| c.smith |
 c.smith L Plate Warrior
 Posted: 03:55 - 03 Sep 2013 Post subject: Rotating engine with valve shims removed - big problem? |
Hi all. New member, new motorcycle owner, and new DIY-er here, so please bear with me.
I recently checked the valve clearances and changed the shims on my 1997 Suzuki GS500. One reference I used was this video, which states at 9:45, "Note: Do NOT rotate engine with shims removed." Well, I did this, and what's more, I left the bike in this state for 3 months (dealer ineptitude + my own laziness = took forever to acquire replacement shims).
I was unable to ascertain why this is so bad as to warrant an all caps and underlined "not," or what the effects would be. As such, I hoped I could just finish the job and everything would be fine. Now, I've finally put new shims in and attempted to start the engine, and it won't start.
The battery has been safely stored inside and charged regularly, and the lights all work, so I don't think that's the issue. Fuel drains out of the carb float bowl when I loosen the appropriate screw, which, according to my maintenance book, indicates that access to fuel is not the issue.
I replaced the spark plugs before doing the valve clearance check and went on a single test drive afterward, so I doubt they are the problem. One caveat: I neglected to turn off the choke when I rode with them, which I heard can foul the plugs. They also did appear to have some black gunk on them, which I tried wiping off with a paper towel, to no avail. Still, a 30 minute ride wouldn't be enough to foul brand new spark plugs, would it?
This leads me to think that the problem is compression, and might(?) have been caused by messing up the valves when I rotated the engine without valve shims. I don't yet have a compression gauge (will probably order a ~$20 one soon), so I can't check if compression is indeed the culprit. Am I right to be worried about this, or is rotating the engine without shims probably not a huge deal and my startup troubles likely stem from something else?
I'd greatly appreciate any clarification or advice that anyone more knowledgeable in the ways of engines could provide.
TL;DR: Would rotating the engine without valve shims significantly damage the engine, and/or cause compression problems which prevent the engine from starting? Or should I look elsewhere to get my engine started? |
| uberkron |
 uberkron Crazy Courier
| jjdugen |
 jjdugen World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 06:03 - 03 Sep 2013 Post subject: |
Forget the shims and cams, you went for a half-hour test-ride so they aren't a problem. Besides, if you didn't touch the chain tensioner it'll still be timed correctly.
Remove the carbs and service them. Leave the tops on, but pay close attention to the choke plungers and their circuits and also the one/two tiny pinholes that are next to the bottom of the throttle butterfly when it's closed plus all the gubbins in the float bowl. I use carb cleaner, compressed air and an acupuncture needle to clear them out. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 06:38 - 03 Sep 2013 Post subject: |
I presume it ran ok on your test run?
I would imagine they tell you not to rotate the engine because when you have the shims out, you also have at least one cam off and the camchain loose. If you turn the engine like this, it makes it marginally fiddlier to set the timing again when you reassemble. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Aff |
 Aff World Chat Champion
 Posted: 10:28 - 03 Sep 2013 Post subject: |
I don't think he has got the bike started after the valve job.
I read it as he changed the plugs before the valve job and took it for a test ride to see if the plugs worked, then he changed the shims and it hasn't run since. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| Fizzer Thou |
 Posted: 10:53 - 03 Sep 2013 Post subject: |
For future referance Wemoto sell replacement shims
https://www.wemoto.com/bikes/suzuki/gs_500_k3/03/picture/valve_shim_2.25_mm/
From what I remember the last time that I worked on a GS500 Twin it is shim-on-bucket and a special tool is used to depress the bucket that the shim sits in.The shim can then be accessed without having to remove the cams.
The only reason that I can think of as to not rotate the engine without the shims in place,is because the lip that holds the shim in place can snag the edge of the cam and possibly damage both.When I sorted the shims on this particular GS500 that I was working on,I measured the clearance,removed that shim to check the size and then put it back into place while checking the others.A list was then made of the replacement shims that were needed.Some dealers do an exchange system where there is a small charge,which keeps costs down.
As to the reason as to why the engine will not start,I would suspect the battery.If not used they can sulphate a cell or two.If you try jumping from a car battery see how that goes.
A compression check will point you in the right direction,as this may well point to gummed up piston rings or valve seats which are corroded. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| Fizzer Thou |
 Posted: 11:12 - 03 Sep 2013 Post subject: |
| stinkwheel |
 Posted: 11:53 - 03 Sep 2013 Post subject: |
In that case, the most obvious cause for a) Poor compression and b) Not running following a re-shim is that the timing is not set correctly.
I'd suggest re-checking the valve timing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| J.M. |
 J.M. World Chat Champion
 Posted: 13:22 - 03 Sep 2013 Post subject: |
The usage of the proper bucket compression tool should not upset the timing in any shape or form on the GS500. Rotating whilst they are removed would also not upset the timing, but others have noted that it could cause little damage to other components such as the bucket surface/cam lobes.
The timing on the GS500 is measured between Arrow #2 on the exhaust camshaft and Arrow #3 on the intake camshaft. The arrows should point directly at a pin in the cam chain. There should be 18 pins (including the 2 that the arrows point at) between the two arrows.
This website shows how to do/check the timing: https://beergarage.com/GSTiming.aspx ____________________ 2004 R1 & 2018 XSR900 |
| Pete. |
 Pete. Super Spammer
| prawny1 |
 prawny1 World Chat Champion
| Pete. |
 Pete. Super Spammer
| prawny1 |
| J.M. |
| andym |
 andym World Chat Champion
| c.smith |
 Posted: 22:45 - 05 Sep 2013 Post subject: |
Thanks so much to everyone who's chimed in so far, it's been enlightening and helpful.
To clarify a few questions people had:
1) I have not gotten the bike running after changing the valve shims. The test run was after changing the spark plugs, but before messing with the valves at all.
2) The bike didn't run well when I left the choke on during the test. It kept wanting to stall and die when I stopped at lights, which confused me until I turned the choke off at the end of the ride and the engine picked up.
3) I did use the specified bucket compression tool. I was pretty thorough in checking the new clearances, but I haven't taken a look at the engine and double checked anything after putting the tank back on and failing to start the engine. That'll be my next step if a compression test turns up positive.
To update:
I bought new spark plugs and they didn't fix the problem. I haven't checked for a spark yet because I was too afraid to start a fire in the parking garage. Maybe there's very little risk of that, I don't know, but I'm being cautious (I also had recently spilled gasoline in the area, and didn't have a fire extinguisher on hand...)
I've ordered a cheap spark tester and compression gauge, which should arrive tomorrow, so my plan is to do those tests and go from there.
I also might try jump starting from a car, as suggested by Fizzer Thou, to eliminate the possibility of the battery being the problem. This still seems very unlikely to me because my multimeter indicates it's fully charged and it seems to be doing fine powering the lights etc. Is it still possible that the battery is the culprit despite these indications? I'm not really sure what it would mean to sulfate a cell. Also, it's an AGM battery, if that makes any difference.
Thanks again for everyone's input so far, I'll continue to update and ask questions as the situation progresses. |
| Pete. |
 Pete. Super Spammer
 Posted: 05:43 - 06 Sep 2013 Post subject: |
If the battery was cranking it well before, it should still be doing it now. Won't harm to check but beware because if you are cranking from jump leads it'll turn faster and might start because it's pulling fuel through the carbs better, making you think the problem is the battery when in fact it's the extra revolutions pulling in fuel that you wasn't getting before.
Take out the plugs, put them in the caps resting on the engine and crank it over to check for spark. You won't start a fire that way - I have tried to and failed. Don't crank the engine with a plug out of the cap though, it's bad for the coils.
If you have a spark, service the carbs. ____________________ a.k.a 'Geri'
| J.M. |
The last post was made 13 years, 70 days ago. Instead of replying here, would creating a new thread be more useful? |
