| gtchtc07 |
 gtchtc07 Derestricted Danger
 Posted: 07:05 - 22 Oct 2013 Post subject: Aprilia RS 125 FP 2006, Power Valve Solenoid PROBLEMS !!!! |
My bike has lost all its power above 8000rpm, I am aware that it is a problem with the power valve system on the bike, i have fully cleaned and replaced the valve blade, i have cleaned, oiled and greased the valve cable and i have fully cleaned the solenoid it is not sticking and all round is in excellent condition...
i have noticed that when the bike is sitting idle and the power valve is closed, when i rev to 2000rpm / 2500rpm the solenoid pulls back a small amount and opens the valve blade half way, the valve blade seems to slowly slip closed again.. as if the solenoid does not have the grunt it should to hold the valve fully open...
could this be caused by a faulty battery although it seems to sit around 12 / 14 volt when on just ignition before start up ((from dash computer)) ,, and she starts first time,,
or is this a sign that i need a solenoid?
although i may just replace it for the hell of it lol  |
| SQL |
 SQL World Chat Champion
| gtchtc07 |
| P.addy |
 P.addy Red Rocket
| gtchtc07 |
| P.addy |
 P.addy Red Rocket
| gtchtc07 |
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 10:38 - 23 Oct 2013 Post subject: Re: Aprilia RS 125 FP 2006, Power Valve Solenoid PROBLEMS !! |
Hi,
yes, this could be a sign of f*cked battery.
have you checked the battery & charging circuit? with a multi-meter & NOT the lcd. (notoriously un-reliable)
check it with lights on & at 5500rpm, should be around 14v.
have you actually adjusted the cable at solenoid end as per wsm?
very little to go wrong with solenoid tbh & it being a 2000 bike, i wouldnt expect it to be totally f*cked.
take it off, clean it up & test it. DONT pin it open if you do any riding in traffic, it makes it useless below 9000rpm.
cheers,
GAZ |
| gtchtc07 |
 Posted: 11:24 - 24 Oct 2013 Post subject: Re: Aprilia RS 125 FP 2006, Power Valve Solenoid PROBLEMS !! |
| stirlinggaz wrote: |
Hi,
cheers,
GAZ |
adjust cable !!!,,, oooops my bad lol,
think its fixed,, started it up and just on choke she revved up off the clock,, so much so that the rev counter jumped the cog lol got stuck at 4000 and above until i turned key 10 times lol she never done that before so im guessing that would be the power valve kicking in properly,,,
will post again once i have a chance to go for 100 and see how she gets on. |
| P.addy |
 P.addy Red Rocket
 Posted: 11:51 - 24 Oct 2013 Post subject: |
On choke... revving off the clock.
I'm not sure I like my piston rings fried, what about you  |
The last post was made 12 years, 241 days ago. Instead of replying here, would creating a new thread be more useful? |
