| azazelus91 |
 azazelus91 Derestricted Danger
 Posted: 10:44 - 11 Sep 2013 Post subject: Kawa ZX7r 1997 Carb problem --- Im going crazy here - Please |
Hi Guys.
I am having a really big problem with this bike.
The bike was off for 2 years. I decided to take the carbs off and clean them. I spent 2 days cleaning the carbs and now i think they are ok. I checked and did the float heigh 13 mm for each carb.
Now here we go.
I did the mixture screw 2.5 turns. I installed the carbs back on the back ( no air filter). I pulled the choke to 100% and push the button. The engine starts for 2 seconds then dies. I have to repeat this step 10 times and then the engine will stay at 1500 rpm idle speed with choke 100% off. After the bike is warm the engine will idle fine at 1500 and throtle is working fine.
This problem with bike not starting correctly it was before i took the carbs out and clean them.
So.... i took the carbs out again and set the mixture screw at 4 turns. When i tested again something weird happened .. the bike will rev very high at 7 k rpm and when i push the throttle the bike goes craze at 10 000 rpm and stays at 10 000 couple of seconds and then goes down really slow. BUT the bike starts now with no problem at all from the first time.
I took the carbs out again and i did the mixture screw 3 turns. Now i have the same problem as previous step with 4 turns but idle is around 3000 rpm. When i push the throttle it goes crazy again like is sucking air from somewhere. Now i thought that there is a leak on those 4 rubbers between engine and carbs but i checked them and i also tighten the collars and i dont think i have any leak there.
Now what should i do? Should i go back with 2.5 turns ?
I checked the pilot jet is fine. I checked the valve needles ... for me they are looking ok. I could not get the seating valve body out ( i dont know how to do it and i was afraid not to brake it ) but i sprayed a lot of air and carb cleaner inside.
The throttle cable is not stuck and the choke is working fine.
The high idle and when i push the throttle the rpm will go down very slowly is a problem caused by any air leak? Rich mixture?
Please HELP.
Thank you
| azazelus91 |
| Fizzer Thou |
| azazelus91 |
| Fizzer Thou |
| prawny1 |
 prawny1 World Chat Champion
| azazelus91 |
| prawny1 |
| azazelus91 |
| azazelus91 |
| prawny1 |
| azazelus91 |
| prawny1 |
 Posted: 13:46 - 11 Sep 2013 Post subject: |
butterfly spindles can leak as can carb balance points (either screws or rubber sleeves over a tube) diaphagms can leak too but usually they cause hesitation and stop you reaching full revs.
Did you double check all the jets got screwed in ok, I have put carbs back on before and forgot to screw the jets in so they just dropped into the float bowl the bike flooded badly until I realised. ____________________ hellkat wrote:
Some people are only alive cos its against the law to kill them. |
| azazelus91 |
| stickybackbob |
 stickybackbob Trackday Trickster
| azazelus91 |
| azazelus91 |
| azazelus91 |
| Pete. |
 Pete. Super Spammer
| Fizzer Thou |
| azazelus91 |
| azazelus91 |
| prawny1 |
 Posted: 10:54 - 12 Sep 2013 Post subject: |
By balance point I mean where the guages are connected to,
The pilot screw can be set up to control total idle air/fuel flow or idle airflow with the fuel being unmetered.
with the first type screwing the pilot out will richen the mix as both the air flow through the idle circuit and the fuel from the slow speed jet must pass the needle, with the second type the pilot screw can only add more air to the mix the further you screw it out because the fuel flow is being directly metered by the slow speed jet.
first type goes air bleed, jet, pilot screw and is called fuel mixture screw. this type will have a separate orifice in the carb throat to control idle fuel flow and usually three smaller holes just under the butterfly that the pilot jet will flow through to transition to the main jet, adjusting the pilot screws on this type of carb only effects the idle air/fuel mix not the slow speed circuit.
second type goes air bleed, pilot screw, jet and is called idle air mixture screw. The idle and slow speed/pilot jet will share the same orifice usually. On this type of carb the pilot screws will effect the air fuel mix of both the idle and slow running circuit so if they are screwed out too far it will be like having an air leak.
It sounds like you have the second kind of carb where the screw controls air flow into the idle/ slow speed circuit which if you have them out too far will cause the bike to rev high and hang like you describe.
In this case you need to screw the pilots in to richen up the mixture and probably need to lower the idle speed via the idle/ tick over screw.
The carbs had probably been adjusted and balanced without cleaning, so when you cleaned everything the old settings became useless, you will need to rebalance the carb with gauges eventually but a good place to start is with a set of toothpick or some stiff wire (welding wire or something), with the carbs off identify which is the control carb this will be the one that has the throttle cable and the idel speed screw on it,
Next take your wire or tooth pick and adjust the idle screw so that the tooth pick is a tight sliding fit under the butterfly then match the other three butterflies to the same position by placing the toothpick/ wire in the same place you did for the first carb and adjusting the little spring loaded screws until it feels the same.
Once you have adjusted them all snap the throttle shut a few times and recheck once you have finished your carbs are now "bench balanced" often this is good enough and only minor adjustment is needed.
Once the carbs are back on screw the pilots to about 2 turns out and run the bike to set the idle speed,
you then can adjust the pilot screws, slowly turn the screws out bit by bit until the bike begins to hang when the throttle is blipped and note the settings then turn the screws in until the revs begin to dip then settle after being blipped and note the settings usually setting the screws inbetween these two point is ideal ,
Using the two numbers you can work out the how many turns out you need, for example if the bike stumbles at idle with 1.5 turns and revs hang at 2.5 turns the you set the screws in between these two which is 2 turns. if you find you still have some hesitation you can set the screws 1/8 turn at a time either way to see if it helps.
Damn it takes me ages to type a post when I started you had not replied. ____________________ hellkat wrote:
| azazelus91 |
 Posted: 11:04 - 12 Sep 2013 Post subject: |
| prawny1 wrote: | By balance point I mean where the guages are connected to,
Using the two numbers you can work out the how many turns out you need, for example if the bike stumbles at idle with 1.5 turns and revs hang at 2.5 turns the you set the screws in between these two which is 2 turns. if you find you still have some hesitation you can set the screws 1/8 turn at a time either way to see if it helps. |
thanks a lot for explanation.
i will try this. the only problem is that i cannot access the mixture screw while bike is running because that screw is between carbs and the engine. Everytime im changing the mixture screw by turns I need to take the carbs out and then put them back in.
This is my carb :
https://www.cmsnl.com/kawasaki-1997-p2-zx750_model12924/partslist/E1612.html#results
The mixture screw is piece number 16014
I have the screw + spring + washer + O ring and have a needle stick to the screw tube. |
| prawny1 |
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
