| Author |
| -Matt- |
 -Matt- World Chat Champion
 Posted: 22:13 - 10 Aug 2013 Post subject: Contemplating a change - DRZ vs XT600 |
Hi all
Haven't posted in this forum before
Been interested in getting a supermoto/traily sort of bike for a while now but just dont have the cash spare.
With moving soon and needing a bit of cash i'm contemplating selling the ZX6 and getting a DRZ400 or XT600 [maybe others but these have caught my eye], which should free up some money depending how lucky i get with the sale/purchase.
The other thing is i'm intending to commute all year round on the new bike if i go through with it - the ZX6 is currently pampered as a dry road toy to be honest, and i'm commuting by car which i'd rather be rid of which will free up more money as well as i only use it for commuting currently, and the mrs already has a car i'm insured on for shopping and whatever else.
Anyone able to recommend which of the two or other alternatives might be a good choice - i'm budgeting around 2-2.5k ideally, probably stick with road tyres that i'm used to most of the time perhaps switching to knobbly tyres for the odd green lane fun etc.
I'm going to try line a few test rides up in the coming weeks to see how i find them to ride around town.
Cheers  |
| Back to top |
| stevo as b4 |
| Back to top |
| -Matt- |
 Posted: 17:18 - 11 Aug 2013 Post subject: |
Cheers steveo
I did have a look at them but one of the pull-factors for me selling the ZX6 was to get a bit of money spare really, so as much as i'd like them the cost side of it doesn't look too likely to be suitable
Maybe have to scrap the idea of using it as a green-lane toy on the side then its not essential was just an extra benefit i thought might be fun for the weekends and stuff really.
Got a test lined up on a DRZ for this week so far anyway, so i'll give that a go first and see how i find the general feel and ride, i've only briefly been on a friends in a car park before so not really experienced one out and about  |
| Back to top |
| G |
 G The Voice of Reason
 Posted: 18:48 - 11 Aug 2013 Post subject: |
I'm not convinced by the two stevo mentioned - both weigh not far off your current bike, but with just over a third the power, maybe.
Sure, having less power and lower gearing is fun - but you could always restrict your current bike and down gear it.
Also, they're both tall bikes, which may be less than ideal if you need to steady the bike with your feet in icy winter conditions.
If possible, I would try and get a good ride on bike of this style.
The two you mention are a bit lighter, with not much less power, but are more serious dirt bikes.
I'd be tempted to see if I could get an injection TE610 - which has more power than any of the above bikes and about the same weight as a DRZ.
Or, consider getting a 'hack' commuter and a dirt bike you can have fun on in the mud - then if it's snowy, certainly consider taking the dirt bike, or when you just fancy a change.
Could get, say, a DZR400 and a tatty G/J model ZX6 in your budget just about I reckon. |
| Back to top |
| -Matt- |
 Posted: 19:34 - 11 Aug 2013 Post subject: |
Thanks G,
I haven't considered the Husq before really like the look of that.
I wasnt overly keen on the XT's from the start to be honest but they were seeming to be the main contender to the DRZ as far as i was able to see.
Having looked at the weight though, and considering i'm only 5''9-10, I could probably just about flat foot okay but i'd want a bit more than that in the commuting weathers i'm going to be likely dealing with like you said, so i think i'll ditch them.
Found a really good relevant article whilst searching about the 610 also
https://www.visordown.com/road-tests/road-test-f650-v-te610-v-dr-z400s-v-xt660r/4741-3.html
Seems the XT's aren't favoursome for off roading vs the other two so further rules them out I think.
Coming from a ZX6 I presume on road i should find the DRZ and 610 fairly controllable perhaps just a little jumpier in the revs Would you say they're probably a bit much for a novice to green laning and off roading, even if taking it cautious on them at first
Two bikes as you also suggested is out the question sadly, no more garage space where i'm moving for the next year or so and leaving it outside isn't going to be a wise option
Thanks again |
| Back to top |
| G |
 Posted: 19:50 - 11 Aug 2013 Post subject: |
The only problem I'd see with a novice riding these bikes off road is the weight - and that makes the XT much worse than the others that are still a bit heavy.
If you try and rag it everywhere, it's a lot of power, but take it easy and you're fine.
First bike I greenlaned properly was a DR600 - I left it in second most of the time, occasionally popping up to third for the faster bits.
Plenty enough low down power.
They're all low powered, but they're also low geared. Also have a higher centre of gravity, so can wheely easier when laying down the same power in a similar gear.
Also, dirt bikes are slim - get two dirt style bikes and they hardly take up more room than one, especially if you top and tail . |
| Back to top |
| -Matt- |
 Posted: 20:01 - 11 Aug 2013 Post subject: |
| Quote: | Also, dirt bikes are slim - get two dirt style bikes and they hardly take up more room than one, especially if you top and tail |
Didn't think of that one, hmm that is tempting its just if i can squeeze it all in money-wise, i really don't want to go much over 2000-2500ish or it will wipe out a lot of the money i've budgetted to save by downgrading from the ZX6, the car would still be going but thats not worth all that much.
How does servicing costs pan out with these sort of bikes, i know they require more regular oil changes, does this crank the cost up a bit VS the likes of the ZX6 I've been doing 10k a year on it so its been needing stuff done fairly regularly, but consumeables-wise, even with it being commuted on through winters it should be a fair sight cheaper with the dirt bikes shouldn't it
On that note, with the higher seating position, would you say they;re stable enough for road speeds in more wintery/wet conditions or is it a bit hairy at times even on road tyres
Cheers  |
| Back to top |
| G |
| Back to top |
| -Matt- |
 Posted: 21:25 - 11 Aug 2013 Post subject: |
Dont think i could bring myself to revert back to a 125 to be honest, as good of a little bike as a YBR or similar would be for the commute
I ride the ZX6 like a pansy most of the time, barely ever goes above half its capability - another reason i've decided it might be wise to sell it, i'm just not using most of the bike, i love the feel and looks but thats where the sense stops really
The DRZ or Husq sound perfect really, the height should be a bonus visability wise on the commute - going to be 10 miles tops through towns mostly with a couple of carriageways so its only really low speed turns at junctions and a lot of roundabouts that might be an issue in the more slippery months, hopefully the road tyres will keep me steady
I could do it on the ZX6 to be honest but with my height/build its like riding on a shire horse sometimes, and the way i sit tends to put my knees out a bit, which with the thickness of the bike makes it a bit bulky commuting in tight city traffic These things look perfect |
| Back to top |
| G |
| Back to top |
| -Matt- |
 Posted: 20:50 - 13 Aug 2013 Post subject: |
So following up - Test rode the DRZ today - Never really considered it previously when i rode one in a carpark, but as G mentioned, its suprisingly wide for city traffic, and more annoyingly it doesn't feel it, its only when I was going to filter i suddenly realised ''oh shit... the bars are out here'' and on a few occasions had to hold back quite a way from the front of the queue.
Did really enjoy it out on the road though it feels more raw than the ZX6 but that may be as i ride it so modestly most of the time perhaps. The test was done in and around central Bristol were its multi-lane chaos in terms of traffic, where i'm moving and intending to use the bike for commuting is a much more smaller town, so although multi-lane road filtering here prooved troublesome, in a small town going down the centre of a road i think the width wouldn't concern me too much.
Stability wise i also it very inspiring, suprisingly so in corners, and the additional height was useful for visibility, so its a definate winner there. Will try and arrange a test on a couple of others now, really interested in the Husq 610 but having looked about there doesn't seem to be any within budget at the moment  |
| Back to top |
| bikertomm |
 bikertomm World Chat Champion
| Back to top |
| -Matt- |
 Posted: 23:24 - 13 Aug 2013 Post subject: |
Make my day and tell me its within a 2k ish budget though
The bike looks incredible, and as previously mentioned the wheels are a tease but just don't think its 'affordable' on my plan
Visually its exactly what i want [yet to ride a supermoto style bike over 400ish also], chunky and bigger tyres, no idea how that will convert onto road, but after todays commute on the DRZ the bigger looks might not be wise to be honest as the DRZ felt chunkier than expected.
Still.... plenty of daydreams to be had over them yet  |
| Back to top |
| G |
| Back to top |
| -Matt- |
 Posted: 00:00 - 14 Aug 2013 Post subject: |
| Back to top |
| G |
| Back to top |
| mysterious_rider |
 mysterious_rider World Chat Champion
| Back to top |
| P.addy |
 P.addy Red Rocket
| Back to top |
| G |
 Posted: 00:52 - 14 Aug 2013 Post subject: |
If you liked the trials bike for ragging up and down a field, you'll absolutely love the 300EXC .
XT is Yamaha.
Hondas are 'unreliable'.
Also, boring.
| Back to top |
| stevo as b4 |
 Posted: 12:17 - 14 Aug 2013 Post subject: |
I'd listen to people like G with lots of off road and enduro bike experience, but your 10mile commute with urban roads and a bit of dual track sounds ideal for a Supermoto bike. I think winter would be fun and cheaper as these bikes are cheaper in consumable spares and fewer of them than any sportsbike. No plastics to crack and if you fit stuff like axle protector bungs and wrap around hand guards to save the lever's, a spill will most likey result in a few cosmetic scuffs and that's it.
I also like G's suggestion of 2bikes if you can afford it, as already mentioned they can be stored in about the same space as a big road bike, and you get a back up bike to use if one needs work etc.
It's only my opinion, but id get a cheap and robust probably aircooled supermoto style bike for your daily ride to work, and if it's just being used on the road I'd try and get a at least a 500cc single or bigger, so you have some grunt. I think an SM converted XT600/660 or Honda XR600 or a KLX650 etc is ideal. I'd want key ignition, and proper service intervals for a road only bike.
Trying to get one bike to cover the on and off road stuff is a bit tricky, but I'd still not go for anything too specialised or expensive or needy of service intervals for your first off roader. Having said that If your going for a 2bike plan then you could go a bit extreme or specialized for your 2nd bike. A road legal enduro or trials bike would be fun in lots of situations, even an MX bike at a push.
The biggest enduro bike I have ridden off road in loose muddy conditions was a Yamaha WR250F and it had so much more ability than me, and was a really great very capable bike that could do everything with ease. But then a DT125 etc could with the right tyres and re-geared do the same thing until you get really serious. I'd keep an open mind and see what comes up locally if your after an off road bike. But I'd like a tough hardy and fairly practical Jap bike for a road machine, something like an XR600 would be great I reckon and well within budget.
BTW I've lost all respect for those KTM525 SM things, after seeing one easily outdragged from 30mph by a big 1800cc Suzuki cruiser type thing. It just went barrrp and made a lot of noise while the Big Ghey Suzuki shuddered off into the distance.  |
| Back to top |
| G |
 Posted: 12:30 - 14 Aug 2013 Post subject: |
| Back to top |
| -Matt- |
 Posted: 13:28 - 14 Aug 2013 Post subject: |
Thanks again guys, so much to ponder over going to have to get a lot more test rides on the cards I think |
| Back to top |
The last post was made 13 years, 60 days ago. Instead of replying here, would creating a new thread be more useful? |
