
Renton
PostPosted: 11:54 - 27 Jul 2013    Post subject: Reply with quote
I will try bumping it on Monday when I get back to work and see how that goes.
MattEMulsion
PostPosted: 12:10 - 27 Jul 2013    Post subject: Reply with quote
If the clocks are resetting it sounds like a power problem, either low battery voltage or a loose connection.
Yamaha YZF-R6
PostPosted: 12:50 - 27 Jul 2013    Post subject: Reply with quote
I agree, check the heavy power leads and earths.
Renton
PostPosted: 13:18 - 27 Jul 2013    Post subject: Reply with quote
I will check this when I get back to the bike.
So how comes the bike won't start with jump leads connected to another vehicle? Given that, by jumping from another power source you are effectively bypassing the bikes battery.
PostPosted: 13:21 - 27 Jul 2013    Post subject: Reply with quote
Putting jump leads on the battery only bolsters the battery on the bike. If there's a wiring fault or loose connection it will still have an effect despite the leads.
Try again by putting the black jump lead directly onto the engine or starter casing. If there's an improvement check the black batter lead end connections.
The last post was made 13 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 14 - Page Size: 84.65 Kb
