nsr 125 water pump impeller
coopsy65
PostPosted: 17:40 - 03 Oct 2013    Post subject: nsr 125 water pump impeller Reply with quote
hi,can anyone pls tell me if the water pump impeller on an nsr 125 jc20 is left or right handed thread cheers
bikenut
PostPosted: 14:10 - 04 Oct 2013    Post subject: impellor Reply with quote
:karma: which way does it rotate when the engine is running........turn flywheel by hand with ign killed to see..........
some mtx have l/hand thread..........
you know of cmsnl for the exploded views........... :karma:
nuts about bikes
coopsy65
PostPosted: 18:29 - 04 Oct 2013    Post subject: Re: impellor Reply with quote
ok cheers i'll try in the morning
bikenut
PostPosted: 09:38 - 05 Oct 2013    Post subject: impellor Reply with quote
:D well its morning here and its stopped raining........
so, when engine rotated in normal direction of rotation, which way does the impellor turn??
use some logic........impellor will act like a water brake....
in so much that the water will try and stop the impellor turning........
and if the thread is the wrong way will try and undo the impellor........
did you check cmsnl.....is the impellor "keyed" to its drive shaft?
nuts about bikes
sprintster
PostPosted: 17:30 - 05 Oct 2013    Post subject: Reply with quote
If it's the same as an NS125 it's just a normal right hand thread.I found it best to use a 12 volt impact driver to remove and fit it without turning anything else.
The last post was made 12 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.18 - MySQL Queries: 14 - Page Size: 42.72 Kb
